Fuel draining from tank into crankcase
cornishman07
PostPosted: 07:52 - 24 Apr 2018    Post subject: Fuel draining from tank into crankcase Reply with quote
Hi all,
I’m hoping someone can give me some guidance on my '95 fzr600r 4jh foxeye. Fuel is draining from the tank into the crankcase contaminating the oil. I’m confident it’s not the carbs as I’ve taken them off and cleaned them. The jets are clear, the floats are clean and free, and there is no gunk or debris anywhere.
It has an in-tank fuel pump and from what I’ve found out it’s a simple pump that fills the floats on starting and pumps the bottom third or so of the tank as this is below the carbs. Most of the time gravity gets fuel to the carbs.
There’s no petcock or fuel tap to turn the fuel off so I’m assuming something should close inside the pump when the ignition is off and it isn’t doing? then gravity is pulling fuel out of the tank through the carbs and down the cylinders, into the crankcase.
I don’t know if it’s the pump itself or whatever controls the pump (relay or something?) that’s not working, or how to test which scenario it is.
Any help with a diagnosis or replacement part numbers (or compatible parts as it’s a 22 year old bike!) would be greatly appreciated.
Regards
Richard
Nobby the Bastard
Harley Gaydar
PostPosted: 09:20 - 24 Apr 2018    Post subject: Reply with quote
The only way fuel can get into the crank casing is via the carbs. Either the float height is wrong, the float(s) are punctured or the valve and/or seats in the carbs are worn.
Triumph Sprint ST 1050
jimspeed
PostPosted: 09:21 - 24 Apr 2018    Post subject: Reply with quote
It has to be either a float valve sticking allowing the fuel to siphon or the control relay for the pump sticking and letting the pump run with the engine off (if it has a relay).
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
temeluchus
PostPosted: 09:26 - 24 Apr 2018    Post subject: Reply with quote
in a bike of that age the primary suspect is the float valve needle and seat. They are wear items that need periodic replacement.
jaffa90
PostPosted: 10:26 - 24 Apr 2018    Post subject: Reply with quote
Has it got a vacuum pipe next to the fuel tank outlet pipe?
PostPosted: 10:29 - 24 Apr 2018    Post subject: Re: Fuel draining from tank into crankcase Reply with quote
That only leaves one option then, someone is pouring fuel into your oil filler cap while you aren't looking.
MCN
PostPosted: 11:06 - 24 Apr 2018    Post subject: Reply with quote
Are you sure?
The word siphon (/ˈsaɪfən/ SY-fən;[1] from Ancient Greek: σίφων "pipe, tube", also spelled syphon) is used to refer to a wide variety of devices that involve the flow of liquids through tubes. In a narrower sense, the word refers particularly to a tube in an inverted 'U' shape, which causes a liquid to flow upward, above the surface of a reservoir, with no pump, but powered by the fall of the liquid as it flows down the tube under the pull of gravity, then discharging at a level lower than the surface of the reservoir from which it came.
Very Happy
cornishman07
PostPosted: 13:19 - 24 Apr 2018    Post subject: Reply with quote
Cheers for the fast responses everyone. I don't really know how a carb works or how to check one is working properly I've already had them off and apart once to clean them but that's all I did. Are there any guides you guys would recommend? If I type this into YouTube there are hundreds but I have no idea who's giving good advice and who just likes filming themselves!!
skatefreak
PostPosted: 13:27 - 24 Apr 2018    Post subject: Reply with quote
Had this on a cbr6 f3.
Float bowl seal do-hicky wasn't sealing...
Upon removing the carbs I was greeted with an inlet full of fuel Rolling Eyes
Carbs off, cleaned them and all was fine.
cornishman07
PostPosted: 13:43 - 24 Apr 2018    Post subject: Re: Fuel draining from tank into crankcase Reply with quote
Ok, I'm not so confident now! They were clean at least! I'll read up on how they work and have another look.
temeluchus
PostPosted: 15:12 - 24 Apr 2018    Post subject: Reply with quote
https://www.cyclepedia.com/manuals/online/free/fuel-system/float-valve/
Good info here. It's not a hard job and only needs very basic tools, just be aware you'll be dealing with fuel.
