What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 313, 314, 315 ... 407, 408, 409  Next
groovylee
PostPosted: 06:45 - 21 Jun 2018    Post subject: Reply with quote
bacon wrote:
groovylee wrote:
not today, but last week.
crashed it. Thumbs Down
not too bad thankfully, low speed corner, too much throttle, front washed out and down I went.
just totting up the cost of bits now Shocked
Unlucky..... How's the injuries or did you get away fairly scathe free?
ok thanks mate, just a sore hip. damage to the bike isn't too bad, I reckon she'll be good as new for under £400 Thumbs Up
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
Dave70
PostPosted: 17:46 - 21 Jun 2018    Post subject: Reply with quote
Collected the new coolant reservoir from the dealers today and fitted it this afternoon. Turns out the original one had more than a crack in it. Shocked
https://preview.ibb.co/hhwWH8/20180621_171851.jpg
What an absolute ball ache of a job it was to get to though. This is the first time I've removed the fairings on the er6f (2015 model). To remove the right side fairing, which is needed to gain access to the reservoir, it turns out that you have to remove the windscreen, then the windscreen mounts and various other pieces of plastic above the nose cone and around the dash, then unbolt the speedo and remove it and locate multiple pop rivets before you can gain full access to it.
Replacing the reservoir and re-filling it took about 5 mins at most. Dismantling and putting back together took about 2 f'king hours. Much profanity was also used.
Gonna buy a naked bike next time. Mad
Courier265
PostPosted: 21:23 - 21 Jun 2018    Post subject: Reply with quote
adjusted the chain on my Suzuki for the first time, 2 full turns needed.
not bad considering I bought the bike with 1100 miles on it...( over a year ago)
thx1138
PostPosted: 21:54 - 21 Jun 2018    Post subject: Reply with quote
Commuted to work on my beta cross trainer, rode round and round all the cones in the carpark really very slowly standing up, just because I could
Topped up the 2t oil, filled it up with fuel, cable tied more broken plastics. Must get around to replacing plastics.
sickpup
Old Timer
PostPosted: 23:06 - 21 Jun 2018    Post subject: Reply with quote
59 Plate Deauville
Unseized centre stand, removed, cleaned up, greased and refitted.
Exhaust silencer removed.
More parts ordered.
sickpup
Old Timer
PostPosted: 23:47 - 22 Jun 2018    Post subject: Reply with quote
09 Plate Deauville
Front pads changed.
<edit>Day later rear pads changed.</edit>
Courier265
PostPosted: 15:28 - 23 Jun 2018    Post subject: Reply with quote
CBF500 new front brake pads....I was 100 percent wrong about the
pads, they were not uneven at all plus I could of got another 2000
miles out of them. Oh Had the oil changed while it was on the bench.
Hawkeye1250FA
PostPosted: 15:34 - 23 Jun 2018    Post subject: Reply with quote
Chain replaced on the rf.
Regreased a lot of moving parts.
Fitted trickle charger and new battery
Oil and filter tomorrow.
I need to find someone with pretty much the entire tail fairing for sale or I'm going to have to get inventive with 3D printing for the broken bit where the indicator attaches.
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
recman
PostPosted: 17:56 - 23 Jun 2018    Post subject: Reply with quote
So, got it on. Bit of ingenuity required.
I rather like it.
https://s15.postimg.cc/625f1fadn/20180623_143207.jpg
https://s15.postimg.cc/pwrgnphx7/20180623_173056.jpg
https://s15.postimg.cc/v86d8j6ln/20180623_173349.jpg
Islander
PostPosted: 22:27 - 23 Jun 2018    Post subject: Reply with quote
Replaced the rear wheel bearings on the M900, sorted out an ignition problem on the M750 (turned out that a new spark plug was a dud) and changed oil and filter on the Bandit 1200.
PostPosted: 22:37 - 23 Jun 2018    Post subject: Reply with quote
Fitted a Sigma BC 5.16 bicycle speedo, so I can have a trip counter and a clock. Apparently it's good to 125mph Smile
https://www.amazon.co.uk/dp/B000KC2402
Fin
PostPosted: 23:19 - 23 Jun 2018    Post subject: Reply with quote
Bodged in a switch for the fan as it never seemed to come on.
you'd all be horrified if you saw beneath the tape.
https://i.imgur.com/jT6cyZg.jpg
I'll see how it holds up tomorrow.
pompousporcup...
PostPosted: 08:53 - 25 Jun 2018    Post subject: Reply with quote
picked up and fitted another engine to the gpz900r. ran it for 10 seconds to confirm it was worth continuing.
adjusted chain and changed all fluids during reassembly.
