| St George |
 St George Borekit Bruiser
| virus |
 virus World Chat Champion
 Posted: 15:55 - 06 Mar 2019 Post subject: |
its unlikley to be anything in the slide area thats causing it, Given how simple it is to take off and back on, I'd take the bowl off, jets out to clean including taking the float valve seat out and making sure thats clean then re assemble and it'l no doubt run again. ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Meatybeaty |
 Meatybeaty World Chat Champion
| Meatybeaty |
| St George |
| Meatybeaty |
| virus |
 Posted: 17:28 - 06 Mar 2019 Post subject: |
its this one. same as the xl250 and xl500
https://www.dansmc.com/carbs/Japanese_Carbs/Keihin_HonXR_XL250_500.jpg
Remove everything in the the float bowl, clean it and put it back in. do not fuck with the accelerator pump linkage unless you absolutely have to, they are a fiddly bastard to put back together without loosing the spring or tearing the probably worn out old diaphram.
Cheers
John ____________________ own: 81 xs1100g...
| St George |
 Posted: 17:30 - 06 Mar 2019 Post subject: |
Virus, that is the baby. Just found a Youtube rebuild on that one, soaking the body overnight in brake cleaner. Not as bad as they look SO FAR  |
| virus |
 Posted: 17:32 - 06 Mar 2019 Post subject: |
I think my 250rs is the only bike I regret getting rid of, so easy to work on and fun to throw around.  ____________________ own: 81 xs1100g...
| St George |
| St George |
| Robby |
 Robby Dirty Old Man
 Posted: 20:17 - 06 Mar 2019 Post subject: |
I know these bikes inside out, in fact I was working on my project one today.
It's a fairly simple slide carb with an accelerator pump. All parts, including the pumper diaphragm, are available from NRP in Norfolk.
If it has been sitting that long, start by getting a rebuild kit, costs about 20 quid and saves a lot of cocking around. You will need to open up the accelerator pump chamber and clean it out. Expect dusty alloy corrosion on one side of the cylinder, and ancient petrol/jelly/varnish on the other side.
Don't loose the tiny O ring on the pump shaft between carb body and float bowl.
Also remove the mixture screw and blow carb cleaner through its hole. Proper screw setting is in the Haynes, about 2 turns out.
Once its all clean and back together, easiest way to start it is two turns of the throttle (to pump in some neat fuel), full choke, give it a kick. |
| St George |
| St George |
| Robby |
 Robby Dirty Old Man
| St George |
 Posted: 17:45 - 07 Mar 2019 Post subject: |
All looks fine in the footrest area, it has been in a dry garage since 2005, quite time warp. Even the chrome on the forks and headlight is good. slight surface rust on swinging arm. Slight rust on spokes which comes off with a Brillo Pad. Thanks for tips.  |
The last post was made 6 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
