Somewhat (un)interesting things I didn't realise.
Bike Chat Forums Index -> Random Banter Goto page Previous  1, 2, 3 ... 10, 11, 12, 13, 14  Next
Easy-X
PostPosted: 17:34 - 20 May 2019    Post subject: Reply with quote
I may be lying in the gutter but I'm looking at the stars...
Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter
chickenstrip
PostPosted: 18:11 - 20 May 2019    Post subject: Reply with quote
They look a bit blurry though hic Wasted
chickenstrip
PostPosted: 15:05 - 21 May 2019    Post subject: Reply with quote
Lord Percy wrote:
To be honest, I think he just added unnecessary mysticism to the subject. At the time it was still a new and rapidly advancing area of research, regularly smashing all the old ideas about how physics works
Isn't it more a case of it having extended our ideas of how physics works? Some of Einstein's work is still among the best physics theory we have, isn't it?
I see it more a case of a separate field within physics, some of which overlaps into what we knew before, and some of which doesn't*. 'Physics' is very wide-ranging in what it covers.
* a question of scale?
Kawasaki Jimbo
PostPosted: 21:44 - 21 May 2019    Post subject: Reply with quote
I'm watching Terminator 2 (not for the first time) and have just twigged that the inventor of Skynet was called Dyson. Coincidence? Also now fancy a Honda XR100 as ridden by the young John Connor, which appears to have an infinite number of gears.
hellkat
PostPosted: 21:49 - 21 May 2019    Post subject: Reply with quote
Howling Terror wrote:
Blood mixed with lime mortar makes it stronger, more waterproof, more weather resistant and a shorter curing time.
*vaguely wonders why you would want waterproof blood*
Or weather resistant, for that matter ... Thinking
hellkat
PostPosted: 21:59 - 21 May 2019    Post subject: Reply with quote
As a lover of facts I too questioned that. Not like they had good quality school rulers in those days.
No, but they probably had 3048 of them, so they could measure that correctly.
hellkat
Guild of non-Vordermanonian calculations
3000x12=36000inches = 91440cm, divided by 30cm is 3048.
Fisty
PostPosted: 22:09 - 21 May 2019    Post subject: Reply with quote
It used to be used as a render for houses, its why lots of old cottages were pink.
Fatter and faster than Fret
Howling Terror
^^^These days they use chemical additives to give mortar additional properties. Blood mixed with lime, sand and sometimes grit obviously works as most heritage structures are still standing.
It wasn't common practise but for certain structures like aqueducts, then it was often used.
hellkat
PostPosted: 23:04 - 21 May 2019    Post subject: Reply with quote
Convenient how blood was more useful than piss.
So you have to kill things, rather than just go for a slash.
Life's so complicated.
Howling Terror
PostPosted: 15:33 - 22 May 2019    Post subject: Reply with quote
More like, what can we do with all this ox blood now the butcher has had what they needed?
Tell yer what, pour some in this mix.
FFWD>> a decade or so.
Hey-up Bill, that wall we built looks as good as the day we built it.
T'other one without it, dun't look as good. Yer can see where t'weather is getting at it.
Well fuck me gently and call me Derek. Who would've thought it.
Dunnae matter now Bill, they've got this fancy cement stuff.
A word for word account of how and why they briefly used ox blood in a lime mortar mix.
goto10
PostPosted: 15:44 - 22 May 2019    Post subject: Reply with quote
MCN wrote:
Britain will exit from the European Union on the 29th of March 2019.
Deal or No Deal.
bhinso
PostPosted: 15:25 - 23 May 2019    Post subject: Reply with quote
If you add every positive integer up to infinity, you get -1/12
True fact Thumbs Up
Howling Terror
PostPosted: 15:45 - 23 May 2019    Post subject: Reply with quote
I lose on average 1.5 sunglasses a year.
yen_powell
PostPosted: 22:17 - 23 May 2019    Post subject: Reply with quote
Are they on your head 0.75 of the time?
XT1200Z and a DR350 in bits
Howling Terror
PostPosted: 23:21 - 23 May 2019    Post subject: Reply with quote
There is an average of 1071 hours of sunlight per year (of a possible 4383) with an average of 2:55 of sunlight per day. It is sunny 24.4% of daylight hours. The remaining 75.6% of daylight hours are likely cloudy or with shade, haze or low sun intensity.
At midday the sun is on average 37° above the horizon at Manchester, England.
