Author |
el_oso |
el_oso World Chat Champion
Back to top |
- Super Spammer
Back to top |
el_oso |
Back to top |
- Super Spammer
Back to top |
el_oso |
Back to top |
- Super Spammer
Posted: 15:42 - 12 Oct 2018 Post subject: |
That's not a screenshot from a Windows client VPN connection, that's from a LAN or wifi connection. Like I said, I presume you're using a standard Windows VPN dial up connection?
Have you tried just creating a VPN connection using the Windows built in VPN client? All you need is WAN IP, username and password. You know, Network and Sharing Centre > Setup a new connection or network. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
Back to top |
owl |
owl World Chat Champion
Posted: 15:50 - 12 Oct 2018 Post subject: |
https://bt.custhelp.com/app/answers/detail/a_id/14244/c/402
I have problems using my VPN (Virtual Private Network)
Some VPNs may not work well with the BT Web Address Help service. If you're experiencing problems with your VPN you should disconnect from the VPN and then opt out of the BT Web Address Help service in Preferences. You'll only need to opt out once. ____________________ Observation is the greatest source of wisdom. |
Back to top |
el_oso |
Back to top |
- Super Spammer
Back to top |
owl |
Back to top |
el_oso |
Back to top |
- Super Spammer
Back to top |
NeverAgain |
NeverAgain Nova Slayer
Back to top |
owl |
Back to top |
NeverAgain |
Back to top |
- Super Spammer
Posted: 17:28 - 12 Oct 2018 Post subject: |
If it is a DNS issue, the OP should be able to open up a BBC "page not found" by typing https://212.58.244.27 into the address bar of the browser.
If that works, it's DNS, if not, then BT are blocking it some other way. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Back to top |
el_oso |
Back to top |
- Super Spammer
Posted: 15:02 - 15 Oct 2018 Post subject: |
el_oso wrote: | sorry guys, was away at the weekend. Thanks for your input so far.
I do get the page not found error from BBC when going to the page by IP.
My prefered DNS servers are pushed from the server. Just to be sure I've overridden the DNS in Windows and Linux Mint, but to no avail.
When doing an nslookup I get a return and the DNS server that I expect is being used. |
Can you set an DNS such as 208.67.220.220 in IP4 for the local area connection you photographed earlier? You know, the one with no default gateway, that you screenshotted from a command prompt.
I have a customer who has a few dial in VPN accounts. Since the VOIP supplier switched the broadband to their ISP, I've no longer been able to get DNS to work through the VPN connections. I have to map drives to a fixed IP address, instead of PC/Server name. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Back to top |
el_oso |
Back to top |
- Super Spammer
Posted: 16:02 - 15 Oct 2018 Post subject: |
el_oso wrote: | mpd72 CPT wrote: |
I have a customer who has a few dial in VPN accounts. Since the VOIP supplier switched the broadband to their ISP, I've no longer been able to get DNS to work through the VPN connections. I have to map drives to a fixed IP address, instead of PC/Server name. |
That is what it is currently set as. |
This is the Ethernet connection, not the wifi? ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Back to top |
el_oso |
Back to top |
owl |
Back to top |
el_oso |
Posted: 16:58 - 15 Oct 2018 Post subject: |
It appeared to work as expected, although from my phone, when I connected to hotspots in sri lanka. Was always able to access my home network, although I never explicitly checked what my external IP was.
Using the mobile network, I can connect to the VPN and my external IP is as if I was at home. Will try a UK based hotspot next time I walk past a pret/starbucks.
I dont remember going through a landing page, however it's an open hotspot. I am assuming it is using a BT cookie from BT sport etc to authorise me as being able to use the BT hotspot.
Code: |
#/etc/openvpn/server.conf
local 192.168.1.3
dev tun
proto udp
port 1194
server 10.8.0.0 255.255.255.0
# server and remote endpoints
ifconfig 10.8.0.1 10.8.0.2
# Add route to Client routing table for the OpenVPN Server
push "route 10.8.0.1 255.255.255.255"
# Add route to Client routing table for the OpenVPN Subnet
push "route 10.8.0.0 255.255.255.0"
# your local subnet
push "route 192.168.1.3 255.255.255.255"
#push "dhcp-option DNS 192.168.1.254"
push "dhcp-option DNS 8.8.8.8"
# Override the Client default gateway by using 0.0.0.0/1 and
# 128.0.0.0/1 rather than 0.0.0.0/0. This has the benefit of
# overriding but not wiping out the original default gateway.
push "redirect-gateway def1"
client-to-client
#duplicate-cn
keepalive 10 120
tls-server
cipher AES-256-CBC
comp-lzo
user nobody
group nogroup
persist-key
persist-tun
status /var/log/openvpn-status.log 20
log /var/log/openvpn.log
verb 3
Code: |
machine-readable-output
#allow-recursive-routing
ifconfig-nowarn
client
verb 2
connect-retry-max 5
connect-retry 2 300
resolv-retry 60
dev tun
remote *removed address* 1194 udp
cipher AES-256-CBC
comp-lzo
key-direction 1
remote-cert-tls server
push-peer-info
____________________ Duke 390
Car: Jeep Wrangler 4.0L |
Back to top |
owl |
Posted: 17:58 - 15 Oct 2018 Post subject: |
Can't see anything obviously wrong
Here's my server/client for comparison
Code: | -SERVER
port 1194
proto udp
dev tun
sndbuf 0
rcvbuf 0
ca ca.crt
cert server.crt
key server.key
dh dh.pem
auth SHA512
tls-auth ta.key 0
topology subnet
ifconfig-pool-persist ipp.txt
push "redirect-gateway def1 bypass-dhcp"
push "dhcp-option DNS 8.8.4.4"
keepalive 10 120
cipher AES-256-CBC
user nobody
group nogroup
persist-key
persist-tun
status openvpn-status.log
verb 3
crl-verify crl.pem
-CLIENT
client
dev tun
proto udp
sndbuf 0
rcvbuf 0
remote *removed* 1194
resolv-retry infinite
nobind
persist-key
persist-tun
auth SHA512
cipher AES-256-CBC
setenv opt block-outside-dns
key-direction 1
verb 3
<ca> |
I don't have any BT accounts or I could test it on port 1194 for you, I just tried connecting to one and it popped up with the captive portal asking me to sign in.
Maybe you could try like NeverAgain said and change the ports to 443, however you might already have something assigned to this. You'd need to reconfigure your forwarding too. ____________________ Observation is the greatest source of wisdom. |
Back to top |
NeverAgain |
Back to top |
The last post was made 5 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
