| Travis Bickle |
 Travis Bickle Banned
 Posted: 22:43 - 16 Apr 2019 Post subject: New engine cover preventing starter motor from working |
Hoping someone can help here.
I bought my Fazer 600 as a category N writeoff. It had been dropped on the right hand side and sustained minimal damage to the front nose cone, broke the brake lever off and one of the side engine covers took quite a whack (pictured):
https://i.ibb.co/xYB73fC/20190416-221652.jpg
It's got drill holes in it as I was having trouble removing a bearing that sits set on the inside of the cover so drilled three holes in the front so I could prod it out with a screw driver (I made sure I removed all the swarf from the bearing before I fitted it back inside the new cover).
https://i.ibb.co/fSdh88j/20190416-210738.jpg
Not sure what it's technically known as but I've seen it referred to as the the crankcase cover / starter motor cover / pickup cover.
It had a hairline fracture in it and had been leaking but only very slightly, and only when the engine was running as the crack is above the level where the oil line is normally when it's resting. Would get a bit of a wet right foot and slippery footpeg after about a 30 minute ride. Nothing major a tissue couldn't wipe off.
Anyway after fitting the new one my engine wouldn't start. Just got the oil light come on while I was pressing the start button and all I could hear was a relay click from somewhere underneath the seat. I loosened the top bolts of the cover and it tried it again, it tried to start but sounded slow and whined like a flat battery. Loosened said bolts even further and it started up fine.
Have I cocked something up or is the new cover possibly not an exact match? It's not a genuine part!
I'm wondering if I bought a second gasket, and maybe a third, and fitted them on top of each other it would put a bit of distance between the inside of the case and whatever it's pinching to stop the starter motor working when the bolts are tight. Is that a definite NO NO to fit two or three gaskets on top of each other or can it be done?
I got a cardboard Athena gasket with the cover. The old one looked like solid plastic so maybe the cardboard Athena one is allowing the cover to be tightened more closely than it was designed for? Or maybe that's complete bollocks and the hard black plastic-looking gasket was once soft but just went brittle over the years.
Can someone please advise? ____________________
Must Go Faster
1999 Yamaha FZS600 Fazer |
| Sister Sledge |
 Sister Sledge World Chat Champion
| Travis Bickle |
 Posted: 07:45 - 17 Apr 2019 Post subject: |
Thanks for your support!
The bearing did definitely seem seated properly but could very well be upside down. I mean it looked the same on both sides to me but I suppose it's possible there are subtle differences. I'll have a go swapping it round.
What are shim washers? ____________________
Must Go Faster
| doggone |
 doggone World Chat Champion
| Travis Bickle |
 Posted: 07:49 - 17 Apr 2019 Post subject: |
Definitely should be flush anyway as it's kinda loose in its seat. Well not loose exactly but it slides in and out easily. Not like when it was in the original case where it was jammed in solid. ____________________
Must Go Faster
| Travis Bickle |
 Posted: 07:50 - 17 Apr 2019 Post subject: |
| Sister Sledge |
| Robby |
 Robby Dirty Old Man
| MCN |
 MCN Super Spammer
| Grubscrew |
 Grubscrew Scooby Slapper
 Posted: 15:11 - 17 Apr 2019 Post subject: |
Let’s play : How much cash in my wallet. (Pic 1.)
I recon there’s £345.00
The closest guess wins it!  ____________________ FJR1300/CBR1000F |
| Sister Sledge |
| Fisty |
 Fisty Super Spammer
| Travis Bickle |
 Posted: 17:02 - 17 Apr 2019 Post subject: |
| Sister Sledge wrote: | Shim washers are basically accurate washers of varying thickness. Spacers yes! They're machined flat and accurately.
My engine starter idler gear has several and it's very easy to put them on the wrong sides of the gear when reassembling. The difference in thickness is minute but makes a lot of difference.
Doesn't look like yours has an idler gear.
Triple check that bearing hole. Could even be machined badly and have a small radius at the side thus preventing the bearing fitting in fully flat. |
Yeah I didn't notice anything like these washers you mention. Just the bearing inset on the inside of the casing and a couple of hollow shafts that slot inside some of the gears. I'm 100% I got those back in the right places and the same way round that they came out.
I'm thinking the same as you, possibly bad machining. I've taken it to my mechanic today as it was booked in for him to do the front fork seals and front brake pads anyway, he's also suggested it may just be a poor match but before trying to re-machine it or carve into the bearing seating even further to try to make it sit deeper, he's said try putting another one or maybe two gaskets on it, which was my original thought.
| Robby wrote: | Out of interest, how much did you save from buying a pattern cover instead of an OEM one?
Either the bearing isn't seated deep enough, or (more likely) the pattern part isn't a very good one.
New OEM cover, new bearing (because you shouldn't keep pressing them in and out of things) and it'll work.
Don't layer up gaskets, it'll leak. |
I'm not sure how much I saved but the decision to go for a copied part wasn't to do with cost, I don't tend to be a cheapskate when it comes to vehicles in general but as I've said on a previous thread I can tend to be quit a lazy shopper. eBay and Wemoto (and Euro Car Parts for cars) are my first port of call, I'll only go looking elsewhere if the part I need isn't on either of those sites. Got this one from eBay and it was the ONLY new one I could find within the UK (was leaning towards a new copy rather than a used genuine part). Wemoto only stock the gaskets, not the covers. I'm also quite impatient so eBay is usually first on the list and I'll try to find a seller who does fast delivery.
I think you're right, the general consensus being that it's a poor quality copy and therefore causing the bearing not to seat properly. Although before buying a new OEM cover and bearing I'll see if I can make this good. The bearing came out quite easily once I had drilled through the casing and was able to prod it from behind, and it just slides in and out of the new casing with no resistance whatsoever so hopefully a new bearing shouldn't be necessary?
| MCN wrote: | TLDR.
What can you see when both covers are sat together on a the same flat surface?
Closely examine both parts one section at a time.
Look for nuances in casting thicknesses.
The cover may need fetling.
Contact the cunts who sold you the cover. Tell them your not happy. 😀 |
That's good advice but I'll have to wait until I get the bike back from my mechanic having done the front fork seals and front brake pads, hopefully will be tomorrow if he cracks on with it. I did notice in some areas the casting was quite poor and there were some burrs in places (which I thought I had taken care of them all), so yeah maybe just fettling the seat area where the bearing sits is the answer. ____________________
Must Go Faster
| Travis Bickle |
 Posted: 17:10 - 17 Apr 2019 Post subject: |
| Travis Bickle |
 Posted: 17:32 - 17 Apr 2019 Post subject: |
| Travis Bickle |
| autistboi |
 autistboi Banned
 - Super Spammer
| steve the grease |
 steve the grease Crazy Courier
| autistboi |
 autistboi Banned
| Pete. |
 Pete. Super Spammer
 Posted: 18:15 - 10 May 2019 Post subject: |
Dowel crushed and tight stuff is probably a badly drilled dowel hole. ____________________ a.k.a 'Geri'
The last post was made 7 years, 94 days ago. Instead of replying here, would creating a new thread be more useful? |
