Author |
10kovako |
10kovako Borekit Bruiser
Back to top |
MCN |
MCN Super Spammer
Posted: 20:31 - 10 Apr 2018 Post subject: |
I hope to Christ you are not going to flounce on us before we solve your problem for you like the last new member.
____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Posted: 00:36 - 11 Apr 2018 Post subject: |
Errrr, battery wrong voltage, Errr, ignition , kill & relay switch full of mercury.
Back to top |
10kovako |
Back to top |
HappyDays |
HappyDays Renault 5 Driver
Posted: 09:28 - 11 Apr 2018 Post subject: |
Hi,
For me I would put the stock indicators back on, see if the problem goes or do the front indicators first then try the back also check wires out with diagram ____________________ Liquorice Torpedoe |
Back to top |
HappyDays |
Posted: 09:36 - 11 Apr 2018 Post subject: |
Also from the indicator relay put in your own earth to frame, then you know you have a good negative/earth, then start with the positives side to each light.
Solder a bulb with two short wires and then go to the relay see if its any better.
Back to top |
10kovako |
Back to top |
HappyDays |
Back to top |
10kovako |
Back to top |
stinkwheel |
Posted: 17:00 - 11 Apr 2018 Post subject: |
Slowing down with the horn suggests an earthing issue, the horn button connects the horn to earth when pressed on most bikes.
A decent electronic flasher relay should flash at the same rate regardless of the load on it so I'd be inclined to blame the relay. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
10kovako |
Back to top |
stinkwheel |
Back to top |
neptune8 |
neptune8 Nova Slayer
Back to top |
10kovako |
Back to top |
neptune8 |
Back to top |
neptune8 |
Back to top |
10kovako |
Back to top |
neptune8 |
Back to top |
neptune8 |
Back to top |
The last post was made 6 years, 17 days ago. Instead of replying here, would creating a new thread be more useful? |