Still quite a few things to do before replacing cam chain and guides
Courier265
PostPosted: 11:11 - 25 Jun 2018    Post subject: Reply with quote
Changed the clutch cable on my Inazuma 250, the old one felt so stiff
and was really pissing me off. Fitting the new cable wasn't easy due to
having to deal with a split pin and not much room to get the bugger
out. (engine connection)
Routing the cable was the easy part, after fitting I adjusted the cable
properly and it feels so smooth which means I got the routing spot on.
I did this little job in the shade but it didn't stop the sweat dropping from
my face, boy is it hot today.....
The only downside to the job was that I re-used the same split pin so I
have ordered some baby R clips to replace.
Wheezybiker
PostPosted: 13:07 - 25 Jun 2018    Post subject: Reply with quote
Waiting for my bike to have its 12000 service plus extras done
They gave me an mt07 demo bike whilst I wait
Not overly impressed with it
Seat is very hard
Feels very vibey when riding compared to my xj6n
The instrument panel is better laid out built in gear indicator Eco mode etc
Slightly better riding position narrower lower handlebars feels good very exposed riding without any screen at all
Can't wait to get mine back
Wheezybiker
PostPosted: 17:55 - 25 Jun 2018    Post subject: Reply with quote
It passed mot
All good for another year
service complete plugs oil and air filter plus coolant change as well
Fisty
PostPosted: 23:43 - 27 Jun 2018    Post subject: Reply with quote
Lent the TL to FretGrinder.
Then we went drag racing. A thoroughly enjoyable way to spend an evening.
https://i.imgur.com/wadEtoa.jpg?1
Fatter and faster than Fret
Tdibs
PostPosted: 12:11 - 28 Jun 2018    Post subject: Reply with quote
That looks like some bloody fun! Does the TL keep up close with the busa?
FretGrinder
PostPosted: 14:55 - 28 Jun 2018    Post subject: Reply with quote
It suspect it might if someone other than me is riding it Laughing
It was a proper good evening, lots of bikes, lots of noise and I had a fantastic time riding both the TL and the Busa for the first time ever.
I'm not sure if I had more fun on the runway, or the 90 mile round trip that I did on the TL on the roads to the airfield, with it's monstrously loud Yoshimura exhausts.
Yamaha MT-09
ಠ_ಠ
johnsmith222
PostPosted: 15:37 - 28 Jun 2018    Post subject: Reply with quote
I keep thinking about changing my 9R for a hayabusa, and your photo isn't helping things! Thumbs Up
Latitude
PostPosted: 22:05 - 28 Jun 2018    Post subject: Reply with quote
Took the old ZX6R J2 for a front fork and rear shock service. Thumbs Up Wheels powered coated and new hoops next on the list.
PostPosted: 22:16 - 28 Jun 2018    Post subject: Reply with quote
New topbox and tool roll fitted, in time for the weekend's bimble around the Peak District Smile
https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/36294316_10156486141201484_4535163140165337088_n.jpg?_nc_cat=0&_nc_eui2=AeHskRFISK9loE76MRm-C1C0S7LblTzgQF7Er59v2KP9JwwOtH3JQ5Uvv26VxiF0GBk7r9UbGC4dMYjsYBdUCGgdJmbF6Oj8CDmQ47fomBL4Tw&oh=06f5270e704594e714845d66351dbec0&oe=5BB53166
Howling Terror
PostPosted: 22:19 - 28 Jun 2018    Post subject: Reply with quote
^^^Want a pitstop gimme a PM.
PostPosted: 22:44 - 28 Jun 2018    Post subject: Reply with quote
The Shaggy D.A. wrote:
Isn't that tool roll going to foul on the front mudguard under heavy brakin-
Oh, as you were.
PostPosted: 22:50 - 28 Jun 2018    Post subject: Reply with quote
Oh, as you were.
Smile
It's higher than it looks in that piccy, and if I find it bounces I'll just tighten the extra zipties I added Smile
https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/36306542_10156486141216484_7114372670216470528_n.jpg?_nc_cat=0&_nc_eui2=AeEWsH0QDRSb7kHlPe4SAFifp7jWuz2Sn1MXggySzRu_KsE8E7YK4zJlFy8v_DeQJZRo1zjWxKMwvs9whLo9j9uPk0v--hGfubDBAaYFJYAcOQ&oh=fecc2ba5327373a2b2b0ebd559ee3338&oe=5BB3739B
The last post was made 5 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 314 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.56 - MySQL Queries: 17 - Page Size: 138.57 Kb
