Need an old XP Pro SP2 installation
PostPosted: 13:12 - 30 Aug 2018    Post subject: Reply with quote
Boot to safe mode then do this? https://www.techwalla.com/articles/how-to-bypass-windows-xp-sp2-activation
owl
PostPosted: 13:15 - 30 Aug 2018    Post subject: Reply with quote
this worked the last time I needed it...
https://goo.gl/VRBqyh
let me know once you have it as I will be removing it after.
owl
PostPosted: 16:59 - 30 Aug 2018    Post subject: Reply with quote
There's plenty keys online, took less than 10 seconds to find one that works....
In fact it's the first result in a google search...
I thought you did this stuff for a living?
https://i.imgur.com/1ppgBeK.png
techsnap
PostPosted: 18:36 - 30 Aug 2018    Post subject: Reply with quote
You need a Volume Licensing version ISO and key. No activation required at all then Thumbs Up
andym
PostPosted: 19:43 - 30 Aug 2018    Post subject: Reply with quote
I may still have my old (original) XP pro disc kicking about somewhere Whistle
owl
PostPosted: 09:41 - 31 Aug 2018    Post subject: Reply with quote
All call home xp activation services were decommissioned when support ended. There’s quite a few options for bypassing/disabling the activation though.
Jayy
Mr. Ponzi
PostPosted: 21:24 - 04 Sep 2018    Post subject: Reply with quote
mpd72 CPT wrote:
Cheers folks, got there in the end with the reg key edit. Managed to make it work by denying all "System" permissions in the advanced section and unticking the "inherit" button.
Thanks for the keys Paddy, I did give the X86 one a go, but it didn't want to work with my OEM installation. Worth a shot though.
All you had to do was get an activation crack which would have sorted it first time.
Im-a-Ridah
PostPosted: 19:39 - 05 Sep 2018    Post subject: Reply with quote
I'm pretty sure the only way is to pirate it with a crack. M$ isn't going to let you activate software that they state is obsolete and insecure.
WD Forte
PostPosted: 01:01 - 06 Sep 2018    Post subject: Reply with quote
I think I might still have a copy of xp pro sp2 somewhere in my disc archives, I'll have a look if you want.
As I recall I bunged it in, booted up and off it went pre activated.
All you had to do then was install drivers for some of the hardware.
EDIT:
Yep still got XP pro SP3 preactivated.
You never know, it might come back into fashion
bikers smell of wee
tittymcarsefa...
PostPosted: 20:08 - 13 Oct 2018    Post subject: Reply with quote
Easiest way to get xp activated properly is via branded oem activation, no need to jump through hoops ringing microsoft to activate or risking having the coa blacklisted.
hp is an easy one to do just google hp dmi tattoo tool, it is a dos program which updates the motherboard bios dmi area to self activate with oem discs, It is designed to remark replacement motherboards so that they self activate.
You can mod a generic disc to any oem for activating oem systems but many of the files used are being lost as links die, It was possible to build multi oem activation into one disc so that you didn't need to carry round a stack of them.
I made myself an oem xp pro x64 sp2 to use on an old fujitsu system so that I could make use of all the ram a few years back, it was originally xp sp3 x32.
Is your computer a self build or an oem? windows 7/8 era machines often still have xp activation features, why not buy a matching brand installation media if you have an oem.
The only reasons I eventually left xp was the lack of 2d v-sync and driver support for new hardware everything else I could deal with.
The last post was made 5 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.83 - MySQL Queries: 17 - Page Size: 108.08 Kb
