Steering head: taper rollers, press or mix and ??match??
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
bikenut
PostPosted: 11:50 - 03 Nov 2018    Post subject: bearing Reply with quote
Yes, but htf are you gunna get the old cone off and the new one on, or are you just gunna replace the bottom yoke complete !
Take that to its logical conclusion, get a new bike when the oil needs changing ?
nuts about bikes
PostPosted: 12:04 - 03 Nov 2018    Post subject: Reply with quote
He plans to leave the cone and put a new race over it... Which I think is a mistake. You don't know how much wear is on the old race, you don't know the tolerances used by the different bearing manufacturers and you don't know what crappy chinese fab shop knocked up the parts.
It is theoretically possible to interchange bearing parts:
Arrow If they are the same make
Arrow If they are the same model
Arrow If they are both brand new
Arrow If they aren't chinese copies.
That's a lot of ifs.
bikenut
PostPosted: 11:16 - 05 Nov 2018    Post subject: bearing Reply with quote
Yep, he shows talent as he says he has changed a main bearing on a 50cc crank, and/or buggered a puller in the process.........
Similar task.........did he get a new/s/h crank also ??
nuts about bikes
Riejufixing
PostPosted: 10:55 - 26 Nov 2018    Post subject: Reply with quote
Well that worked out OK. Components interchangeable. Cleaned, greased, refitted.
bikenut
PostPosted: 11:07 - 26 Nov 2018    Post subject: races Reply with quote
Same protrution of the steering tube and enough upper thread available, some pics would help.
nuts about bikes
Riejufixing
PostPosted: 11:13 - 26 Nov 2018    Post subject: Reply with quote
"Components interchangeable. Cleaned, greased, refitted." Statement, not question.
bikenut
PostPosted: 11:21 - 26 Nov 2018    Post subject: Reply with quote
so a pic will say it all then !
nuts about bikes
PostPosted: 11:24 - 26 Nov 2018    Post subject: Reply with quote
That's a bit of a pratty response considering people tried to help you and you ignored their advice.
Riejufixing
PostPosted: 12:34 - 26 Nov 2018    Post subject: Reply with quote
Sorry, but refer to my OP about the question, which was not answered, and subsequent posts about interchangability of bearing components. If that's no good, e-mail SKF (a bearing manufacturer) for further advice.
MCN
PostPosted: 12:40 - 26 Nov 2018    Post subject: Reply with quote
TLDR.
Redundancy max+ to fit a new part of a bearing with an old part.
If you cannot replace all of the bearing system then leave things as they are.
The point with roller bearings is that a lot of wear is invisible to a naked eye. The wear takes place under the surface. The surface of a roller bearing flexes in service and it it this part that most commonly fails. Pitted surfaces one notices in 'failed bearings is usually due to not being replaced soon enough.
They should be replaced long before they become pitted.
That can be determined by OEM service guides or hard won experience.
Riejufixing
PostPosted: 13:01 - 26 Nov 2018    Post subject: Reply with quote
If sir would like a nice fairly exhaustive article about wear on bearings, I was about to pop this into the conversation (it's Timken's):
https://www.timken.com/pdf/5892_Bearing%20Damage%20Analysis%20Brochure.pdf
cb1rocket
PostPosted: 13:30 - 26 Nov 2018    Post subject: Reply with quote
still bad practice, that's like putting a new chain on worn sprockets. Rolling Eyes
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
PostPosted: 13:35 - 26 Nov 2018    Post subject: Reply with quote
Agreed.
Riejufixing
PostPosted: 13:44 - 26 Nov 2018    Post subject: Reply with quote
So tell Skef & others about it. This is becoming like discussing Brexit with that other fellow. I'm out.
PostPosted: 13:49 - 26 Nov 2018    Post subject: Reply with quote
Well, you might happen to be the only one who disagrees with us...
Suntan Sid
PostPosted: 14:46 - 26 Nov 2018    Post subject: Reply with quote
Dremelling the thing off is not difficult!
Copied this from my rebuild thread:-
I needed to get the bottom bearing race off the steering stem.
I haven't got any workshop facilities at the moment, just a, knackered, shed and a workmate type thingy, which means brute force, ignorance and a large hammer weren't going to solve my problem.
I decided to get the Dremel out!
It was a lot easier than I thought it was going to be, took less than 10 mins.
I made a diagonal cut into the race, just deep enough to get a flat blade screwdriver into the slot.
A halfhearted twist of the screw driver and the bearing race cracked and came off them stem with finger pressure, didn't mark the stem at all, result!
Sorry about the photo but you get the idea.
https://i645.photobucket.com/albums/uu172/Troodos-Pool-Guy/XL125RC/XL125RC10_zps57c31992.jpg~original
PostPosted: 14:53 - 26 Nov 2018    Post subject: Reply with quote
That's what I did with mine, I bought a battery powered dremel specifically for that purpose.
The last post was made 5 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 17 - Page Size: 101.03 Kb
