Author |
Dave70 |
Dave70 World Chat Champion
Posted: 18:39 - 13 Jun 2018 Post subject: Replacing Coolant Reservoir er6f. |
It turns out that the coolant reservoir on my er6f has cracked and I'm ordering a new one tomorrow and replacing it myself.
Seeing as I'm a mechanical noob, is it a simple as taking off the old one, fitting the new one, reconnecting the hoses and filling it up with coolant between the min-max levels or is there anything else I'd need to do? Will I need to bleed/flush it through the radiator for example?
All advice appreciated as I know nothing. ____________________ There ain't no devil, there's just god when he's drunk.
2012: R125 killed by white van. 2016 R125 killed by 30,000 miles of redline. Current: 2016 Kawasaki ER6f. |
Back to top |
RhynoCZ |
RhynoCZ Super Spammer
Posted: 18:53 - 13 Jun 2018 Post subject: |
Yes, as simple as that.
Once you replace the reservoir, you're going to have to bleed the system. That's pretty simple as well, just let the engine run with the filler cap off for a while. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
Back to top |
Dave70 |
Posted: 18:54 - 13 Jun 2018 Post subject: |
Appreciated.
Thanks. ____________________ There ain't no devil, there's just god when he's drunk.
Back to top |
Dave70 |
Posted: 19:08 - 13 Jun 2018 Post subject: |
Good call.
I'll check out some you tube vids.
I was just going to fill it from the cap on top of the bottle.
EDIT: Your other post's vanished. ____________________ There ain't no devil, there's just god when he's drunk.
Back to top |
RhynoCZ |
Posted: 19:13 - 13 Jun 2018 Post subject: |
Yes, I was not sure if it was ER6, so I removed the post.
Either way, you always bleed cooling systems (and brakes as well, notice where the bleed nipples are on the calipers) at the highest point. On some motorcycles the highest point is the reservoir, on other bikes it's not and there tends to be an extra cap either on the radiator or elsewhere.
EDIT: After you bleed the cooling system, check the coolant level again. It will drop once there's no air in the system. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Back to top |
Rogerborg |
Rogerborg nimbA
Posted: 20:06 - 13 Jun 2018 Post subject: |
RhynoCZ wrote: | Either way, you always bleed cooling systems (and brakes as well, notice where the bleed nipples are on the calipers) at the highest point. |
Points, plural. Some bikes have bleed points within the system. For once, it really is a case of RTFM. ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
The last post was made 5 years, 316 days ago. Instead of replying here, would creating a new thread be more useful? |
