Author |
Andy_Pagin |
Andy_Pagin World Chat Champion
Back to top |
Itchy |
Itchy Super Spammer
Posted: 08:33 - 16 Aug 2018 Post subject: |
Is the 2003 model similar to the 2000 model?
Sandra changed her rear shock oh hers and it didn't require any special tools I remember helping her out on it.
I changed it on my XT600 and my CBRs as long as you don't need to remove the swing arm completely or split the shock (spring replacement) you can just undo the bolts on the top and bottom.
The swing arm requires special castle sockets to undo.
It's much easier with an extra pair of hands though. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
Back to top |
el_oso |
el_oso World Chat Champion
Back to top |
MarJay |
MarJay But it's British!
Back to top |
DrSnoosnoo |
DrSnoosnoo World Chat Champion
Back to top |
Arfa__ |
Arfa__ Traffic Copper
Posted: 13:38 - 16 Aug 2018 Post subject: |
Dead easy on Fazer. Did mine couple of years ago, admittedly at OMC with help of some expert staff.
You'll really appreciate the centre stand on the Fazer here. Stick it on stand, remove side panels, can't recall if I removed rear wheel and hugger, may have done just to get better access. Then literally just unbolt it top 'n bottom. Top bolts will likely need an extender/universal joint on sprocket to reach in. Good plan to buy a replacement bearing for bottom to stick on at same time, only a few quid from Fowler's. Usual deal with bearing grease / copper slip / correct torque etc on refitting.
Two pairs of hands certainly helps to brace nut/bolt on t'other side and support swingarm (but you can probably prop this up with some wood), especially on refitting new shock. ____________________ Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007 |
Back to top |
stinkwheel |
Back to top |
ThatDippyTwat |
Back to top |
grr666 |
grr666 Super Spammer
Posted: 21:54 - 16 Aug 2018 Post subject: |
Did the mono shock on the scooter. It blew its oil seals so I needed a new one. Complete unit with spring.
Had a lot of plastic to remove to get to the nuts, but otherwide a doddle. I strapped the rear wheel over the saddle
with a ratchet strap to keep it up on the swingarm so I could easily remove/replace the bolts with out lifting the back end. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off. |
Back to top |
Skudd |
Skudd Super Spammer
Back to top |
Andy_Pagin |
Posted: 20:28 - 02 Sep 2018 Post subject: |
Did it. Single handed as per Haynes. Dead easy. Helped a lot having a bottle Jack to raise the swing arm, and a couple of Next catalogues to rest the tyre on.
https://i636.photobucket.com/albums/uu84/anadin96/20180901_140648.jpg ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
Back to top |
The last post was made 5 years, 235 days ago. Instead of replying here, would creating a new thread be more useful? |
