What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 316, 317, 318 ... 407, 408, 409  Next
AshWebster
PostPosted: 13:51 - 17 Jul 2018    Post subject: Reply with quote
found out the 600RR is limited to 139.
disclaimer: this was in my dreams and definitely 100% didnt take place
Honda cg125 J reg peice of shit ---> CB650F ---> 2016 CBR600RR
Ford KA ---> 93' MR2 ---> 94'MR2 ---> 98' Subaru WRX STI Ver 3 (track car)
P.
PostPosted: 18:18 - 17 Jul 2018    Post subject: Reply with quote
It's probably broken if it only did that. I know my clocks read 171 before, so take some sizeable wedge off for Speedo inaccuracies... It was well over 140, probably more into 150.
Hong Kong Phooey
PostPosted: 21:31 - 17 Jul 2018    Post subject: Reply with quote
Hong Kong Phooey wrote:
Road 5 rear fitted, would have done the front too but the chain needed some tlc.
Will fit front tomoz.
PR4s seem to have done 8.5k, might have got away with another 500 miles but it was getting a bit squirmy in the wet the other day.
Rear was tried today, makes the steering responsive again getting a nice round profile back on, but the front felt a bit shitty as the current PR4 is worn oddly on one side.
New front is on, can't wait to give it some. Didn't feel as tacky as the rear, bit shinier so I'll go gently for a few miles.
---Update---
Forgot how good new tyres feel, still only tested in the dry warm weather but they do feel better when leant over than the pr4s when they were new. I think there's about 1cm of the edge that hasn't touched the road yet, so more to give if needed but felt stable regardless, and I've not felt that I've been pushing too hard.
Hong Kong Phooey
PostPosted: 21:33 - 17 Jul 2018    Post subject: Reply with quote
I'm thinking the gearing has been altered, but then I'm not certain where the speedo picks up from on that bike.
Definitely should be capable of more unless you're wearing your MC hammer pants, diving flippers and your helmet is 64XL.
Fin
PostPosted: 21:47 - 17 Jul 2018    Post subject: Reply with quote
Do you have another gear? Laughing
Well my cbr600f3 does around 140 in 5th and up to an indicated 160 in 6th but the speedo reads a bit high.
AshWebster
PostPosted: 10:56 - 18 Jul 2018    Post subject: Reply with quote
Nope, was in 6th and full throttle.
wasnt even at 15k revs.. around 10k.
139 on the dash.
Edit: i might have to have another dream this weekend.
kramdra
PostPosted: 12:16 - 18 Jul 2018    Post subject: Reply with quote
On the dash, something is wrong. I assumed gps... The cbr6f with massive topbox can easily do that though I have no desire to find where she tops out...
FretGrinder
PostPosted: 19:28 - 18 Jul 2018    Post subject: Reply with quote
Fitted a 12v socket to the MT09.
It's an official yamaha kit that wires directly into the bikes loom via an auxiliary connector, so it runs off the ignition.
https://s33.postimg.cc/oy47dhgi7/IMG-20180718-_WA0023.jpg
Yamaha MT-09
ಠ_ಠ
recman
PostPosted: 11:18 - 19 Jul 2018    Post subject: Reply with quote
Can't beat a bit of plug and play.
ThatDippyTwat
PostPosted: 17:34 - 20 Jul 2018    Post subject: Reply with quote
MOT'd the VFR - No Advisories after being off the road for 18 months.
Howling Terror
PostPosted: 12:26 - 21 Jul 2018    Post subject: Reply with quote
Decided to be proactive and get a new battery as the old motobatt isn't holding charge like it used to, can't complain after +6 years.
Save myself from taking the fairing off I looked up the part number on motobatt site. Did a search on that auction site and up pops a different motobatt....says it fits my bike.
I ain't got time fo dis so plumbed for the proper one albeit the more costly one.
