YBR 125 Washer(s)
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
Huarachedevil
PostPosted: 14:14 - 09 Dec 2018    Post subject: Reply with quote
Thanks for all the advice guys. In the end I bought the magnetic bolt and some washers from Fowlers. That way if I overtighten and crush one, I can have four goes at it 😂
PostPosted: 18:39 - 09 Dec 2018    Post subject: Reply with quote
The washers are meant to crush.
If you over-tighten the bolt then it will damage the thread in the sump and you'll either have to fit a helicoil or replace the sump.
Huarachedevil
PostPosted: 18:42 - 09 Dec 2018    Post subject: Reply with quote
Ste wrote:
The washer are meant to crush.
Ugh.
Do you use a torque wrench for yours or tighten it just so, by feel?
bikenut
PostPosted: 17:17 - 10 Dec 2018    Post subject: Reply with quote
Use the torque wrench, you know the lbs/ft or nm yes?? post a pic of the wrench you purchased.
Are you gunna remove the clutch cover to inspect the course filter screen, if so post a pic of whats under the cover. Also get a new gasket. If the clucth cover is coming off you can flush out the sump floor when the cover is off.
nuts about bikes
PostPosted: 18:14 - 10 Dec 2018    Post subject: Reply with quote
I'm too lazy to use a torque wrench. Razz
If you've got one then you should use it, at least until you've got an idea of how tight sump bolts need to be.
Courier265
PostPosted: 22:12 - 10 Dec 2018    Post subject: Reply with quote
Ugh.
You shouldn't need a torque wrench on a sump nut, a decent ring spanner and tightened by feel does the job.
In fact you shouldn't really need a torque wrench on a motorcycle except for the head race bearings nut.
bikenut
PostPosted: 10:50 - 11 Dec 2018    Post subject: Reply with quote
You need a torque wrench unless you have 30 years experience, even then you would use a torque wrench.
Are the advocates of torque wrench non use offering to pay for stripped thread repairs I wonder ?
nuts about bikes
talkToTheHat
PostPosted: 13:35 - 11 Dec 2018    Post subject: Reply with quote
Probably late to the party, but just ebay copper washers, M12 bolt? M12 copper washers. Simple. Cheap and disposible.
https://www.ebay.co.uk/itm/COPPER-SEALING-WASHER-M6-M8-M10-M12-M14-M16-M18-M20-M22/202269555218
Bandit. does. everything.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:42 - 11 Dec 2018    Post subject: Reply with quote
I'll remind you of this comment the next time you borrow mine.
Sprint ST 1050
The last post was made 5 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 17 - Page Size: 63 Kb
