Author |
Kayak23 |
Kayak23 Two Stroke Sniffer
Posted: 10:29 - 11 Apr 2018 Post subject: Do I need new piston rings? |
Hi.
I'm currently in the process of rebuilding the top end of my 1982 GSX400F. It needs the valves doing etc.
I also have the head off as I'm painting it etc.
I've cleaned all the coke off my pistons and am now turning my attention to the rings.
All of the bores are nice and smooth, no scoring however, they don't have the cross hatching from a fresh hone.
Before I dismantled the engine I did a leakdown test, and found the valves were not sealing, hence the teardown. I found that leakage to the oil filler (indicating worn rings) wasn't too bad but it was there(bearing in mind it's a cold engine obvs)
I've been looking at how you measure the rings properly and they all seem to be within wear tolerances except for 'free end gap' limits.
I can't actually find anyone really mentioning this measurement as important, other than in my manual so am wondering how much weight I give it considering that the end gaps when in the cylinder are all good and replacing all 4 sets of rings will set me back about £190.
https://farm1.staticflickr.com/899/27513616628_1ba44814f1_k.jpgUntitled by Kayak23, on Flickr
Measurements are as follows...
Cylinder 1
1st ring
Free end gap = 6.4mm
In Cyl gap = .406
2nd Ring
Free end gap = 7.76
In Cyl gap = .305
Cylinder 2
1st ring
Free end gap = 5.79mm
In Cyl gap = .406
2nd Ring
Free end gap = 7.95
In Cyl gap = .381
Cylinder 3
1st ring
Free end gap = 6.38mm
In Cyl gap = .406
2nd Ring
Free end gap = 8.38
In Cyl gap = .330
Cylinder 4
1st ring
Free end gap = 6.35mm
In Cyl gap = .406
2nd Ring
Free end gap = 8.35
In Cyl gap = .305
So, all of the rings are seemingly well within the end gap limit when inserted into the cylinders, but, most of them are over the limit when free.
Is it advisable to get new rings anyway, and if so, anyone know a good place to try to get them that might come out a little easier on the wallet!?
Cheers. |
Back to top |
fatjames |
fatjames World Chat Champion
Back to top |
Kayak23 |
Posted: 11:25 - 11 Apr 2018 Post subject: |
Cheers, yeah it's kind of the way I'm thinking given the cost. However, I sure as hell don't want to be stripping this thing down again in a few months! |
Back to top |
chris-red |
Posted: 11:59 - 11 Apr 2018 Post subject: |
If you've gone to the trouble and expense of tearing it apart that far you might as well do as much as you can. I would do the rings.
I'll also just leave this here...
https://tts-performance-parts.myshopify.com/products/suzuki-gsxr400-442cc-je-big-bore-piston-kit ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
Back to top |
Kayak23 |
Posted: 16:19 - 11 Apr 2018 Post subject: |
Very nice kit, but it only costs about a £100 than the bike cost me!
Back to top |
stinkwheel |
Posted: 17:08 - 11 Apr 2018 Post subject: |
I would also only be worrying about the end gap with them in the barrel. Assuming you don't break any putting them back in again, which would make the decision for you. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
A100man |
A100man World Chat Champion
Back to top |
Kayak23 |
Back to top |
steve the grease |
steve the grease Crazy Courier
Back to top |
rpsmith79 |
rpsmith79 World Chat Champion
Posted: 07:37 - 12 Apr 2018 Post subject: |
Funnily enough, i was just watching this the other day
Piston Ring Gap - the importance of:
https://www.youtube.com/watch?v=1-ujH65POaY ____________________ Current Bike: Honda CG125 ES4 // Honda CB600FS Hornet // Triumph Street Triple R |
Back to top |
The last post was made 6 years, 14 days ago. Instead of replying here, would creating a new thread be more useful? |
