Removing broken hex key from allen bolt
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
PostPosted: 15:34 - 16 Jul 2018    Post subject: Reply with quote
Also worth noting that if you remove all other steel parts from the calliper, you could dissolve the pin out by immersing it in a boiling hot, strong alum solution for a few hours. This will dissolve ferrous metal but leave alloy untouched.
It may or may not attack the paint/coating.
Old Git Racing
PostPosted: 16:42 - 16 Jul 2018    Post subject: Reply with quote
Tried a magnet?
OGR.
andyscooter
PostPosted: 17:13 - 16 Jul 2018    Post subject: Reply with quote
snapped cheap hex key will also probably mean rounded off head as well
I bought a set of hex sockets for my ratchets these have become my go to thing now for any removal
Raffles
PostPosted: 23:06 - 16 Jul 2018    Post subject: Reply with quote
Kawasaki Jimbo wrote:
I wonder if you could use a punch at a slight angle to try and drive the key clockwise and loosen its grip.
^^^This^^^
A few correctly aimed strikes could see the remains of that Quidshop key simply fall out with very little effort.
Riejufixing
PostPosted: 23:13 - 16 Jul 2018    Post subject: Reply with quote
It looks as though the key was the wrong size and it's snapped off/jammed. Tap it about with a drift and if that frees it use an air line/tubular nozzle to blow it out.
kramdra
PostPosted: 12:43 - 22 Jul 2018    Post subject: Reply with quote
That should come out with a wiggle and few taps of a punch. If not, hot alum to disolve it.
New caliper is a good option - they often come with almost new set of pads.
recman
PostPosted: 16:48 - 22 Jul 2018    Post subject: Reply with quote
I need closure.
MCN
PostPosted: 20:43 - 22 Jul 2018    Post subject: Reply with quote
Dave.... wrote:
A masonry drill will drill hardened steel. Slow speed and keep putting oil on it.
Masonry drill will cut through most steel easily BUT.
It doesn't have a proper cutting edge so needs to be ground to provide an edge. Minor detail but when sharp it will piss through that hex key.
(Which looks to be the wrong size anyway.)
The last post was made 5 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.16 - MySQL Queries: 17 - Page Size: 57.93 Kb