So yeah...new battery. Clapping
andym
PostPosted: 14:00 - 21 Jul 2018    Post subject: Reply with quote
I decided to have a go at fixing the slight running issue... got to the lockup and realised I'd forgot the key.... so I kicked the back wheel, called it a useless bastard and came home
Hawkeye1250FA
PostPosted: 14:48 - 21 Jul 2018    Post subject: Reply with quote
Gsx1250
Front and rear wheel bearings replaced
Degrease and properly clean both wheels and sprocket while I had them off
Rf400r (over last 3 weeks)
Replace spark plugs
Oil change
New battery
Fit new fairing clips where missing
Installed trickle charger adapter under seat
Starts first time every time now 👍
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
waffles
PostPosted: 15:46 - 21 Jul 2018    Post subject: Reply with quote
Fitted a voltage and temperature gauge to the grom, the unit replaces the top clamps on the bars and looks pretty good. Needs some cable ties to hide some wiring and it is done. Very happy!
ThatDippyTwat
PostPosted: 18:09 - 21 Jul 2018    Post subject: Reply with quote
VFR750:-
Sorted reg/rec and associated wiring. Battery now charges.
Replaced oil feed line to the cooler. No apparent leaks.
"Tested it" on a quiet section of dual carrigeway.
GA125 - Chain lube and tension. sorted out a few odd wires for it's MOT next week.
bezza1966
PostPosted: 19:25 - 21 Jul 2018    Post subject: Reply with quote
had a few parcels arrive from the Land of Fried rice..
Lovely Top of the Range Bike alarm (£9) gotta be excellent..
also an adjustable sidestand, as the one on the Skygo is about 2" too short!!!!
and also a lovely new(to me) back tyre is going to be fitted in the week prior to the MOT test....
Do I need a rear brake light switch for MOT????
ThatDippyTwat
PostPosted: 20:44 - 21 Jul 2018    Post subject: Reply with quote
If you have lights, you need both brake switches to be functional.
kramdra
PostPosted: 00:46 - 22 Jul 2018    Post subject: Reply with quote
Tidied garage and got the 250 out,carbs off, ready to clean.
I may have too many tires.. Half are worn out but dump charges 4 quid each, which I was refusing to pay. Two more good ones on the wall.
https://s20.postimg.cc/h3gxeojrh/IMG_20180721_211859.jpg
tom_e
PostPosted: 11:14 - 22 Jul 2018    Post subject: Reply with quote
Wrap a couple in black bags, tape together, throw in general waste, profit?
johnsmith222
PostPosted: 11:25 - 22 Jul 2018    Post subject: Reply with quote
Wheelie bin makes these disappear!
If they don't fit, cut the sidewalls out with a knife.
kramdra
PostPosted: 11:41 - 22 Jul 2018    Post subject: Reply with quote
It takes a fuck ton of effort to cut up a tire, particually the bead wires. It will ruin hacksaw blades but I have not yet attempted with the grinder. I have disposed of a few this way. thin disc in slow grinder and a scalpel blade has it in 3 pieces very quick.
If its going to cost 4 quid Anyway I am tempted to post them without a return address. I do have some freepost return labels..
Got 250 carbs stripped. Lots of sand and shit in the float bowls, unsure where or how it has got in - was it hiding somewhere when cleaned years ago?! Or has it come from the tank.
Jets were blocked, soaking in carb cleaner in a mini jam jar.
sickpup
Old Timer
PostPosted: 11:31 - 24 Jul 2018    Post subject: Reply with quote
59 plate Deauville
Replaced headraces.
https://www.bikechatforums.com/download.php?id=101326
Head race press makes things a lot easier when fitting head races.
https://www.bikechatforums.com/download.php?id=101325
sickpup
Old Timer
PostPosted: 13:29 - 24 Jul 2018    Post subject: Reply with quote
And now fork seal and bushes.
https://www.bikechatforums.com/download.php?id=101327
P.
PostPosted: 15:47 - 24 Jul 2018    Post subject: Reply with quote
Old tyres mix really well with petrol and speed cameras.
PostPosted: 18:01 - 24 Jul 2018    Post subject: Reply with quote
Today's comedy brought to you by the numbers 10115 and 915.
10115 miles on the Enfield, with 915 showing on my "trip counter", a 3 digit combination lock which I use to record when I last filled up.
10115 - (9)915 = 100, right? Riiiight? No, wait, is that two hundr-
*cough* *splutter* rolllll to a stop. Not had to flip it to reserve for quite a while. Embarassed
The last post was made 5 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 317 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.66 - MySQL Queries: 17 - Page Size: 134.36 Kb
