Slight tyre difference
A100man
PostPosted: 23:11 - 12 Jun 2018    Post subject: Slight tyre difference Reply with quote
I'm about to change the perished Avon roadrider (130/80 r18) on my old FZ750 for a lower profile Michelin pilot activ 130/70 r18. Apart from a slight gearing change am I likely to notice any difference?
jaffa90
PostPosted: 23:45 - 12 Jun 2018    Post subject: Reply with quote
Going from a 104mm side wall tyre to a 91mm side wall tyre will make your bike more rapid Shocked
If not declared to your ins com as a modified bike you may be hung drawn and quartered or sent to prison.
weasley
PostPosted: 13:11 - 13 Jun 2018    Post subject: Reply with quote
Theoretically:
The 12.5% gearing change will lead to a 12.5% reduction in speed for a given engine revs, so you'll need to rev higher to achieve the same road speed. This will also reduce fuel economy, both because the gearing has reduced and because you'll probably ride at higher revs more of the time.
It will lower the rear of the bike by 13mm, which will slacken the steering geometry by increasing the rake and trail. It will reduce ground clearance and maximum lean angle. It will sit more upright on the side stand. Your headlight aim will be too high. All of this might be offset somewhat if you are able to increase the preload on the rear spring (but this might then set your sag at the wrong position).
Acceleration will improve, at the expense of top speed. You may find handling changes, due to the change in profile of the rear tyre and how it drops into and holds a lean angle.
Theoretically.
PostPosted: 14:57 - 13 Jun 2018    Post subject: Reply with quote
Remember both of these are bias belt tyres.
A100man
PostPosted: 15:08 - 13 Jun 2018    Post subject: Reply with quote
weasley wrote:
Theoretically:
The 12.5% gearing change will lead to a 12.5% reduction in speed for a given engine revs, so you'll need to rev higher to achieve the same road speed. This will also reduce fuel economy, both because the gearing has reduced and because you'll probably ride at higher revs more of the time..
I think it's only about 4% difference one you add in the wheel not just the sidewall ..
Bias belt? Is that bad??
PostPosted: 15:12 - 13 Jun 2018    Post subject: Reply with quote
No, but you'd have to be careful if you were fitting tyres of different makes. You can't have a radial on the rear and a bias belt on the front.
A100man
PostPosted: 15:34 - 13 Jun 2018    Post subject: Reply with quote
Hmm BT45 up front which i think is the same type.
PostPosted: 16:06 - 13 Jun 2018    Post subject: Reply with quote
Yes. They are also bias belt so that's fine.
Oh, and my earlier statement is backwartds. You're not allowed a radial front with a bias belt rear. The other way round is ok.
weasley
PostPosted: 07:59 - 14 Jun 2018    Post subject: Reply with quote
Of course it is. Doh! Same applies, just not as big.
A100man
PostPosted: 09:21 - 14 Jun 2018    Post subject: Reply with quote
Thanks all - I'll press on with it and let you know how it goes..
Cheers
J
The last post was made 5 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 17 - Page Size: 67.55 Kb
