Busby Derestricted Danger
Posted: 01:23 - 22 Mar 2019 Post subject: Problem with the Kawa GPZ 600 r 1987. I have a clicking/clac |
Found the culprit, The sprocket bearing was totally wasted! Floating around the race like a plastic bottle in the sea! I will change all three tomorrow!
Problem with the Kawa GPZ 600 r 1987. I have a clicking/clacking coming from somewhere near, either the front chain sprocket or rear wheel!
But definitely chain related, as the noise is there when free wheeling with engine off!
At first I thought the chain was to tight, so I released the chain a little but its still noisy and clacking away, not a constant clack/ click almost as some bearing when reaching a revolution has a problem with a roller, if that makes sense?
The chain and both sprockets are new as the noise was the reason I changed them!!
Ive checked the front sprocket for tightness and the rear sprocket bolts all is ok with both!
Any thoughts out there? I hope its a simple fix as performance dosen't seem to be affected.
Bhud World Chat Champion
