GY6 & derivatives, rebuild, gasket compound?
WmY
PostPosted: 17:30 - 24 May 2018    Post subject: GY6 & derivatives, rebuild, gasket compound? Reply with quote
I'm guessing that a very thin smear of non-setting compound, if there's any hint of problem with the mating surfaces would be useful, or nothing if the faces are OK (or it's the cylinder head gasket!). Nothing on the belt drive cover (unless it's a little grease to assist subsequent disassembly).
Any advice?
Nobby the Bastard
Harley Gaydar
PostPosted: 18:09 - 24 May 2018    Post subject: Re: GY6 & derivatives, rebuild, gasket compound? Reply with quote
WmY wrote:
Any advice?
Yes, give us a make and model or gtfo
Triumph Sprint ST 1050
wr6133
PostPosted: 20:26 - 24 May 2018    Post subject: Reply with quote
A gy6 complete gasket set is circa £5...... why spend more on paste?
WmY
PostPosted: 21:33 - 24 May 2018    Post subject: Re: GY6 & derivatives, rebuild, gasket compound? Reply with quote
Nobby the Bastard wrote:
WmY wrote:
Any advice?
OK nobby you win.
WmY
PostPosted: 21:36 - 24 May 2018    Post subject: Reply with quote
I've got a gasket set. I'd hoped for an answer to the question....
WmY
PostPosted: 21:55 - 26 May 2018    Post subject: Reply with quote
Observation: The manufacturer uses a small spot of grey RTV on the crankcase gasket where joint meets the cylinder base gasket.
MCN
PostPosted: 05:57 - 27 May 2018    Post subject: Reply with quote
Additional sealing compounds are used to assist assembly by keeping the gasket in position. I would stick any gasket to the part that is easiest to get the gasket off again.
Normally it is either gasket or a sealant/paste and not both as the sealant can affect the properties of the gasket material.
If an old gasket is all that is available the. Using a compound is better than nothing.
Some gaskets can be eliminated by using certain compounds.
RTF silicone is popular but is not at all any sort of panacea.
Look for 3M or Loctite products if you need reliable performance.
And if using any compound all surfaces must be spotless. No oil or grease.
rhys99
PostPosted: 11:24 - 27 May 2018    Post subject: Reply with quote
I always thought this too, however recently when rebuilding a Ducati monster engine it clearly states in the service manual to use sealant on the base and head gaskets
21:16:02 Fin: I got a girl to believe I have a huge dick today, she's going to be so disappointed
K̶5̶ ̶S̶V̶6̶5̶0̶S̶ K3 SV650N
The last post was made 8 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.09 - MySQL Queries: 16 - Page Size: 63.76 Kb
