Author |
NutsyUk |
NutsyUk Nearly there...
Back to top |
piazza |
piazza Brolly Dolly
Posted: 17:28 - 09 Sep 2018 Post subject: |
Does the bulb not pull out of that? |
Back to top |
MarJay |
MarJay But it's British!
Back to top |
NutsyUk |
Posted: 17:43 - 09 Sep 2018 Post subject: |
Im just showing both sides....
This is an h4 fitting https://new.minimania.com/images_temp/800600001g2nmx1501.jpg
See the difference? ____________________ Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold! |
Back to top |
Evil Hans |
Evil Hans World Chat Champion
Back to top |
NutsyUk |
Back to top |
NutsyUk |
Posted: 18:01 - 09 Sep 2018 Post subject: |
Ahhhhhhh right see what you mean. The base fitting is like an adaptor.... just realised mine pulled off and low and behold the h7 small contacts....
Thanks I can also tell my brother to check his bulbs... hes going to be relieved as he was having the same issue as me...
Yeah it pulls out, i should have noticed but it was so tight in there i honestly thought it was one unit... And brother was having the same issue... And he was telling me of stories of hes seem people just bend the contacts to make it fit....... which threw me right off...
So yeah H7 it is... Thanks all ____________________ Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Back to top |
Evil Hans |
Back to top |
grr666 |
grr666 Super Spammer
Back to top |
NutsyUk |
Back to top |
grr666 |
Posted: 19:18 - 09 Sep 2018 Post subject: |
That's a minimum. Admittedly I'm not a big miles rider but haven't replaced a blown one yet in any of my
vehicles I've had them in. Anecdote maybe, but quite true in my case none the less. I have them in the van too.
If it's lifespan you're after But you'll get no increased performance. At the end of the day to be brighter the filament must burn hotter,
only way to do that is to make it thinner therefore more fragile and prone to breaking. If superbright halogen bulbs that didn't
blow more often were a thing then I can't imagine any other kind needing to exist anymore.
Or there's these which are a middle ground between either extreme. Slight performance increase but increased durability
Best compromise you'll get I reckon without iffy HID conversion. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off. |
Back to top |
NutsyUk |
Posted: 21:07 - 10 Sep 2018 Post subject: |
So still looking for bulbs, and i started to look at the LED bulbs again...
And OMFG LOL *SPITS COFFEE OUT* WTF!
So looking on ebay decided to see whats going these days for LED headlight bulbs... and the specs, Oh wow those specs.... I know many of us smart folk can see through it all but DAMN. Why does Ebay let sellers get away with the UTTER fucking SHITE, the sellers say about the bulbs!
The level of bullshit is painful to the nose. Specs like 20k LM at TWO HUNDRED WATTS!!!!111!!1!11
Seriously WTF... Can cars even comfortably dish out 200w of power per bulb?
but lets not get too carried away with that watt rating, because lets look at that 20000 LM..... Well no dont, dont look at 20000LM youll go blind rather quickly.
Lets get some comparisons (im not going to search right now for exact figures but the roughs are close enough)
A good quality Xenon Lense headlamp takes roughly 55w of power. These dish out somewhere between 2-4 thousand LM at high beam. Roughly.... As you know this is damn good light, doesnt get much better.
Thats 55w, In a xenon gas filament bulb... LEDs are meant to be more efficient so realistically 55w LED bulb will produce more light.
A good quality Cree COB used in realistically specced flash lights give off around 1000 LM, and use up roughly 10-15W on the lower voltage of 3.7.
So when I see insane figures like 20000LM and 120w or 200w power draws I cry.... heck EVEN if theyre 200W leds and some how survive running... They would melt the reflector right out of any headlight.
it pisses me off that this goes on all the time and shops and places like EBAY do nothing to curb it. These specs arnt even realistically over stated... They are RIGHT out of the ballpark fucking crazy...
Its annoying though because I wouldnt mind trying LED bulbs again. But I want to check out real specs so i know they wont catch fire the moment i turn them on and they wont draw too much power off the bike.
I couldnt help myself I had to double check with some real specs
https://uk.farnell.com/cree/mkrawt-02-0000-0d00j20e1/led-hb-xlamp-mk-r-cool-white-1040lm/dp/2458470
This is a real cree cob of acound 1000 lm... Found in the high end good quality LED flash lights draws like I guessed 15w...
And here is the brightest largest cob on farnell
https://uk.farnell.com/cree/cma3090-0000-000q0h0a40g/led-array-cob-neutral-wht-12372lm/dp/2816594
Its just over 12k LM its 3Cm wide and draws 174w. ____________________ Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Back to top |
Riejufixing |
Posted: 21:24 - 10 Sep 2018 Post subject: |
Back to top |
iooi |
iooi Super Spammer
Back to top |
stinkwheel |
Posted: 22:03 - 10 Sep 2018 Post subject: |
I've had quite a few bulbs from from classiccarleds.co.uk
I've emailed them with technical questions about running them on AC power before and got answers that gave every impression they know what they are doing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
kramdra |
kramdra World Chat Champion
Posted: 21:33 - 11 Sep 2018 Post subject: |
Most likely shit adjustment by the user. Assuming it is this, www.ebay.co.uk/itm/283138090247
H7's like this are ideal as you get a dedicated reflector without any need for dual beam shielding, or wasting light to prevent glare. 100% of the light can be focused for low beam.
If bulbs are blowing, look at your headlight mountings and add some rubber somewhere to remove vibration. |
Back to top |
The last post was made 5 years, 238 days ago. Instead of replying here, would creating a new thread be more useful? |
