Recommend me a cover?
BenR
PostPosted: 14:15 - 10 Nov 2018    Post subject: Recommend me a cover? Reply with quote
As per title I don't have a garage & recently bought what I deemed to be a mid range cover as it had a strap you can tie up underneath the bike to stop the wind from blowing it off. When going out this morning I got down stairs & found the strap had let go (only velcro) & the cover wrapped around one of the mirrors. Mad How hard is it to make a bike cover that does up properly underneath the bike with proper poppers or a better arrangement? Anyway any of you guys got any recommendations? Ta very muchly. Thumbs Up
talkToTheHat
PostPosted: 14:51 - 10 Nov 2018    Post subject: Reply with quote
You don't want metal fixings if you like your paint. Better covers use webbing straps and plastic clips. I tried buying a semi-fitted cover from the very special people known as Specialised and once they managed to get the order right I had a fitted cover that was right on a Suzuki marauder, a virago and a bandit and has survived for over 6 years now. Looks like they've withdrawn the dayglo pink they thought was red.
I dont use the cover in high winds though, doesn't protect from impact with ground and it's an utter bastard pickuping up a bike inside a fitted cover.
Bandit. does. everything.
M.C
PostPosted: 17:50 - 10 Nov 2018    Post subject: Reply with quote
Not a lot of help but the Lidl cover from a few years ago (2014 I think) was excellent, its always stayed on different bikes with no strapping. Like their gloves I've no idea why they changed the design Crying or Very sad
andys675
PostPosted: 18:02 - 10 Nov 2018    Post subject: Reply with quote
I hate to say it but the R&G cover or the oxford stormex I find to be the best
Howling Terror
PostPosted: 18:07 - 10 Nov 2018    Post subject: Reply with quote
Oxford Stormex.
They last years.
Suntan Sid
PostPosted: 18:18 - 10 Nov 2018    Post subject: Reply with quote
Another vote for Oxford Stormex.
Mine has finally given up the ghost, but it has served me well for 6 years!
chickenstrip
PostPosted: 18:25 - 10 Nov 2018    Post subject: Reply with quote
I'd say the Stormex too. There was a problem with them a while back though where the seam-seal tape would peel - don't know if they've sorted this yet.
I used to sell Held covers at one place I worked, which were popular and looked quite good quality, although I never used one myself.
notbike
Formerly known as
notabikeranymore
PostPosted: 18:57 - 10 Nov 2018    Post subject: Reply with quote
Stormex.
Wheezybiker
PostPosted: 20:35 - 10 Nov 2018    Post subject: Reply with quote
Oxford stormex here as well
Fantastic bit of kit
tom_e
PostPosted: 20:47 - 10 Nov 2018    Post subject: Reply with quote
The stormex is a great heavyweight cover but I find it a pain in the arse for daily use on and off the bike due to its weight and the strength of the elastic used round the bottom generally catching on pegs, crash bungs and pinging up around the plate while trying to get it over the front end also any muck picked up around the bottom then gets dragged over your paint work.
The aquatex is lighter weight but still waterproof enough and stays put, much easier getting it on and off the bike as well.
bacon
PostPosted: 23:01 - 10 Nov 2018    Post subject: Reply with quote
I've had 2 aquatex covers, the first blew away in heavy wind (it's not elasticated, so it's a pain in the ass to do up the strap underneath especially if it is windy), the second which I still have has turned brittle and has split in several places. I use it on my Deauville, my shed is a bit crammed with two bikes so I keep one outside.
I was considering the Oxford stormtex or the R&G next, I had an R&G years back and it lasted fairly well. But everyone here seems to bum the stormtex so I think I'll try one of those.
M.C
PostPosted: 00:56 - 11 Nov 2018    Post subject: Reply with quote
It's the price that puts me off. That's like 5 Lidl covers Smile
BenR
Thanks for the suggestions guys. There seems to be a dramatic difference in prices on eBay also what size should I get it's for my wolf which although big for a 125 is smaller than say a bandit. Thumbs Up
bacon
PostPosted: 09:52 - 11 Nov 2018    Post subject: Reply with quote
Well my Aquatex covers are mediums. In my old flat I had an undercover parking space, so I used them more as dust covers.
The bikes they fit nicely were:
Street triple
Zrx1200R
Zx7r
They fit very tight over the deauville and I've torn it since it's become brittle. So for that when I buy the Oxford stormtex cover I'd need a large.
So for your 125 I'd get a medium, can always pull the strap tight, plus then it's useful for your next bike.
If you get the R&G, mine was for a ZX7r that spent 2 years outside. The cover was the sport bike cover, it went mouldy in the end as water would pool on the top. If I got the r and g now. I'd go for the adventure sized one for the deauville. For you I'd stick to the sport bike cover.
Johanna
PostPosted: 09:31 - 12 Nov 2018    Post subject: Reply with quote
There is also Rainex which is like a lighter Stormex. My other half has Rainex and I have Stormex. Both have the same elasticated cuff. I find the easiest way to put it on is to find one of the holes at the back and loop it over an indicator. Then do the front of the bike, pull the cover down over the back and then sort out all the bits that have caught on the sides. Having the cover attached at the back stops all the cursing as the cover pings forward and falls off the side of the bike.
woo
PostPosted: 12:14 - 12 Nov 2018    Post subject: Reply with quote
i used to use a £7.99 cover from ebay and use a bungee strap around the seat and under the bike to hold the cover down.
the covers from the motorcycle bay i used to use kept getting stolen so had to also resort to using a cheap bicycle wire lock also to stop the thefts
the cheap cover worked and did the job and at the price of a mcdonalds signature burger meal i was happy that it lasted more than 12 months
Elen sila lummen omentielvo!
Motorhate
PostPosted: 15:29 - 26 Nov 2018    Post subject: Reply with quote
Yeah that happened to mine. Proper pissed me off as they're not cheap.
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
owl
PostPosted: 16:33 - 26 Nov 2018    Post subject: Reply with quote
Happening to mine now, after 2.5 years Confused
Observation is the greatest source of wisdom.
bacon
PostPosted: 22:06 - 26 Nov 2018    Post subject: Reply with quote
The day after I order a stormex you all mention them being shite Laughing
Motorhate
PostPosted: 09:54 - 27 Nov 2018    Post subject: Reply with quote
I had mine for a couple of years before the seams started peeling. It was on a bike I'd left out all summer of this year so I'm assuming that the hot weather may have done something to the adhesive on the seams. Can't be certain though.
The last post was made 5 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.98 - MySQL Queries: 17 - Page Size: 111.39 Kb
