Author |
MarJay |
MarJay But it's British!
Back to top |
Mark65 |
Mark65 World Chat Champion
Posted: 11:37 - 02 Nov 2018 Post subject: |
Hi,
I fitted the grips and they work great, but I didnt want to glue them on in case of a fault for warranty, so I used hairspray, works fine till they get hot then I get a slight bit of movement.
Ive got some ally foil tape to shim them a bit tighter and use a stronger hairspray, once i crack that the muffs can go on.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
Back to top |
kramdra |
kramdra World Chat Champion
Back to top |
rpsmith79 |
rpsmith79 World Chat Champion
Posted: 13:26 - 02 Nov 2018 Post subject: |
kramdra wrote: | rpsmith79 wrote: | If anyone is interested, MCN or running an offer this month on their 12 month subscription, £85 for 51 issues, with a free set of Oxford Heated grips worth £79.99 (rrp)
Not bad if you already get the occasional issue of MCN |
Again, I dispute the "worth" 79.99. That may be the rrp but if you had a set, youd never get more than half if you tried to sell them on. Even then, the buyer would be getting a bad deal.
£10. Delivered. Gets you a better product, even if you throw in the mcn shite. |
Well it's clearly a bad deal if you have no intention of reading the paper, but if like me, you already buy the paper each week, then it's a bloody good deal, even if i were to sell them straight away for £40 (which is what i am considering doing anyway, as i don't particularly need heated grips) ____________________ Current Bike: Honda CG125 ES4 // Honda CB600FS Hornet // Triumph Street Triple R |
Back to top |
Hong Kong Phooey |
Posted: 20:31 - 02 Nov 2018 Post subject: |
Fitted direct to battery, which is LiFePO4 chemistry, so was a bit wary of how it would work.
Kept checking the voltage and upped the idle a touch to make sure it's ok while hanging about at traffic lights. The auto switch off battery monitor works great.
Connectors are o-ring and screw cap so should be nicely protected from the elements. The mounting bracket, supplied screws and collars were ideal for the cbr, mounted next to the choke on the clutch lever bracket. The control unit is plastic welded shut so you can't open it up, time will tell but it looks like it will hold up.
Not particularly cold today, 50% was plenty hot enough. It warms up pretty quick.
I've taped the levers with black electrical tape, as they were sucking any heat out of my fingers.
Recommend, especially at £52. ____________________
'81 CG125, '97 FZS600 : '99 CBR600F4, '09 KTM RC8 |
Back to top |
bacon |
bacon World Chat Champion
Back to top |
talkToTheHat |
Back to top |
Polarbear |
Polarbear Super Spammer
Back to top |
bacon |
Posted: 12:32 - 04 Nov 2018 Post subject: |
As an electrical noob I followed Stinkwheels old post with wiring in a relay. I highly reccomend anyone interested in bike wiring start with his guide and installing a relay.
I invested a little bit of cash, not much maybe £30 in total, on a set of crimps, a pack of 5 relays, some different colours of 17A thin wall (black, red, green, think 10m of each), male/female 3.9mm bullet connectors, some double female bullets, spade connectors, piggy back spade connectors, m6 ring terminals etc.
All uninsulated, that's the key, your blue, red and yellow shit is useless here.
The uninsulated connectors have plastic covers, I use dielectric grease on my connections too. So they should be fairly resistant to water ingress and corrosion too.
Anyway I'm going off on a tangent, so far I think the Oxfords are doing the job well. Long term use will see how reliable and how accurate Kramdras comments are. |
Back to top |
mudcow007 |
mudcow007 World Chat Champion
Back to top |
natefz6 |
natefz6 Brolly Dolly
Posted: 20:50 - 04 Nov 2018 Post subject: |
I fitted mine today, the muffs arrived a couple of weeks ago so I think I should be all set for the winter now. I got the ones that were on offer from M&P for £40.
I fitted them with a relay, taking a feed from the tail light as it was the easiest wire to get to. I got it right first time too . They seem well enough made, I had to bash the control unit bracket about a bit in order to get it to fit but it all looks good and nothing looks too out of place.
I even managed to give the bike a treatment of XCP too so the bike should be feeling well loved. ____________________ "no I didn't steal it that's just the way I ride" |
Back to top |
There is a gap of 332 days between these two posts... |
hume |
hume Borekit Bruiser
Back to top |
MarJay |
Back to top |
kawakid |
kawakid World Chat Champion
Back to top |
hume |
Back to top |
hume |
Back to top |
grr666 |
grr666 Super Spammer
Back to top |
ThunderGuts |
Posted: 14:18 - 04 Oct 2019 Post subject: |
I had OEM on my Triumph; similar price I think. Yes, expensive, but they are essentially invisible - one tiny button, but uses the existing MFD to display settings so a much neater install than having an Oxford controller. ____________________ TG. |
Back to top |
SirFallalot |
SirFallalot Trackday Trickster
Back to top |
Hong Kong Phooey |
Back to top |
SirFallalot |
Posted: 08:18 - 06 Oct 2019 Post subject: |
Thanks, must have missed those, why did they have to be more expensive
Looking at my bars, anything slimmer would seem quite bendy ____________________
Lexmoto Valiant 125; 94 CB400; 96 CB750F2; 81 CB750 (restoring, lol not gonna happen); 2001 ZX9R(It's about to go :c); 2012 R1200R; 2015 R1200RS |
Back to top |
The last post was made 4 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
