| OmegaA |
 OmegaA Two Stroke Sniffer
| RAYK47 |
 RAYK47 Nitrous Nuisance
| redeem ouzzer |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
| M.C |
 M.C Super Spammer
| SDFarsight |
 SDFarsight Nova Slayer
| MarJay |
 MarJay But it's British!
| M.C |
 M.C Super Spammer
| P.addy |
 P.addy Red Rocket
| M.C |
 M.C Super Spammer
 Posted: 16:47 - 26 Dec 2018 Post subject: |
You don't need to see the license plate, you only need to see what happened. Having no camera wouldn't get you the license plate either. ____________________ a.k.a 'Geri'
| M.C |
 M.C Super Spammer
| MarJay |
| M.C |
 M.C Super Spammer
 Posted: 01:40 - 27 Dec 2018 Post subject: |
I give up, I actually have footage from my 720 and 1080 to show the difference but I can't be arsed with this pointless debate. |
| Tierbirdy |
 Tierbirdy Crazy Courier
| inline4 |
 inline4 Nova Slayer
| AdamEf |
 AdamEf Nova Slayer
 Posted: 13:47 - 27 Dec 2018 Post subject: |
| SDFarsight |
| pepperami |
 pepperami Super Spammer
 Posted: 14:31 - 27 Dec 2018 Post subject: |
Having a camera about your person or on your bike make you a coward?
Ensuring you can prove that an incident wasn’t your fault make you a coward?
How does that work then?
I try to ride defensively and be observant, however being a human being and having to be in the world of other humans, I can’t rely on their behaviour.
So to prove I am a man and not a coward, I must dispense with the ability to prove that I have been wronged.?
Nah! I’ll stick to having a camera  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| M.C |
 M.C Super Spammer
 Posted: 16:39 - 27 Dec 2018 Post subject: |
Can't read the plate what camera's that then?  |
| Freddyfruitba... |
| M.C |
 M.C Super Spammer
| Teflon-Mike |
 Posted: 16:27 - 28 Dec 2018 Post subject: |
Winning the argument who might have been to blame is something of a punic victory, especially if you iz dead at the time..... Prevention is far better than a presumed cure....
And one DOES wonder how many folk drive or ride like idiots 'cos camera... means they 'cant' be in the wrong... camera proo-ooves it...... bang! See!!!! It was MY right of way,,, right up the pearly stairs!
Loads of stuff rather more important in the list of priorities to dodge an accident, or try soften the blow when one happens, than an electric widget that 'may' help show who was less in the wrong to be there, after the event, and certainly far more important than whether that widget happened to have web-cam res or 4k vidie cap-ability.... it still needs to be pointing in the right direction, and not wobbling around like an alziemer sufferers mug of tea!
Slightly more practically...... battery life is only half the problem; you need the memory capacity to at least equal if not exceed the battery life in order to capture all it might record.... higher resolution you aim for, more memory you need, and as hintimated, utterly wasted if the picture is wobbling around all over the place, and or camera not pointing at anything 'useful'.....
A wide angle lens, doesn't oft help here, and the topic starts to get a lot deeper. A very wide angle lens, distorts the perspective, far subjects appear very very far, near subjects a lot nearer, in between as the range changes, it appears to change an awful lot faster... so the lens distorts perceptions of both speed and distance.. whilst the wider the lens, to get most margin around where the cameras pointing and hopefuly get that critical angle in shot..... so the relative resolution falls, the subject a much smaller proportion of the whole frame.....
Eg.... you want to prove that it was D875OEP that hit you.... camera not only has to 'see' that bit of the subject that includes the number plate, it has to be clear enough to read, and see the rest of the wreck at the same time..... So its NOT merely the pixie count the camera might generate.... those pixies have to be in the right place at the right time, and not jumping up and down all over exited like.....
So how far do you go?
Even TV companies with the budget to buy really good kit struggle with on-board footage, whether on an F1 car or a chap in a game show..... So how much are you prepared to pay and what's the acceptable quality level, and IS a 'better' camera an awfully large part of the equation, when the mounting system is as if not more important, and you still have the matter of battery and memory capacity...
A-N-D.... what are you trying to prove, WILL this be like a flat fire extinguisher most of the time, doing nothing, but give you some false sense of security that IF it comes to, you are 'prepared'.... oh the CO2 cartridge seems to be flat... there's no foam coming out.... oooh.... its about to get a BIT hot round here...... well, that was a waste of time..... maybe I should have been a bit more careful with the lighter-fluid when the barbeque wouldn't light.......
There's no one size fits all, over the counter answer to the question, A-N-D the very fact that its being asked begs an awful lot of other questions, pulling the priorities back to check that all the basics have been tackled first, which PROBABLY make a ride-cam pretty much redundant if they have been.....
But what the heck... what would You-Tube compositors have to splice together if every-one was a b-i-t sensible on this subject......
Do or dont, its your call, but, in the grander scheme, I think that there's rather a lot more important stuff to be worried about than the resolution of a tele-tubby cam, and whether its best powered of its internal battery or a mains supply!!!! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| M.C |
 M.C Super Spammer
The last post was made 7 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
