Engine Damage
Bod
PostPosted: 09:58 - 18 Mar 2005    Post subject: Engine Damage Reply with quote
Hi all I am looking at an engine for my bike as a spare. I have seen one however it has damage to the sproket casing.....
the bike's chain snapped and damaged the casing around the front sprocket (see picture). Very little damage was caused but unfortunately it was enough to make the bottom end of the engine unuseable.
Now, unusable....does this mean cannot be used EVER, or can repairs be made to the casing?
Here is a picture of the damage.
https://i14.ebayimg.com/01/i/03/9e/e5/19_1_b.JPG
Cheers
Bod
Ian (GPX)
PostPosted: 10:00 - 18 Mar 2005    Post subject: Reply with quote
If thats an Ali case, you can get it fixed at a metal factors, they will be able to repair that.
Bod
PostPosted: 10:01 - 18 Mar 2005    Post subject: Reply with quote
So I could get it repaired and be used as a spare engine, cool.
Cheers
Bod
cc123
Geez a joab?
PostPosted: 10:05 - 18 Mar 2005    Post subject: Reply with quote
I've seen something similar on an older model R1. Guy repaired the whole section round that area.
Good as new once it was fixed. Think his front sprocket snapped off in mid-go!
Old bikes >>> https://www.bikepics.com/members/cc123/
PostPosted: 10:12 - 18 Mar 2005    Post subject: Reply with quote
Certainly doesn't look like anything load-bearing or functionally critical has gone. You could probably even glue a cover on using epoxy metal, although a metal fabricator could TIG weld something much nicer looking on there. Done properly, it could be made to look a bit flash and 'custom' for extra pose value.
Zoffo
PostPosted: 10:15 - 18 Mar 2005    Post subject: Reply with quote
Often happens when a chain lets go so is a common repair
Bod
PostPosted: 10:34 - 18 Mar 2005    Post subject: Reply with quote
Cool, so it be good to go then Smile
Dr Nick
PostPosted: 10:57 - 18 Mar 2005    Post subject: Reply with quote
Did the same to my hornet engine, took the water pump mount clean off the crankcase, mate of my dads drilled into the crankcase, put a bolt in and re attached the waterpump, has been fine since summer touch wood.
is that it
PostPosted: 13:04 - 18 Mar 2005    Post subject: Reply with quote
Looks like it has torn off the mounts for the clutch slave cylinder. Might not be an easy repair.
Bod
PostPosted: 17:20 - 18 Mar 2005    Post subject: Reply with quote
Hiya, the engine is off a rsv mille, does that make a difference KS?
Sparks!
Sir Tart-a-lot
PostPosted: 18:14 - 18 Mar 2005    Post subject: Reply with quote
What's wrong with your current engine?
Is that why he sold the bike cheap? Wink
Bod
PostPosted: 18:26 - 18 Mar 2005    Post subject: Reply with quote
hahah yams :S nothing wrong with my engine now, buying that as a spare to learn how to adjust valves and cam chains etc
PostPosted: 18:27 - 18 Mar 2005    Post subject: Reply with quote
Not really. I would expect the clutch slave cylinder would need to be mounted securely and accuratly. Get it wrong and the clutch action is likely to be nasty, or the slave cylinder will just tear itself off.
Personally I would say you need to speak to an experienced high quality alloy welder, but it would not surprise me if they say it needs an engine strip to machine the repaired section accuratly.
Bod
PostPosted: 18:29 - 18 Mar 2005    Post subject: Reply with quote
Right, I would be stripping it down anyway to learn what makes it tick so that wouldnt be a problem.
Thanks
It which case go for it if cheap. Do a total strip as you feel like it. Suspect a blown engine with good cases might well be fairly cheap.
Bod
PostPosted: 18:32 - 18 Mar 2005    Post subject: Reply with quote
He is looking at 150 for it at the moment.
PostPosted: 18:53 - 18 Mar 2005    Post subject: Reply with quote
No idea on RSV engine prices (suspect they are not that expensive as the frames are so easily written off), but that sounds fairly cheap.
keith
Claud 14.7 to 1
PostPosted: 19:42 - 18 Mar 2005    Post subject: Reply with quote
Why not get an engine from the breakers yard. An engine is an engine, may have a different piston configuration but they all use the "same" parts.
Crappie old car engine will teach you lots. Or an older bike engine for that matter. RSV engines are expensive I presume.
That or just buy a Haynes manual and look though it.... a lot. Thumbs Up
Bod
PostPosted: 08:34 - 19 Mar 2005    Post subject: Reply with quote
Never thought of that will have a gander for motorbike breakers near Rochdale.
Cheers
Bod
The last post was made 21 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.4 - MySQL Queries: 16 - Page Size: 105 Kb
