Author |
kramdra |
kramdra World Chat Champion
Posted: 13:59 - 09 Mar 2019 Post subject: Engine flush? high milage |
Cbr6 is upto 108k and due an oil change. She was ran for an extended time with the oil level at or slightly below the minimum, which may have cooked it a bit so oil change is slightly early this year. There us some visible oil staining inside the engine. She doesnt burn, but fresh oil goes back very quick.
I know engine flush is generally bad, as opposed to more frequent changes and making sure the level is good.. thought it was worth asking, should I use it? |
Back to top |
stinkwheel |
Posted: 14:45 - 09 Mar 2019 Post subject: |
It's not like older engines which relied on sludging to remove muck from an engine. It would build up in the sump and your engine flush would help remove it.
You have a paper element oil filter. Any nasty particulates are carried in suspension and removed by the filter in a continuous process.
If I was going to "flush" a modern engine, I'd do it with high detergent engine oil (maybe one designed for diesels) and a short-interval filter change.
However, are you fixing a problem that doesn't exist? The black is carbon deposits but the particle size will be smaller than the filter.
Personally, the most I would do is a short interval oil change unless there was convincing evidence there was a problem causing a high level of sooting (like knackered valve stem oil seals). Then I'd fix the problem.... Or actually, on a 100K plus bike I'd probably ignore it until it became impossible to ignore then swap the engine/bike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
RhynoCZ |
RhynoCZ Super Spammer
Posted: 15:24 - 09 Mar 2019 Post subject: |
A flush should not harm the engine and it's fairly cheap. Depending on your method.
At 108k miles, I'd do the compression test and check the air/fuel mixture. The ZX7R, that I owned, had worn piston rings (oil consumption was negligible) and for some reason it ran rich in low revs (someone messed up the ram air intake system and I could never fix it). Everytime I changed the oil, it got black in a matter of hours.
Anyway, the engine ran smooth, there was a plenty of power and I did not bother doing anything to it, other than basic maintenance.
A friend of mine has a '98 Fireblade with 75k miles on it and the oil he drains from it, 8k miles intervals, is always as clean as new. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Back to top |
F18 |
F18 Renault 5 Driver
Back to top |
stevo as b4 |
Back to top |
ThatDippyTwat |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
ZRX61 |
ZRX61 Victor Meldrew
Back to top |
stinkwheel |
Back to top |
Bhud |
Bhud World Chat Champion
Back to top |
The last post was made 5 years, 37 days ago. Instead of replying here, would creating a new thread be more useful? |