During 24.4% of daylight I wear them 33% of the time.
Shaft
PostPosted: 00:03 - 24 May 2019    Post subject: Reply with quote
Not necessarily, piss has been used for all sorts of useful things and still is.
Here's just one historical use..........
https://www.nationaltrust.org.uk/yorkshire-coast/features/how-alum-shaped-the-yorkshire-coast
They also used to use it in the process of tanning leather, which brings us to the subject of shit, or pure as it used to be known (google pure collectors)
Lord Percy
PostPosted: 03:42 - 24 May 2019    Post subject: Reply with quote
Yeah, extended is a better word, and yeah it's correct that physics is mainly a load of specialist areas which overlap into each other.
It's not about Einstein's though. He came up with relativity, and none of that was altered by quantum mechanics. QM changed our understanding of how matter exists at very small scales, regardless of whether it's stationary or travelling at light speed (Einstein's area).
Overlap in physics isn't necessarily decided by scale, but I think your thought process is correct. Quantum and classical mechanics are separated by an arbitrary cut-off point at which everything must be calculated using QM equations. The cut-off point isn't strictly defined though. I think generally it depends on the size and nature of the atoms/particles/photons you're dealing with.
Sister Sledge
PostPosted: 08:21 - 24 May 2019    Post subject: Reply with quote
Organic produce is not completely chemical free. It also does not use natural methods of production either.
Chemicals are used 'only when needed' which means antibiotics are still shoved into animals.
Soils can still have pesticides and other nasties dumped onto it.
Free range hens do not wander around farm yards where cars sometimes scatter them apart. Hens live in some challenging conditions..
Farming is nasty. Modern farming is intensive. Animals are filled with antibiotics because they're forced to live together in crowded conditions. Disease spreads rapidly and if one gets a bug, they all get some jabs.
Someone mentioned poop earlier and why I did this post.
Much of your solids from toilet use are turned into a farming product. Often the solids are mixed with lime and turned into what looks like a whitish grey mush. It's spread onto farm land and adds 'goodness' to the land.
The lime is added to kill germs but is never 100% effective. The lime does not kill off various chemicals which people have shat out. This includes hormones from the pill and other stuff.
I've seen sheep eating this human solids product whilst it was heaped up and ready to be spread. Many farmers just do not care.
Food crops are then grown on said land and we eat them. Remember to wash those ingredients folks!
No I'm not a greeny. I just know this stuff.
I have a heap of farming facts if people want them.
CCM 404 DS
grr666
PostPosted: 08:40 - 24 May 2019    Post subject: Reply with quote
Gracie breaks on average 2.0 pairs of sunglasses a year. It's made me scared to wear my nice ones on a dog walk.
pepperami
PostPosted: 08:45 - 24 May 2019    Post subject: Reply with quote
I lose ALL of my sunglasses EVERY year . I now wear a hat and squint Crying or Very sad
Islander
PostPosted: 09:03 - 24 May 2019    Post subject: Reply with quote
Isn't it more a case of it having extended our ideas of how physics works? Most of Einstein's work is still among the best physics theory we have, isn't it?
FTFY Thumbs Up
Islander
PostPosted: 09:07 - 24 May 2019    Post subject: Reply with quote
Piss was important too. Google night soil collectors - there was a huge demand for urine and urine soaked soils to extract saltpetre (potassium nitrate) for gunpowder production. Thumbs Up
It's allegedly good for compost heaps too. Razz
chickenstrip
PostPosted: 10:26 - 24 May 2019    Post subject: Reply with quote
I mentioned Einstein because I'm a layman, not a student or professor of physics, so he, of course, readily springs to mind. But as I understand it, he had some of the ideas about quantum mechanics wrong, subsequently proved so by others. Of course, that doesn't take away from what he did achieve.
bhinso
PostPosted: 13:39 - 28 May 2019    Post subject: Reply with quote
He was never a fan of QM, famously saying: "I don't believe God plays dice."
PostPosted: 10:45 - 07 Jun 2019    Post subject: Reply with quote
I saw this video about how flatworms fight with their penises and I immediately thought of this thread.
It's a video about penis fencing so some people might consider it not work safe.
https://www.youtube.com/watch?v=wn3xluIRh1Y
The last post was made 4 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Page 11 of 14
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.59 - MySQL Queries: 17 - Page Size: 145.63 Kb
