Changing 2003 Fazer ignition lock.
Andy_Pagin
PostPosted: 11:57 - 09 Apr 2018    Post subject: Changing 2003 Fazer ignition lock. Reply with quote
The keys getting a bit sticky so it's time to fit a new lock assembly. How do I go about getting the old barrel out? (INB4 ask the local bike thieves Laughing )
weasley
PostPosted: 12:45 - 09 Apr 2018    Post subject: Reply with quote
Diagram here
Item 26 held in by item 27. Item 27 is a security bolt, which you screw into place then knock the end off, making it impossible to undo again by conventional means. May be able to tap it round with a punch, or cut a slot in and unscrew it, or file some flats on it and use a spanner, or drill it out. You may want to do the seat lock too if you want matched keys.
Before all that though, will some lock lubricant not fix it?
kramdra
PostPosted: 19:52 - 09 Apr 2018    Post subject: Reply with quote
Locks dont usually wear too much, blast it with brake cleaner and get some new keys cut.
The last post was made 6 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 17 - Page Size: 37.03 Kb
