Author |
0l0dom0l0 |
0l0dom0l0 World Chat Champion
Posted: 10:13 - 21 Aug 2018 Post subject: Strengthening Garage Roof for Storage |
New build house. Single large garage 6 X 3M.
Photo attached.
What do I need to do to board the roof out and be able to walk around/ store stuff up there?
I'm not talking about loads of stuff, but assorted bike spares and fairings etc and I need to be able to wonder about to get to them.
Also need to make some kind of ladder (was thinking on runners) so I can access the different bits.
Thanks ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
Back to top |
0l0dom0l0 |
Posted: 10:16 - 21 Aug 2018 Post subject: |
https://www.bikechatforums.com/download.php?id=101438 ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Back to top |
doggone |
doggone World Chat Champion
Back to top |
0l0dom0l0 |
Posted: 10:27 - 21 Aug 2018 Post subject: |
doggone wrote: | Would you really need walk about, the truss things look like a big problem for that idea.
I'd try to make something more like plywood open shelving to slide stuff in from a tall stepladder. |
Its not the best photo. Remember it's 6m long!
There's a huge void in the middle where you've got no real truss in the way. Deffo room to walk about. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Back to top |
Polarbear |
Polarbear Super Spammer
Posted: 10:51 - 21 Aug 2018 Post subject: |
I think he means more like, will it ever take the weight.
what size are the roof trusses? Looking at them I would say you would have to just about completely rebuilt the roof to take any sort of weight.
But I'm a marine engineer, not a builder and if it isn't minimum 2" steel I beam it's too weak ____________________ Triumph Trophy Launch Edition |
Back to top |
arry |
arry Super Spammer
Back to top |
0l0dom0l0 |
Posted: 11:56 - 21 Aug 2018 Post subject: |
arry wrote: | Looks like a lightweight block wall that it ties into on the right hand side - that won't be a lot of good for strength. If I were doing it, I'd build a timber frame down to the ground tied into the wall either side. You'd lose a bit of clear width on your left hand side but the right hand side has the support pillar centrally anyway, so you'd be able to run your timbers down there without it affecting much. |
Ok, that might work as I was thinking of insulating the thermalite block wall anyway so can build a timber structure and the plaster board over the top.
The alternative I am thinking is to run some horizontal joists across underneath the timbers bolted into the walls to support the long thin beams. I could also double or treble up on the roof timber.
Do you think the beams would work? The wall on the left is the exterior wall of the house. Right is thermalite into next doors garage. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Back to top |
bugeye_bob |
bugeye_bob World Chat Champion
Back to top |
Riejufixing |
Riejufixing World Chat Champion
Back to top |
0l0dom0l0 |
Posted: 12:56 - 21 Aug 2018 Post subject: |
Riejufixing wrote: | "The wall on the left is the exterior wall of the house. Right is thermalite into next doors garage"
It doesn't look like Thermalite or other aerated block, it looks more like medium density aggregate of some sort. If it's thermalite, it will have a smooth texture and you will be able to push a screwdriver into it easily. Anyway, whatever, you can install beams into it but you need to ensure it does not weaken the structure, and you need to tell your neighbour.
First step: Do you know a friendly builder who'd advise, "for a drink"?
I might be inclined to bolt a timber plate to the party wall, and hang joists on it under the existing, in old money 2" x 6" joists at 18" centres (across the garage!). Probably leave it as a "gallery" for ease of access. |
Sorry. Yes you are correct. It's breeze block type thing.
Your points are noted. There is a considerable area for storage although I don't have loads and loads to store up there. I'm just talking about bike fairings and a few boxes of bits for the bikes, scrubs for trackdays etc
There's a really nice space that you can comfortable stand up in between the truss of the roof bits and so I was looking to use this as access and the smaller areas under the eves as storage.
My preference would be to make it as least damaging/ intrusive on the existing structure as possible so I like the idea of building a timber frame on the right hand side and mounting the joists to that as I can insulate and plaster board over that as well to hide the timber frame.
On the left I could bolt a plate to support the other end of the joists.
Is it worth (if I can actually get some 6 x 2 long enough) doubling up on the roof beams and does what I've concluded sound reasonable?
Don't know a builder sadly.
I don't think the wall on the left is anything other than the exterior wall so I don't think there's much risk of doing any damage to it (in terms of weakening) as I assume it isn't load bearing. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Back to top |
Riejufixing |
Back to top |
MCN |
MCN Super Spammer
Back to top |
Kawasaki Jimbo |
Kawasaki Jimbo World Chat Champion
Back to top |
skatefreak |
skatefreak World Chat Champion
Back to top |
J4mes |
J4mes World Chat Champion
Posted: 09:58 - 22 Aug 2018 Post subject: |
be aware of your NHBC warranty and house insurance should you fuck about cutting trusses and shit and the roof collapses.
I boarded all of mine in my last garage and just left regular access points so everything was within reach of my boat hook!
I seem to remember you're meant to get approval from building control for boarding your loft as the roof trusses might not be man enough for the weight. |
Back to top |
doggone |
Back to top |
MattEMulsion |
MattEMulsion World Chat Champion
Back to top |
stevo as b4 |
Back to top |
MCN |
MCN Super Spammer
Back to top |
The last post was made 5 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