I'd also rebuild or replace the fuel tap as well, as a precaution, whilst you have it apart.
https://www.fowlersparts.co.uk/parts/4125589/fzr600-fzr600rg-genesis-3hhe-1995-010-b/carburetor-for-usa
Genuine part numbers here and you can find pattern parts with several vendors.
jaffa90
PostPosted: 16:14 - 24 Apr 2018    Post subject: Re: Fuel draining from tank into crankcase Reply with quote
I'm not so confident now! They were clean at least! I'll read up on how they work and have another look.[/quote]
You no answer question!
PostPosted: 22:33 - 24 Apr 2018    Post subject: Reply with quote
As a 95 bike, it could well be ethanol in the fuel attacking your needle valves. I had a similar problem with a KLE500.
That kind of damage will look like white fur on the alloy of the needle valve and the end will look like it's been slighty nibbled. If this is the case, get some new viton tipped ones.
You can actually check if a duff needle valve/float is the problem too (but it is, can't be much else). It should be possible without removing the carbs from the bike. There will be a drain screw in each of your float bowls, when you loosen the screw, fuel will run out of a little spout in the bottom of the float bowl.
If you put a piece of clear hose on that little spout (other end open to air) then bend it up next to the carburettor body, when you open the drain screw, fuel will fill the hose to the same level it is sitting in the float bowl. In a normal carburettor, this will be slightly below the float bowl gasket. In one with a leaky needle valve, it will be the same as the level of fuel in the tank (ie, it'll piss out of the top of your bit of tube).
You could use this to test each carb, might only be one duff one.
jaffa90
PostPosted: 23:35 - 24 Apr 2018    Post subject: Reply with quote
It’s quite s job getting the bank of carbs off my YZF, due to the position. I’m a competent mechanic but still gave up until I bought a Haynes manual.
I wonder if the OP saying the carbs are clean is just looking down the intakes and not inside the float bowls?
They do not have a fuel tap. Reserve is via a sensor and physical pump switch.
Some models have a vacuum fuel tap, that`s why i`ve asked about the vacuum pipe.
cornishman07
PostPosted: 23:46 - 24 Apr 2018    Post subject: Reply with quote
I'll take the carbs off this weekend and check them properly this time. I feel like I know what to look for now.
I really do appreciate advice from those with the knowledge and are willing to take a minute to pass it on to someone they've never met! I'll let you know how I get on.
jaffa90
PostPosted: 00:32 - 25 Apr 2018    Post subject: Reply with quote
You can take a horse to water but you cannot make it drink it.!
PostPosted: 07:46 - 25 Apr 2018    Post subject: Re: Fuel draining from tank into crankcase Reply with quote
cornishman07 wrote:
Hi all,
Regards
Richard
Find this thing under the fuel tank. Take the small pipe off. If any amount of fuel comes out - buy this and fit it.
jaffa90
PostPosted: 10:28 - 25 Apr 2018    Post subject: Re: Fuel draining from tank into crankcase Reply with quote
Pete. wrote:
cornishman07 wrote:
Hi all,
Regards
Richard
Probably ignore your post as well.
cornishman07
PostPosted: 11:18 - 25 Apr 2018    Post subject: Re: Fuel draining from tank into crankcase Reply with quote
You no answer question![/quote]
Didn't realise I'd missed a question, what question?
cornishman07
PostPosted: 11:28 - 25 Apr 2018    Post subject: Reply with quote
Just read back all the posts, apologies I missed this, I'm looking on a phone and with all the quote boxes some single line posts are hard to distinguish! Not sure is the answer, I'll have a look when I get in from work tonight. I'm pretty sure it does as I had to remove two rubber hoses from the tank outlet manifold thing!
temeluchus
PostPosted: 12:10 - 25 Apr 2018    Post subject: Reply with quote
take a picture of it when you have it apart, easier that way.
cornishman07
PostPosted: 14:16 - 02 May 2018    Post subject: Reply with quote
A bit later than i expected but here are the pics
The last post was made 8 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.90 Sec - Server Load: 6.04 - MySQL Queries: 16 - Page Size: 143.31 Kb
