What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 326, 327, 328 ... 407, 408, 409  Next
betone
PostPosted: 00:59 - 18 Dec 2018    Post subject: Reply with quote
Changed out the handle bar grips for the OEM ones because the aftermarket ones I got weren’t as good.
thx1138
PostPosted: 01:13 - 18 Dec 2018    Post subject: Reply with quote
gave it a visual check before I ran it for the first time in a month
clouds of 2 stroke smoke everywhere in the cold as it warmed up
need to adjust and lube the chain, and top the 2T oil up, will probably do that at Twixtmas, won't bother with an oil change till Jan
rode it about town, and gave it a quick blast down the bypass
ThatDippyTwat
PostPosted: 10:49 - 23 Dec 2018    Post subject: Reply with quote
VFR -
Oiled chain. Rode it to the coast, on a decently sunny, if cold, day out.
Ordered steel and friction plates for clutch (113K, doubt steel plates have been changed), and springs, rollers etc for starter clutch service. Also got some Oil, filter, clutch cover gasket. Would be silly not to while I've got her open.
Work rat -
Failed dismally to find the spare copper exhaust gasket. Ordered more.
Oiled chain. Rode it around until she was up to temp, locked it back up.
FretGrinder
PostPosted: 11:36 - 23 Dec 2018    Post subject: Reply with quote
Removed the screens and mirrors as the covers cover more of the bikes without them on.
Topped up the fuel tanks.
Chucked on the covers, then a tarpaulin and bungee straps.
Said goodbye till the spring.
Yamaha MT-09
ಠ_ಠ
Nobby the Bastard
Harley Gaydar
PostPosted: 14:51 - 23 Dec 2018    Post subject: Reply with quote
Found and fixed the break in the wiring that was stopping the front brake switch working the brake light.
Sprint ST 1050
Wheezybiker
PostPosted: 14:45 - 27 Dec 2018    Post subject: Reply with quote
Cleaned it
Scrubbed and lubed chain
Checked all lights and horn etc
Quick ride round the block
recman
PostPosted: 22:38 - 27 Dec 2018    Post subject: Reply with quote
Spent half an hour trying to work out how to remove the battery for charging without the alarm having a breakdown.
ThatDippyTwat
PostPosted: 18:18 - 28 Dec 2018    Post subject: Reply with quote
VFR:-
Whipped out clutch plates, friction plates were really badly worn. Put new steel and friction plates in. Changed oil and filter while I was at it. Still need to bleed it, by all accounts they are a twunt to bleed, and didn't work the way I've bled any other bikes after a clutch plate change.
Adjusted chain tension and lubed it.
Work rat:-
Chain tension and lube.
RAYK47
PostPosted: 19:07 - 28 Dec 2018    Post subject: Reply with quote
Installed Oxford heated grips. All good just need a proper test run
wr6133
PostPosted: 13:11 - 30 Dec 2018    Post subject: Reply with quote
Finally started stripping down the GSXR. Plan is total refresh and back on the road for late April.
https://farm5.staticflickr.com/4814/45612088855_dac3d955e8_h.jpg
https://farm8.staticflickr.com/7864/46473397592_aa1797632a_h.jpg
[url=https://flic.kr/p/2cuzTa4]https://farm5.staticflickr.com/4896/45612089665_2a43147709_h.jpg
Found out why cheap Taobao fairing bolts are so cheap
[url=https://flic.kr/p/2cuzSBk]https://farm8.staticflickr.com/7819/45612087825_ca302b695b_h.jpg
Pigeon
PostPosted: 01:22 - 31 Dec 2018    Post subject: Reply with quote
Got further with rebuilding shock (with heavier oil and spring)
Trusty PVC fork seal driver came in handy.
https://i.imgur.com/Ugww5p7.jpg
Had to drill into circlip recess, just couldn't get it out otherwise (couple of hours with various picks).
Also, online guides said to use a socket to drift the bladder lower.
I knew this was a bad idea and did it anyway. Rolling Eyes
Result, one fugly looking bladder cap.
As it turned out (found as part of re-assembly) that PVC piping was fine to use as a drift.
https://i.imgur.com/yXUsSr8.jpg
https://i.imgur.com/qhC0kzy.jpg
https://i.imgur.com/w2wPOjN.jpg
Just need to source a heavier spring. Have contacted a few companies, but xmas/new year etc
Also need to get local shop to re-pressure with Nitrogen.
