Fuel pump issues...
dextersaurus
PostPosted: 16:54 - 27 May 2018    Post subject: Fuel pump issues... Reply with quote
Hi folks.
Wondering if anyone knows how the hell this fuel pump is supposed to be wired.
I've got a black/blue wire and a green wire. Bl/b one goes from the connector into the pump.
The green wire bolts to the housing as you can see. The issue is that there's a clear wire not connected to anything that has continuity from the connector at the bl/b wire.
Can't figure it out and the other pump is totally knackered...
Help!
Nobby the Bastard
Harley Gaydar
PostPosted: 18:00 - 27 May 2018    Post subject: Reply with quote
It looks like it's supposed to be connected to the central pin
Triumph Sprint ST 1050
dextersaurus
PostPosted: 18:20 - 27 May 2018    Post subject: Reply with quote
The central pin spins apparently - at least it does by hand. Couldn't see anywhere that it could have been soldered to...
And if I do connect it, It shorts out since the casing is bolted to the earth wire.
Probably worth noting that the clear wire does appear to be powered
sickpup
Old Timer
PostPosted: 19:00 - 27 May 2018    Post subject: Re: Fuel pump issues... Reply with quote
Mr Dunkable wrote:
Hi folks.
Help!
Its a 2 wire diaphram fuel pump.
The following is a guess but probably accurate.
At some point the points inside have been replaced and someones soldered in a new wire, so ignore the clear bit of cable.
Chances are the points need replacing again.
The shaft when the pump works will go in and out not spin although it is free to rotate.
So, check the points they will be worn out, replace.
The last post was made 8 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 40.58 Kb
