Help non mechanic zxr6 non start
supermatrix
PostPosted: 17:27 - 21 Mar 2005    Post subject: Help non mechanic zxr6 non start Reply with quote
Hi All
ok the bike ZX6R 1995
Bike was running although a slight jumping at low revs (could go to 3k revs with little power and then would suddenly kick in) this was a week ago. now bike will not start at all, Kill switch is in run, ignition on , bike is in neutral, fuel is ok and on, I have sparks to all plugs, the fuel pump does kick out fuel (dont know how fast this should flow its not like a full flow like when you take a pipe of the tank) but there is no noise from the pump when I turn the ignition on ?? I have tried to put fuel directly into each carb but the fuel just splatter out, the battery is ok but to be sure I had it setup on a jump lead.
Can anyone assist??
PostPosted: 19:12 - 21 Mar 2005    Post subject: Re: Help non mechanic zxr6 non start Reply with quote
Try draining the carbs (should be screws on the bottom of them to drain) and use a fresh fuel supply.
This can be a particular problem if it hasn't been run for a while and some water has collected in the tank from condensation.
When I had this on my zx9 it would not run at all at low revs, but was ok if I revved it a lot.
supermatrix
PostPosted: 21:55 - 21 Mar 2005    Post subject: Reply with quote
Cheer G I will try that tommorow the bike had been standing for about 3 mnths before I purchased, but have done about 80 miles since.
I will try and then post results back.
Regards
supermatrix
PostPosted: 15:25 - 29 Mar 2005    Post subject: Reply with quote
Thankyou G
This I done at the weekend and is now starting
Thanks
bish777
PostPosted: 19:21 - 29 Mar 2005    Post subject: Reply with quote
I have a real condensation problem due to my pod filters and having no garage lol
I found draping a piece of tarpaulin over the bike with a towel underneath stops the worst of it.
GSXR1100J
The last post was made 21 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.04 - MySQL Queries: 16 - Page Size: 45.19 Kb
