Cheap way to make bike hard to steal?
adam277
PostPosted: 21:59 - 24 Jun 2018    Post subject: Cheap way to make bike hard to steal? Reply with quote
I'm getting a bike this week so I was hoping on advice to keep it secure.
My plan is DISC LOCK - £10
Chunky Chain - £30? - I'd like a recommendation on this because everytime I buy a chain in the past the key gradually gets worn out which causes issue.
Ground Anchor cemented into the ground - £20-30
That is my plan so far I don't really want to go over £100.
For practical reasons I have to park my bike on the drive so people will be able to see it, so it has to be somewhat secure.
I'm also reluctant to get an alarmed disk lock (think i may have one lying about somewhere) as they can be a bit to temperamental.
Edit: My bike is going to be worth about £1000 if that helps.
Bikes: Previous Bikes: Piaggio x8 125: 2012/2013, YBR 125: 2013/2013 BMW R1150GS 2013/2017, Honda CBR600RR 2017/2017, Honda CB500 2018/2018, Suzuiki Address 110cc 2019/2020, BMW R1200GS 2021-2023
Current Bike: Honda CBF 125: current
PostPosted: 22:06 - 24 Jun 2018    Post subject: Reply with quote
What bike and where in the UK?
An Almax chain or Pragmasis chain is over budget but is a good investment.
NJD
PostPosted: 22:12 - 24 Jun 2018    Post subject: Reply with quote
Might want to update signature or tell us what bike then because..
adam277 wrote:
Current Bike: NONE :Sad: Working towards a newish R1200GS stallion
..is a bit more than £1000; unless you buy part of it, that is.
Alarmed disc locks, from what I've read on here, at pointless because cry wolf situation -- in as much as how many times do you jump up the window to a non existent thread before giving up and a real one occurs; and even then what do you really do?
Owning a £1000 bike, though, and only allotting £100 to secure it is pretty pointless; might as well get yourself a lock from poundland and have done with it.
Disc locks are better used on the rear sprocket, or disc, because the front can be lifted and the rear wheel will roll when pushed forward; often used to put bikes into vans; or go with both, if you've got the time.
Ground anchor's a good idea; any one is better than nothing I'd imagine.
Chain usually Almax or Pragmasis here; you won't find them anywhere but online.
You'll want a cover, too; and luggage to carry the chains around with you, too.
adam277
PostPosted: 22:26 - 24 Jun 2018    Post subject: Reply with quote
I haven't got the bike yet but either a ybr or cb500 or similar basically a cheap hack.
How much do you think I should spend on security?
PostPosted: 22:28 - 24 Jun 2018    Post subject: Reply with quote
Where in the UK are you?
NJD
PostPosted: 22:31 - 24 Jun 2018    Post subject: Reply with quote
City, or region, if you're not particularly feeling ready to invite all us for a BBQ in your front garden yet.
adam277
PostPosted: 22:36 - 24 Jun 2018    Post subject: Reply with quote
Basildon essex
PostPosted: 22:42 - 24 Jun 2018    Post subject: Reply with quote
19mm+ Almax or Pragmasis chain with a squire lock and an appropriate ground anchor. It's enough to put off tooled up opportunists who haven't got angle grinders. I'd hope that those with angle grinders will have their sights set on more valuable bikes than yours.
The security is an investment.
johnsmith222
PostPosted: 00:22 - 25 Jun 2018    Post subject: Reply with quote
I would get:
Kryptonite new york disc lock £40 x 2 (front disc and rear sprocket)
Almax series 3 16mm chain and squire padlock (£150ish) (a series 4 or bigger would be better for Essex I would think though).
A bike cover.
A £10 disc lock isn't going to cut it unfortunately. The only time I support a disc lock that cheap, is if it's the only one that will fit (like the xena x2 on my rear disc. (but I also lock the rear sprocket)
It might seem overkill, but it means they need to make a fair few cuts before it's ridable. Even if you have a grinder or 3, why do that when you can lift the other bikes that are about?
stevo as b4
PostPosted: 00:47 - 25 Jun 2018    Post subject: Reply with quote
Either a fuck off loud alarm that goes off if your bike is moved a mm, in the hope it scares away the thief or if not gives you time to wake up and tool up.
