Daelim roadwin Cush drive
Sammydroid
PostPosted: 17:28 - 21 Mar 2018    Post subject: Daelim roadwin Cush drive Reply with quote
Hi to all
I’m a bit new to this so not sure exactly what to ask
I’ve got a daelim roadwin 125 and it needs new Cush drive rubbers. I’ve been quoted 40 quid for these + labour but I’m seeing loads of them on such as eBay for way cheaper (some are like 15 quid for 4) but these are for Honda cg’s etc
My question is, if they look similar to the ones on mine would they fit? Because I feel as though my garage is taking me for a mug at 40 quid
Evil Hans
PostPosted: 18:16 - 21 Mar 2018    Post subject: Re: Daelim roadwin Cush drive Reply with quote
To be honest, one cush drive rubber looks very like another. But they have to fit properly, otherwise they'll be no better than the worn ones.
40 quit to supply and fit doesn't sound OTT, really.
Sammydroid
PostPosted: 18:20 - 21 Mar 2018    Post subject: Reply with quote
Basically, I bought another back wheel because mine was buckled (I’ve apparently been riding it like that since I got it off it’s previous owner, long story) but the wheel I’ve bought was advertised as needing new Cush drive rubbers. I thought it would be a simple case of removing the ones from mine to the new (second hand) one but I’ve obviously discovered that it’s not that easy
They are the round ones that the sprocket studs sit in
Sammydroid
PostPosted: 18:22 - 21 Mar 2018    Post subject: Reply with quote
They’re wanting 40 quid just for the parts, then however much it’s going to cost me in labour (don’t know how long it’ll take them to do it)
Beehive Bedlam This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
Sammydroid
PostPosted: 19:49 - 21 Mar 2018    Post subject: Reply with quote
Here’s 2 pics of the hubs. The one with the decent rubbers is the buckled one I took off mine and the other is the state the rubbers are in on the second hand one hence the reason for replacement
Teflon-Mike This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
PostPosted: 08:09 - 22 Mar 2018    Post subject: Reply with quote
Yup, Abusive given for blatant and repeated waycism. He's been told over and over.
Teflon-Mike
tl;dr
PostPosted: 14:27 - 22 Mar 2018    Post subject: Reply with quote
Whether the road-vehicle as registered was first assembled in Tiwan, Balangladesh, or Homatsu, is of little pertinence.....
Fact is these bushes are a bast'd to get out, without wrecking the wheel, or not... in which case wheel was probably wrecked to start with, lacking metal to grip the ruddy things!
Hardly racist to say so, especially when criticism also applied to original design and product emanating from Japan!!!
steve the grease
PostPosted: 20:15 - 22 Mar 2018    Post subject: Reply with quote
These rubbers are not the ' just drop in ' type. They are a metal/rubber composite bush and will be a difficult job to change as I guess they are in a blind hole. The old ones will need grinding out with a die grinder, then collapsing in on themselves. I wouldn't undertake it for forty quid including parts..................
Raffles
PostPosted: 20:39 - 22 Mar 2018    Post subject: Reply with quote
Neither would the outfit that quoted for the job:-
Sammydroid wrote:
I’ve been quoted 40 quid for these + labour.....
Robby
Dirty Old Man
PostPosted: 13:07 - 23 Mar 2018    Post subject: Reply with quote
Cush drive rubbers act like a shock absorber. They absorb some of the vibrations from the chain, make the bike less jerky on closed-throttle deceleration, and make gearchanges a bit smoother. They also help to extend chain life.
However, that particular type of cush drive just isn't very good. I've done a back-to-back comparison on one of my bikes where I have a back wheel with a round cush drive (RSA model) and one with a proper cush drive (RSD model). The proper cush drive works.
You've been riding around with a buckled wheel without noticing. I doubt you would notice a big different between new and old round cush drive rubbers.
So if the rubbers in the replacement wheel are all there and look vaguely ok, I would just ride it and see how you go. Replacement is, as said, a proper bastard job. The labour is likely to cost more than the parts. Even DIYing it, you'll easily spend £50 on the tools to do the job, and quite possibly ruin the wheel in the process.
bassmastergen...
PostPosted: 19:38 - 28 Mar 2018    Post subject: Reply with quote
Just be grateful that they can get the parts and someone is prepared to fit them. The Daelim scooter I had some years ago was definitely praiseworthy, but their dealer network had collapsed by 2008, and you could hardly find any spares at that point.
£40 + labour sounds perfectly reasonable given that - as steve the grease has already said - these will have to be extracted with a die grinder. Get it fixed and continue to enjoy riding it.
There's a lot of shit being talked in this thread by people who don't understand that a) South Korea != China, and b) not all cush rubbers simply drop right in. Such is the Internet.
PostPosted: 21:30 - 28 Mar 2018    Post subject: Reply with quote
Which people, plural?
Bodytard arguably doesn't count as a person. He's more like if Koko the gorilla had learned to type instead of sign.
Sammydroid
PostPosted: 17:53 - 06 Apr 2018    Post subject: Reply with quote
I ended up just buying yet another wheel in the end (i’ll just sell the other one on at a loss, let someone else deal with it Wink )
One i bought was only £55 quid inc postage off ebay and it came with a decent tyre, bushes, sprocket and the disc as well.
Would have cost more to have the work done
But thanks for all the advice
The last post was made 6 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 17 - Page Size: 109.36 Kb
