Author |
Renzakuken |
Renzakuken Borekit Bruiser
Back to top |
RhynoCZ |
RhynoCZ Super Spammer
Back to top |
Renzakuken |
Posted: 16:10 - 23 Mar 2018 Post subject: ^ |
Yep sounds good
I guess i can just drain the new oil and re-use it
All the same, what would the torque specs be
I've ordered a new gasket ____________________ CBR 125 2006 STOLEN
GSX600F 2003 SOLD
GSX650F 2009 CURRENT |
Back to top |
bikenut |
bikenut World Chat Champion
Back to top |
Renzakuken |
Back to top |
RhynoCZ |
Posted: 18:25 - 23 Mar 2018 Post subject: Re: torque |
bikenut wrote: | Yes, ignore torque values and strip thread etc. |
bikenut wrote: | just take your time and don't get any silicon or any sealer down the threaded holes, as they may/can/do burst. |
Why would anyone use silicone? Sealants are the cancer of every single garage! The easy way for those too lazy to do the work properly.
bikenut wrote: | Ever made your own paper gasket ? A good skill to have. |
Yes, simple stuff, doesn't have to be perfect.
EDIT: Doesn't have to be perfect in this case. If, for instance, you make a gasket for between the two halves of the crank case, then you have to make sure you have the right thickness of the paper. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI; MZ 150 ETZ, '98 Mercedes-Benz w210 E200 Kompressor |
Back to top |
ADSrox0r |
ADSrox0r World Chat Champion
Back to top |
RhynoCZ |
Posted: 19:46 - 23 Mar 2018 Post subject: |
ADSrox0r wrote: | Some manufacturers specify sealant at certain points, the VFR for example specifies sealant at two points on the alternator cover. |
Yes, if it's specified by the manufacturer, then it is alright.
But the horrors/stupidity I've seen over the years is just ridiculous. I bought a motorcycle from a lad who glued the carburetor bowl to the carburetor because he torn the seal. He used the multipurpose red silicone, which shall not be exposed to the petrol nor heat, and as it deteriorated it first clogged up the jets and then the bowl started to leak. Of course it didn't leak when I was buying it.
My fix was a proper seal, made by a specialist and I paid maybe £2 for it, not sure right now, and guess what, it worked.
Then I bought a motorcycle where the previous owner glued the exhaust silencer to the rest of the exhaust system with the very same red sealant. I also have seen someone using the exact same red sealant instead of the head gasket, completely messing up all the coolant and oil ways into the head. And I could go on with such horror stories all day long... ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Back to top |
The last post was made 6 years, 6 days ago. Instead of replying here, would creating a new thread be more useful? |
