Author |
WmY |
WmY Renault 5 Driver
Back to top |
Radioactive Shock Therapy |
Radioactive Shock Therapy L Plate Warrior
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
ThatDippyTwat |
ThatDippyTwat World Chat Champion
Back to top |
WmY |
Back to top |
WD Forte |
WD Forte World Chat Champion
Back to top |
jaffa90 |
Back to top |
stinkwheel |
Posted: 01:36 - 24 Jun 2018 Post subject: |
It's very common to break the lock-stop when someone steals a bike by percussively breaking the steering lock and is why I never use such things.
Have you priced up a used replacement bottom yoke? May not be as much as you'd imagine. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Dave70 |
Dave70 World Chat Champion
Back to top |
Chuffin Nora |
Chuffin Nora World Chat Champion
Posted: 12:35 - 24 Jun 2018 Post subject: |
Look on the bright side.
You've a great chance to out-odd jaffa90's 45 odd years of riding by simply turning the 'bars 180° and riding the bike backwards!
Don't forget to cross your arms, though, otherwise -- what with the controls being all arse-about-face -- things might get a tad confusing, if not somewhat dangerous.
Hey! No more need for shoulder checks!
HTH ____________________ There's a fine line between integrity |
Back to top |
Polarbear |
Polarbear Super Spammer
Back to top |
Tankie |
Tankie Crazy Courier
Back to top |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 14:36 - 24 Jun 2018 Post subject: |
MOT rules basically say that the handlebars shouldn't touch anything or trap fingers at the extremes of steering; lock-stops should limit travel to prevent this.
Common for stops to get broken on theft attempts or when bike dropped....
On which basis, I would be more concerned WHY the lock-stop's broke, to begin with, than wangling it through an MOT... it may be the least of your worries if the frame or forks are bent from a drop, or the twockers come back.....
What bike though would definitely help with fix suggestions; different bikes have differnt lock-stop arrangements... may be possible to add something to the other mating lock-stop on the frame, to limit travel both ways;
Personally, I wouldn't even dream of trying to re-make lugg on bottom yoke.
It could be done with aly braze suych as lumiweld, or MIG, but the amount of metal I would imagine would need laying on, be easier to weld something, like a bolt in place than build that amount of metal up in weld...
Then given burning out the headrace bearing grease, and probability of burning wiring looms going throuygh that area? It would be something I WOULDN'T tackle with the broken yoke still on the bike....
Given you would have to take off the broken yoke... why not just replace it with one from a breakers or brand new! Its probably just as onerouse and no more expensive than taking the chance on welding or brazing.
To do in situe, and save taking apart or buying new bits.... I rather like my tap and die set... so drilling to take an M8 and tapping the hole tight would, likely be my preferred method of salvage.
But depends on what bike, and how much guff is around the yoke, and how hard it is to come by a new one, and how expensive etc....
Tell us the bike! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Back to top |
WmY |
Back to top |
P. |
P. Red Rocket
Back to top |
WmY |
Back to top |
Evil Hans |
Evil Hans World Chat Champion
Back to top |
jaffa90 |
Posted: 11:53 - 25 Jun 2018 Post subject: |
Chuffin Nora wrote: | Look on the bright side.
HTH |
I have never used the turn a key steering lock which means no breakages. |
Back to top |
Tankie |
Back to top |
stinkwheel |
Posted: 15:13 - 25 Jun 2018 Post subject: |
I'd just drill down into the hole where it broke off, tap it and fit a socket head cap screw in there with loctite (probably an M6). The head of the capscrew should act as a lockstop. Use a good quality mild steel one, not stainless.
If the hole goes all the way through (tricky to see on the pictures) then a nylok nut on the back of it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Ste |
Ste Not Work Safe
Back to top |
The last post was made 5 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
