Nsr125 electrical problems! Fuse box??
WillRoy
PostPosted: 09:26 - 18 Mar 2018    Post subject: Nsr125 electrical problems! Fuse box?? Reply with quote
Hi guys, I was a bit dopey.. Confused
I bought an nsr after not riding for years. Im not 100% savvy on bikes, I'm fairy good with cars though..
So the problem.. the bike was running fine, ignition came on when you turned they key.. neutral light, kick stand light, lights came on ect..
Had to fix the kill switch as the connection came unplugged.. while I was looking round saw some rust on front of the frame that holds the headlights, decided to take it off rust treat it and respray. Went to put everything back together and think I may have blown a fuse.. as now there is no life on the bike. Battery is fine but when I turn the key nohing happens, no nutral light, no kick stand light, nothing..
I've read on here about possible fuses and connections. I've cleaned out the connectors and have been trying to locate the fuse box and I can't for the life of me find it! Shocked
My question.. where the hell do I find the fuse box? I've traced all the wires back and can't find anything that remotely looks like a fuse box
Do they have a fuse box or am I being blind??
Any suggestions where it is?! Embarassed
alains
PostPosted: 12:11 - 18 Mar 2018    Post subject: Reply with quote
this bike has only one fuse of 15A in a cylinder shape plastic box sited on the main positive near the battery
the fuse is in a glass tube (easy to see if gone) . it goes off very rarely
to check if it was that :
- put key on
- with a small wire touch the 2 ends of the fuse holder and see if your dash board comes on
if it's not that check ground and battery positive
the positive is always RED , ground is GREEN , positive with the key is BLACK
Boddee This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Hong Kong Phooey
PostPosted: 16:16 - 18 Mar 2018    Post subject: Reply with quote
Get a digital multimeter and learn how to use it.
WillRoy
PostPosted: 23:01 - 19 Mar 2018    Post subject: Reply with quote
- put key on
Cheers guys, I spent about 30 mins looking around finally found it tucked under the frame out of sight, 15a fuse right next to the battery.. easy to find, if you know what your looking for..! replaced it and it's all good. Many thanks for the help
Thought I was being a bit special when I couldn't find it haha
And for the dude that said get a multi meter and learn how to use it, didn't even have anything to do with my question. very original and constructive. A++ comment.
Hong Kong Phooey
PostPosted: 00:16 - 20 Mar 2018    Post subject: Reply with quote
I thought this was also you.
https://www.bikechatforums.com/viewtopic.php?t=323721
Don't matter though, still buy one, one day you'll return to thank me Thumbs Up
WillRoy
PostPosted: 11:36 - 20 Mar 2018    Post subject: Reply with quote
Okay, fair enough man. I thought you were just trying being rude, my bad. I have a multi meter and I know how to use one, but I couldn't find where the fuse was, which was my point and question.
Cheers for the advice.
The last post was made 6 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.99 - MySQL Queries: 17 - Page Size: 60.91 Kb
