Soldering micro USB contacts.
WmY
PostPosted: 12:35 - 14 Jun 2018    Post subject: Soldering micro USB contacts. Reply with quote
My phone (a "Ulefone" Gemini) was charging only intermittently, then not ay all (yesterday). So, I got the back off, which was not very easy, as they're not supposed to be taken apart by users (Ha! A direct challenge!), and I saw that the five contacts on the USB socket were flapping about in the breeze; they should be soldered down. A give-away should have been that the "tongue" in the port was loose.
Anyway, I had a go with my 25W spade-bit, and it's working again, but I don't trust the soldering, as the joints are too small to see easily.
Is there an easy way to fix such things? The Internet shows people with expensive magnifying kit and special hot air blowers and suchlike. It would be cheaper to buy a new board than that! However, I do like fixing things....
PostPosted: 21:06 - 14 Jun 2018    Post subject: Reply with quote
Get another phone and zoom in on the contacts you have soldered. You'll be able to see how good (or bad) the solder joints are.
woo
PostPosted: 09:31 - 15 Jun 2018    Post subject: Reply with quote
get a new different phone
may look all fine but one day when charging it may catch fire, not worth the heat in my opinion lol!
Elen sila lummen omentielvo!
The Artist
PostPosted: 09:38 - 15 Jun 2018    Post subject: Reply with quote
Unlikely to be a fire. It the joint gets hot, it will just melt most likely.
Small SM components are normally soldered using one of many methods that don't involve a hand held soldering iron but it can be done, it just won't be easy or reliable.
You would probably need a pointed tip but hard to say without pics.
WD Forte
PostPosted: 12:45 - 15 Jun 2018    Post subject: Reply with quote
I've done similar crude but effective bodges but at least I used a 1mm tapered tip and wick.
Now I use a SMD hot air station and solder paste, it's not in daily use
but very handy to have at times.
bikers smell of wee
WmY
PostPosted: 22:56 - 15 Jun 2018    Post subject: Reply with quote
Good man!
My spade bit was at least very worn (like a "blunt" screwdriver (which is in fact sharp!). A bit like a gimlet, if you happen to know what one of those is.
Anyway, I've ordered a new USB socket/card, from China (AliExpress), for the princely sum of £6.11 (delivered in about 3 weeks). When it comes I'll fit that. In the meantime, I use "Super Saver", a power reduction feature, and plug it in most carefully to charge, retaining my mum's Dorophone as backup.... Smile
WmY
PostPosted: 00:12 - 20 Jun 2018    Post subject: Reply with quote
The 'phone still charges. Looking at it through a 60x "pocket microscope" shows it looks OK, no bridging, but just in case the solder's weak I have ordered a new board via "Aliexpress". In fact, I've ordered two, from different suppliers, to see which courier wins (and just in case one's wrong!).
If both boards are correct, I'll sell the other on and keep the repaired one as a spare JIC.
dydey90
PostPosted: 08:35 - 20 Jun 2018    Post subject: Reply with quote
The phone is £80 new, this seems like a lot of work to be going through.
WmY
PostPosted: 16:51 - 20 Jun 2018    Post subject: Reply with quote
So I spend £7.60 for two cards and have my 'phone working again, and have a bit of fun, instead of spending £80 on a "new" one with an outdated Android version. Sounds like a good deal to me.
WmY
PostPosted: 12:27 - 27 Jun 2018    Post subject: Reply with quote
Excellent! Ordered from AliExpress standard delivery 16/Jun, arrived 25th. Fitted & working! Not sure all deliveries will be that fast, though, the other one hasn't arrived & AliExpress standard delivery is said to be 20-40 days...
The last post was made 5 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 17 - Page Size: 66.7 Kb
