Triumph 1960's 650 Unit engine into 500 Daytona Frame.
St George
PostPosted: 19:01 - 18 Mar 2019    Post subject: Triumph 1960's 650 Unit engine into 500 Daytona Frame. Reply with quote
Will the 650 unit motor fit into a 500 Triumph Daytona type frame, they look very similar. Thinking of building a Trackmaster replica , thanks.
steve the grease
PostPosted: 21:22 - 18 Mar 2019    Post subject: Re: Triumph 1960's 650 Unit engine into 500 Daytona Frame. Reply with quote
I think you will struggle, the 650 engine is much larger than the very compact 500. Longer and taller, the 650 crankcase also has a large cast nose section sticking out at the front, which the 500 does not.
The popular conversions were a Triumph engine into a Norton frame or a Beezer frame. Tape measure time really , but I have never seen a 650> 500 conversion, the 500 is a physically much smaller and lighter bike. You would think that as so many Triumph engines were fitted in other frames (and there is a reason for this) that there would be loads of Triumph frames without engines lying around.
St George
PostPosted: 13:19 - 19 Mar 2019    Post subject: Reply with quote
Thanks Steve, will stick with the 500, they are a good motor in any case.
Regards.
The last post was made 5 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 17 - Page Size: 36.76 Kb
