Water Pump leak, help?
Hornet1998
PostPosted: 17:16 - 24 Sep 2018    Post subject: Water Pump leak, help? Reply with quote
I recently replaced the radiator fan on my Hornet, did not touch the water pump at all but as soon as i turn it on, it leaks coolant from a small hole at the back of it.. Does anyone know why this has happened or how i can fix it?
Pete.
PostPosted: 17:22 - 24 Sep 2018    Post subject: Reply with quote
The pump seal bellows have split. The pumps are expensive little buggers. Usually you can only swap the pump but it is possible to swap out the seals if you're that way inclined.
a.k.a 'Geri'
MCN
PostPosted: 19:05 - 24 Sep 2018    Post subject: Reply with quote
As said by Pete, the pump seal is burst/broken.
They are two separate parts that rub together to form a seal.
https://en.m.wikipedia.org/wiki/End-face_mechanical_seal
The hole is there for two reasons, one to prevent water passing into the engine via the water pump drive shaft. And two, to let you see the seal is leaking.
It's called a Tell-Tale Hole.
Some pumps can be repaired by fitting a kit, some can be bridged and just the seal replaced and some cannot be opened to allow access. Factory sealed.
You may be lucky on eBay.
About £200 for a pump or £30 for a kit. (Guess)
I would do the kit if it were mine. Shocked
Or try this shit:
https://www.amazon.co.uk/KALIMEX-LTD-K-Seal-Coolant-Repair/dp/B001QT9KO6#immersive-view_1537812864858
Hornet1998
PostPosted: 07:51 - 25 Sep 2018    Post subject: Reply with quote
Thanks for the replies, where can I get these kits?
And so I understand better, would it be the gasket/water pump cover that's gone, no. 5 on this spares site?
https://www.bike-parts-honda.com/honda-motorcycle/600-MOTO/HORNET/1998/CB600FW/Engine/WATER-PUMP/13MBZW41/E__1000/1/1616
rpsmith79
PostPosted: 10:57 - 25 Sep 2018    Post subject: Reply with quote
Yep, same happened on my Hornet, according to the Haynes Manual, the hole is there as an indicator/bypass, so that when the seal fails, water drips from here rather than going into the engine itself and mixing with the oil
It is a non-servicable part, so replacement only
I got lucky and bought a 2nd hand one of eBay for about £30 and a new gasket for a a few quid, new they are over £150
In you link, it's the part with no number that has gone, the part with the shaft sticking out (all included in item 3)
MCN
PostPosted: 20:45 - 26 Sep 2018    Post subject: Reply with quote
The part you need is the 'mechanical seal'.
It is not a gasket. (The thing that forms the seal between two mating faces.)
Something 'similar' to this beast.
https://www.ebay.co.uk/itm/HONDA-VF1000F-VF1000R-WATER-PUMP-MECHANICAL-SEAL-ALL-YEARS-B107-G617/132312973712?epid=1665534302&hash=item1ece77c190:g:28sAAOSwarNZp7RB
The last post was made 5 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 17 - Page Size: 51.42 Kb
