Mis firing help Please.
Ammoman
PostPosted: 18:26 - 07 Apr 2019    Post subject: Mis firing help Please. Reply with quote
The wife's 2012 Yamaha Fazer8 has been unused for 9 months in the Garage. Apart from starting it every couple of months it ain't moved.
It now Mis fires and splutters when below 2.5k revs, over that it runs perfect. Fresh fuel and a 40 mile blast and still the same. Question Question
2013 ZZR1400 & Honda CG125 1986..
MCN
PostPosted: 19:37 - 07 Apr 2019    Post subject: Reply with quote
HT.
Coils/Coil, Lead/Leads.
Maybe not enough current at low RPM to drive the ignition.
Battery leads and battery condition too.
9 mths damp exposure. if carbon leads the moistuere creeps in.
Try skooting a load of WD-Fuckwit over all the HT system.
If you have a place to run it in dark
kness you may even see the HT current tracking to earth.
Robby
Dirty Old Man
PostPosted: 22:55 - 07 Apr 2019    Post subject: Reply with quote
40 miles should clear out the fuel system. See if it is still misbehaving tomorrow, after everything has had a chance to soak away in fresh fuel.
Otherwise as said, electrical. Spray anything that looks electrical with WD40, and put the battery on charge overnight.
I would also hunt down and check the main earth strap from the battery to the frame, seeing as it should be fairly accessible. If there is any rust at either end, clean it up with some emery paper and give it a smear of vaseline.
The last post was made 5 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.51 - MySQL Queries: 17 - Page Size: 37.02 Kb