Or you could go the other way with a silent alarm/baby monitor if your feeling wide awake and ready at all times (but mostly night) to go out all stealthy and sneek up on your bikes attackers.
If neither of the above sound plausible or ideal for you, then your better off booby trapping the bike every night or rigging up a folding electric fence connected to a mains supply.
Only real way to prevent someone taking your bike away if they really want it is the 3 'D's
1, Disarm
2, Disable
3, De-motivate
You could add De-cappitate to this, but I don't think you'll get away with chopping up too many theives before you get caught and sentenced to a good long stretch. If going this route I'd suggest being as brutal and savage as your imagination will allow, as if your going to get put away in a cell, you might as well go down being known as a right fucking animal not an accidental murderer. Wink
adam277
PostPosted: 01:02 - 25 Jun 2018    Post subject: Reply with quote
I get the logic in buying expensive chains as you can use them once you get a more expensive bike.
I cant justify the cost of £250+ though upfront. If they want it bad enough they can have it. My job is just to make my bike more hassle then someone else's.
Also double disclock? I did that before along with a chain and it got tedious fast. Especially when your doing it 3/4 times a day.
So basically it's get a big Fuck off chain or don't bother?
I mean this is potentially a rusty ybr that's been dropped a few times we are talking about not a fireblade.
mentalboy
PostPosted: 01:21 - 25 Jun 2018    Post subject: Reply with quote
adam277 wrote:
Basildon essex
Sounds like good grounds for an annual bus pass.
Make mine a Corona.
johnsmith222
PostPosted: 03:12 - 25 Jun 2018    Post subject: Reply with quote
It's really up to you and I guess that's why you pay insurance. 2 disc locks is definitely a hassle, but it is to prevent the bike being wheeled away on the back wheel. It also means they have to break locks, rather than just unbolting a front brake disc until they get it away.
If you get one thing though, a chain is probably your best option. Pragmasis do a 13mm chain for £63 at 1.5m, but you also have to buy a padlock. Probably a false economy though, as might as well go for a 16mm one.
c_dug
PostPosted: 06:45 - 25 Jun 2018    Post subject: Reply with quote
I'd have a single 16mm+ chain from Almax (or Pragmasis) on it's own over a cheap disc lock and chain from, say, Oxford. In fact that's exactly what I did.
My logic is that you can get a cheap chain off with croppers, and many disc locks off with levers or hammers. I've done both for legitimate reasons before. Both can be done fairly quickly, but also near silently.
Nobody is getting through an Almax without an angle grinder. That's like having an alarm that only ever goes off when it's a legitimate theft attempt.
You can always add more security at a later date. I've now got a cheap alarmed lock through my sprocket, just as a visual deterrent really (I don't think there's a battery in the alarm). This is on a bike I never ride though, so multiple locks isn't so much an issue for me. I'd lose patience if I ever ride it regularly again and would resort back to chain alone.
PostPosted: 09:30 - 25 Jun 2018    Post subject: Reply with quote
Buy a couple of metres of 16mm (or larger) anchor or lift chain. Much cheaper than Almax or Pragmasis, probably not croppable, will take a few seconds less to go through with an angle grinder. A patient and industrious person could probably hacksaw through it, which rules out that method for pikies.
Spend the savings on a crossbow. They were coming right for you.
If you're not prepared to murderkill a pikey, what do you imagine you'll do during the extra few seconds that an Almax or Pragmassis will give you? Fvcks given by tooled up career pikies are approaching zero.
BusterGonads
PostPosted: 09:48 - 25 Jun 2018    Post subject: Reply with quote
1, Disarm
2, Disable
3, De-motivate
This is what is wrong with our country. We are expected to act like sheep and run away from people who attack us or take our valuables. If we don't do that, we will very likely find ourselves in more trouble than the animals who prey on the decent citizens. The justification for this is that the police will protect the citizenry and that all force is in the hands of the state. The problem is - that's all a big lie. The police will not protect you or even investigate your loss and they use no force unless you are roaming about with a gun in public. Moped criminals only have to take off their helmets to be given a free pass and when they do, pursuing police desist from following them in case the poor little fellahs get hurt. In fact, they should be riding them down and running over them repeatedly. Then they would be doing their job of preventing crime and disorder and protecting the respectable public.
