Odd electrical question
meyrick
PostPosted: 00:20 - 20 Mar 2005    Post subject: Odd electrical question Reply with quote
Been trying to figure this one out for days, but I can't find any useful info:
Is it ok to wire up two 12V sealed lead acid batteries of different capacities (amp hours) in parallel and both use and charge them as a single unit?
Thinking Eh?
Paul.
PostPosted: 00:48 - 20 Mar 2005    Post subject: Reply with quote
Not sure. I would have thought using batteries in paralell would work ok. They use a big line of batteries in coaches and buses.
Not sure about the capacities though?? I know when you charge batteries in series (like in a radio controlled car) they only go up to the level of the lowest capacity cell in the pack.
What are you trying to do?
alains
PostPosted: 01:20 - 20 Mar 2005    Post subject: Reply with quote
in parallele yes , the charging amps will split in 2 separate intensity function of each capacity . ex : if you've got a 12 Ah and a 8 Ah with a total charge courant of 4 Amps , the 12 will charge at 2,6 A & the 8 at 1,6 A .
meyrick
PostPosted: 10:27 - 20 Mar 2005    Post subject: Reply with quote
I want to replace my battery with something bigger and a little more deep cycle. I have just fitted a heated waistcoat and I am planning a halogen headlight so I want to make sure the bike has some reserve. Only problem is space under my seat is at a premium. Best thing I can think of is to split it between two batteries and squeeze them in where they will fit, but the holes are different sizes, hence the batteries need to be.
Sweet. Thumbs Up Very Happy
The last post was made 21 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.29 - MySQL Queries: 16 - Page Size: 41.88 Kb
