Author |
stinkwheel |
Back to top |
Fizzer Thou |
Posted: 15:28 - 18 Feb 2019 Post subject: |
I have a Honda CBR1000 clutch master cylinder on my FJ1200 and where the unit points upwards then,as others have suggested,air gets trapped.
https://i1073.photobucket.com/albums/w384/Rhencullen5/FJ1200/20160607_205644_zpss8102caj.jpg~original
Unless you have a banjo bolt with a bleed nipple in the end,then I found the easiest way to bleed the master cylinder without touching the slave cylinder was to arrange the left handlebar to point downwards slightly.Then,with the cap off the master cylinder just pull the clutch lever in just a little and then let it go slowly.If you see lots of tiny air bubbles bleed to the surface,keep doing this until no more appear.
This works just as well on the brakes ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
Back to top |
Polarbear |
Polarbear Super Spammer
Back to top |
ThatDippyTwat |
Back to top |
jimspeed |
jimspeed World Chat Champion
Back to top |
Enduro Numpty |
Enduro Numpty Could Be A Chat Bot
Back to top |
Enduro Numpty |
Back to top |
Grubscrew |
Grubscrew Scooby Slapper
Back to top |
ThatDippyTwat |
Back to top |
stinkwheel |
Posted: 21:44 - 19 Feb 2019 Post subject: |
ThatDippyTwat wrote: |
Something is wrong. It's very, very difficult to paddle the bike with the lever back to the bars. I need to really push to get it to move at all. Yeah, it's a lump oif a bike, but it's never been that difficult to move it about in 1st with the clutch in. For that reason, I don't fancy knocking her into gear with the motor running, for obvious reasons. I'll see if I can weight the front down on the centrestand enough to feel happy giving it a go.
No, sit on the bike with it on both wheels, Hold the front brake on and put it in gear. It's not going to wheely across the yard or do a rolling burnout at idle even if the clutch isn't disengaging at all. It'll stall.
If you're super paranoid, roll it so the front wheel is against a wall. But still be on the bike in case you drop it.
Holy crap, you should have seen the welly I used to give my GPZ500 to free off a stuck clutch... ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
ThatDippyTwat |
Back to top |
Meatybeaty |
Meatybeaty World Chat Champion
Posted: 07:41 - 20 Feb 2019 Post subject: |
Hope that bleed banjo comes sooner than hoped, it does get frustrating when something like this happens, but keep the faith |
Back to top |
stinkwheel |
Posted: 20:13 - 20 Feb 2019 Post subject: |
ThatDippyTwat wrote: | stinkwheel wrote: | If you're super paranoid, roll it so the front wheel is against a wall. But still be on the bike in case you drop it. |
Emphasis mine.
Not super paranoid, but she's a heavy old bird that I've had to pick up once, and I don't fancy repeating it, not to mention fairings are expensive bastards. |
The point being, if you're on the bike, you won't drop it. Ever put it in gear with the stand down and tried to ride away and the engine dies as soon as you let the clutch out a bit? That's what it'll feel like if the clutch is stuck.
If you fuck about trying to weigh the front end down so the rear is off the ground with it sat on the mainstand and start fucking about with the rear whel spinning, THAT is when you will drop it.
Plus I think your clutch plates are slightly stuck together so it probably will have a fair clunk/stall when you put it in gear. Holding the rear wheel stationary is more likely to shock them loose than just allowing it to spin the rear wheel in the air. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
ThatDippyTwat |
Back to top |
andym |
andym World Chat Champion
Back to top |
Tankie |
Tankie Crazy Courier
Back to top |
stinkwheel |
Posted: 16:02 - 21 Feb 2019 Post subject: |
I will repeat that I don't think it needs further bleeding. There is adequate seperation of the clutch plates showing on that animated image earlier.
We are chasing a non-problem and I will continue to consider this to be the case until proven otherwise by the OP getting on his bike, starting it and putting it into gear. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Tankie |
Posted: 16:13 - 21 Feb 2019 Post subject: |
Your powers of remote diagnostics must be good ____________________ Always learning, everyday is a school day |
Back to top |
ThatDippyTwat |
Back to top |
ThatDippyTwat |
Back to top |
Riejufixing |
Back to top |
ThatDippyTwat |
Back to top |
Riejufixing |
Back to top |
ThatDippyTwat |
Back to top |
The last post was made 5 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