Wheezybiker
PostPosted: 13:16 - 25 Jun 2018    Post subject: Reply with quote
Not as tedious as walking in motorbike gear as some fcuker has stolen your bike.
I have a 16mm chain and a disclock which are used every time I lock the bike when away from home
At home 16mm chain and disc lock and 1 10mm chain and disc lock plus 2 ground anchors and a cover.
Drive blocked off with sons car
Unlocking chains and locks takes a few seconds each just have to plan journeys and factor in slightly extra time needed
If they want my bike they are gonna have to work for it
PostPosted: 14:22 - 25 Jun 2018    Post subject: Reply with quote
In Trowbridge, you're allowed to kill someone who tries to rob you.
https://www.wiltshiretimes.co.uk/news/15547400.Jury_clears_Hayden_Maslen_of_Jordan_Taylor_murder/
He did however get 20 months for possession of a knife in public.
https://www.wiltshiretimes.co.uk/news/15549832.Hayden_Maslen_jailed_for_having_knife_in_fatal_brawl/
arry
PostPosted: 15:31 - 25 Jun 2018    Post subject: Reply with quote
adam277 wrote:
Basildon essex
Good luck Laughing
You'll need more than thirty quids worth of chain.
RhynoCZ
PostPosted: 16:05 - 25 Jun 2018    Post subject: Reply with quote
Paint it all bright pink.
PostPosted: 17:23 - 25 Jun 2018    Post subject: Reply with quote
Essex? I thought it mostly was.
Jmoan
PostPosted: 18:34 - 25 Jun 2018    Post subject: Reply with quote
This is what is wrong with our country. We are expected to act like sheep and run away from people who attack us or take our valuables. If we don't do that, we will very likely find ourselves in more trouble than the animals who prey on the decent citizens. The justification for this is that the police will protect the citizenry and that all force is in the hands of the state. The problem is - that's all a big lie. The police will not protect you or even investigate your loss and they use no force unless you are roaming about with an air toy gun in public your garden. Moped criminals only have to take off their helmets to be given a free pass and when they do, pursuing police desist from following them in case the poor little fellahs get hurt because lazyness or politics. In fact, they should be riding them down and running over them repeatedly. Then they would be doing their job of preventing crime and disorder and protecting the respectable public.
Fixed.
Vracktal
PostPosted: 20:46 - 25 Jun 2018    Post subject: Reply with quote
This was put to Facebook a while ago - re-using an Abus car steering lock through the rear sprocket of a motorbike
https://scontent-lhr3-1.xx.fbcdn.net/v/t1.0-9/35481893_2074432772804259_528504603470200832_n.jpg?_nc_cat=0&_nc_eui2=AeFBU4NKZr_A8DBKvr9yCyEcDdi51stAAuOQQLVLxO2VZKwEKyHwVZQrxXPoyt9CWSm2j7Riz9TTSNXdvHTl8bBaEb_k7alimbptgTzzT0uP9w&oh=fa6ff75cebde33bd0fb697e67f0ca154&oe=5BA5876C
Bit of research suggests it's called an Abus Carblock 73.
https://img.tradera.net/images/142/274724142_5e99dfa4-4ee1-4f39-a7b8-161c9c1db433.jpg
The two loops just happen to line up with the holes in his sprocket though, so I imagine it won't work for every bike. I'd probably turn it the other way as well, so the handle couldn't be used as a lever but on the face of it it seems like a good idea.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
stevo as b4
PostPosted: 20:56 - 25 Jun 2018    Post subject: Reply with quote
Ingenious, but IMHO I don't see what (access permitting) that a D-lock through the Swingarm and a rear wheel spoke does not do better?
PostPosted: 21:25 - 25 Jun 2018    Post subject: Reply with quote
I'd say a D lock is easier to crop or cut than a steering lock that's through the rear sprocket.
"fuck that, let's go and find one that's easier to steal"
Or using a steering lock like that could just be a reason to carry something which could very easily be used as a weapon.
The last post was made 5 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.45 - MySQL Queries: 16 - Page Size: 138.73 Kb
