Author |
Triton Thrasher |
Triton Thrasher Could Be A Chat Bot
Back to top |
CHR15 |
CHR15 Turbo nutter bastard
Posted: 21:56 - 25 Jan 2016 Post subject: |
have you got any photos of the head + valves when they're coked up?
that may give a clue as to how and where the oil is being burnt. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
Back to top |
stinkwheel |
Posted: 22:48 - 25 Jan 2016 Post subject: |
Now with added science!
I'm finding some of the numbers I'm getting here fairly mind boggling.
So:
Description
Late model Royal Enfield 350 bullet engines breathe an inordinate amount.
It has already been established that by repositioning the crankcase breather from the oil tank to its original design location on the crankcase, an as-yet unquantified vacuum exists inside the oil tank/crankcase.
It is possible to allow the oil tank to ventilate itself. It is uncertain what effect this will have on the quantity of gas being expelled fron the breather system.
Hypothesis
Venting the oil tank to atmosphere while retaining a direct crankcase breather could effectively turn the engine into a compressor.
Equipment
A 2007 350 bullet with a retro-fitted crankcase breather utilising a non-return ball valve, standard oil tank breather stub in oil tank and blanked-off timing chest return stub.
A bucket of water
A 750ml wine bottle
A length of silicone tubing.
A Royal Enfield duckbill breather hose.
A stopwatch (nokia).
Method
By filling the bottle with water , covering the neck and inverting it in a bucket of water, it is possible to insert a rubber hose into the bottle without disturbing the water. Any pressurised gas passed through the hose will displace the water.
The volume of the bottle is already established. By timing how long it takes to displace all the water, a rough gas flow rate can be calculated.
The engine was set to a fast idle speed of approximately 1,200prm then the end of the crankcase breather hose connected to the measuring apparatus.
Results
With the crankcase breather modification blocked off and a standard duckbill breather on the oil tank stub, the gas flow rate was 1.8 litres per minute.
With the crankcase breather modification active and the oil tank vent blocked, the gas flow rate was 1.7 litres per minute.
With the crankcase breather modification active and the oil tank free to ventilate to atmosphere, the gas flow rate was 10.0 litres per minute.
Conclusion
The gas flow rate breathed by the engine is not significantly affected by having relocated the crankcase breather to the oil tank.
By allowing the crankcase to breathe directly, a significant vacuum must occurr in the oil tank. By ventilating the oil tank, the engine breathes at a rate nearly an order of magnitude higher.
Discussion
To put these figures in perspective. A 350cc single cylinder engine will be displacing 420 litres of gas per minute both above and below the piston when rotated at 1,200rpm.
It is considered desirable to have a slight vacuum in the crankcase. This helps to avoid oil being forced up past the piston rings. If too high, it will cause resistance to the piston rising on the compression and exhaust strokes.
It is not considered desirable to have a vacuum in an oil tank, this can provide resistance to oil egress into the high pressure part of the lubrication system.
It would appear that ventilating the oil tank while allowing one-way breathing from the crankcase results in a massive increase in the rate of gas being breathed out. Suggesting some sort of through-flow effect not unlike a compressor. The effect of running an engine under load in this state remains to be seen and will be the subject of further experimentation.
What the effects of the differing breather locations at higher engine speeds has not been established.
Also video of the above experiment:
https://youtu.be/ET0Rv4fh-Yc
TL;DR Piss off, you wouldn't have got this far down the thread if you didn't have a reasonable attention span. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
stinkwheel |
Back to top |
CHR15 |
Posted: 23:30 - 25 Jan 2016 Post subject: |
what does the valve chest side of the head look like?
from what you wrote, my understanding is that the oil is scavenged from the crankcase and fed into the head, before dropping back down into the oil tank? (what a lovely simple way of lubricating the head and deaerating the oil!)
with the engine in the frame, is there the possibility of oil pooling around the guides to the point where it reaches the level of the stem seals? ____________________ Turbocharged drag thing / project death weapon / GK73A
Back to top |
stinkwheel |
Posted: 23:38 - 25 Jan 2016 Post subject: |
CHR15 wrote: | what does the valve chest side of the head look like?
from what you wrote, my understanding is that the oil is scavenged from the crankcase and fed into the head, before dropping back down into the oil tank? (what a lovely simple way of lubricating the head and deaerating the oil!) |
Yes, it runs down the pushrod tunnels into the timing chest to lubricate the tappets, cams and timing gear then runs out of there back into the oil tank.