Sister Sledge
PostPosted: 17:12 - 01 Jan 2019    Post subject: Reply with quote
Shortened the wires for the rear indicators and rear light.
It was a mad rats nest when the seat was lifted - cables far too long and curled into reels!
Managed to break an indicator bulb so not everything was successful.
CCM 404 DS
PostPosted: 23:29 - 01 Jan 2019    Post subject: Reply with quote
Changed the oil and filter on the VFR, and generally inspected, and ACF50'd it. Found one of the large cap head bolts from the lower fairing panel was missing, so fashioned something similar from bits I had lying around.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Pigeon
PostPosted: 23:38 - 01 Jan 2019    Post subject: Reply with quote
XR250 oil change.
ThatDippyTwat
PostPosted: 21:05 - 02 Jan 2019    Post subject: Reply with quote
SpeedyFastners do these. I have a few I need to order. Pretty sure they're the same fastner across the 750 and 800's.
Sister Sledge
PostPosted: 10:32 - 07 Jan 2019    Post subject: Reply with quote
Done some 'Loctite' fixes/checks on the CCM - DRZ400 engine.
Drained oil, replaced filter, unclipped half the wiring harness and released the stator wire connector. Unbolted the starter motor and then unbolted the LH engine casing. Drained even more oil.
Checked internals and put the thing back together. Replaced with new engine oil, started it.
The bike has had 4 owners since new and the loctite fixes are well known and absolutely needed - I just didn't know if it had been done to my bike. It has but that's OK because I can now sleep at night.
Whoever did the fixes did a good job of them but were careless when reassembling the engine because they trapped a piece of conifer in the gasket..
CCM 404 DS
Hong Kong Phooey
PostPosted: 12:57 - 07 Jan 2019    Post subject: Reply with quote
That would really give me the needle.
Sister Sledge
PostPosted: 13:56 - 07 Jan 2019    Post subject: Reply with quote
I just twigged what you meant there.
CCM 404 DS
Hong Kong Phooey
PostPosted: 21:50 - 07 Jan 2019    Post subject: Reply with quote
Probably needs a root and branch overhaul
pepperami
PostPosted: 23:23 - 07 Jan 2019    Post subject: Reply with quote
Took the mighty little Hyosung for a service and an MOT today.
I know everything is good on the bike .
The bike is faired and has no centre stand , also I have no space to work on a bike, so it was easier to let the shop do the work.
You need to take half the fairing off to change the plugs Evil or Very Mad
Anyhow, it passed with no advisory’s Smile Thumbs Up
kramdra
PostPosted: 03:18 - 10 Jan 2019    Post subject: Reply with quote
Wired up glove heated liners, fit them inside the Spada Enforcers and a quick test. Test was good, very warm, 5w per glove at only half powar.
Sister Sledge
PostPosted: 08:45 - 10 Jan 2019    Post subject: Reply with quote
Replaced a leaky O-ring.
CCM 404 DS
BTTD
PostPosted: 10:07 - 10 Jan 2019    Post subject: Reply with quote
Checked tyre pressures and rode it into work. JESUS it's cold.
Heated jacket and gloves, barmuffs, but still got frozen feet.
ride_to_die
PostPosted: 15:42 - 10 Jan 2019    Post subject: Reply with quote
Lubed chain, acf 50'd few bits.
I'm not here for a long time, I'm here for a good time.
thx1138
PostPosted: 17:49 - 10 Jan 2019    Post subject: Reply with quote
Crashed it. Rolling Eyes The wife's van van 200
Just outside Chinnor on the b4009, low speed off on mud at side of road just as I was pulling over tried to save it with stamp of foot, but i slipped on mud leg twisted round and wirh leg at awkward angle was pinned under bike, and was struggling to wiggle free.
Joe public to the rescue...
I kept yelling it's fine, I'm fine etc was worried some over enthusiastic passers by would lift it off me and drop it on its other side due to panic
Apart from sticky animal shitty farm mud over me and the bike , just got a slightly bent lever and scratched mirror and indicator, rode it another 50 miles home.
Not worthy of a spill thread post.
The last post was made 5 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 327 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.46 - MySQL Queries: 17 - Page Size: 131.4 Kb