Quote: | with the engine in the frame, is there the possibility of oil pooling around the guides to the point where it reaches the level of the stem seals? |
You know what, I've never checked. I should. Maybe I just need to get the dremmel out and facilitate a quicker flow of oil between the rocker area and the pushrod tunnel.
WIth properly pressure-fed rockers, it shouldn't need much oil hanging about up there.
Mind you. It's done it with two different heads.
I'm off to have a look now. Only needs 4 nuts undoing.
EDIT:
Yes. Yes it can.
And it would be much worse if it were leaned over to the left (like if it was on the sidestand). I can't see much one could do to stop it though. There's a narrow gap in the casting between the posts the rocker block is mounted on which is where any oil that lands up around the valve stem has to pass through to get out.
https://i48.photobucket.com/albums/f216/stinkwheel/enfield%20head%20231010/CIMG0292.jpg
As evidenced by the oil in top of the rocker block and nuts, oil gets flung about up there a fair bit.
https://i48.photobucket.com/albums/f216/stinkwheel/enfield%20head%20231010/CIMG0290.jpg
Poured some 10w-40 oil over the top of the valve to over the level of the seal and it takes a tedious count of 10 to disappear again. Admittedly that's with it cold.
If I can't open out the outflow, I'd have to reduce the inflow. I wonder if I should re-fit the old, lower volume oil pumps? Although I dimly recall it doing the length of the dipstick on the way home from the dealers. Although that means draining the timing chest, removing the gasket etc, etc which is tedious as hell.
More questions and ponderings. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
CHR15 |
Posted: 00:40 - 26 Jan 2016 Post subject: |
i would suggest taking it for a run, at a point where you dont have to use it for a while afterwards.
park it up on the sidestand and remove the carb, spin the engine to tdc on compression and leave it overnight. have a look if theres any oil coming down the stem or pooled on the head in the morning. ____________________ Turbocharged drag thing / project death weapon / GK73A
Back to top |
Triton Thrasher |
Back to top |
stinkwheel |
Back to top |
mysterious_rider |
mysterious_rider World Chat Champion
Back to top |
stinkwheel |
Back to top |
Triton Thrasher |
Back to top |
Northern Monkey |
Northern Monkey World Chat Champion
Back to top |
There is a gap of 3 years, 83 days between these two posts... |
stinkwheel |
Back to top |
BusterGonads |
BusterGonads Trackday Trickster
Back to top |
MCN |
MCN Super Spammer
Back to top |
BusterGonads |
Back to top |
Northern Monkey |
Back to top |
BusterGonads |
Back to top |
ajb235 |
ajb235 Two Stroke Sniffer
Posted: 10:39 - 14 May 2019 Post subject: 500 bullet oil consumption |
I have a 1993 500 Bullet which I have owned for 12 years, and I have had exactly the same problems. I have tried breathers the Hitchcock crankcase breather return, new valves new guides new Pistons new rings, all to no avail. This discovery is a life saver for me. My engine will be stripped and rebuilt ASAP! |
Back to top |
MCN |
MCN Super Spammer
Posted: 17:57 - 14 May 2019 Post subject: |
My BSA C12 was a pig to start. Iridium plug helped that but it was very under powered and got mad hot on short 3-4 mile runs on the flat.
I found that the ignition was only 180 degrees centigrade out. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Back to top |
The last post was made 4 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
