Heat induction tool.
recman
PostPosted: 20:21 - 26 May 2019    Post subject: Heat induction tool. Reply with quote
A bloke at work bought one a couple of weeks ago, he was raving about it.
He's desperate for me to try it so I might give it a bash on my header nuts as I gave up trying to remove them after plusgas failed.
From what I've seen they are extremely effective, anyone have any experience?
Riejufixing
PostPosted: 21:49 - 26 May 2019    Post subject: Re: Heat induction tool. Reply with quote
I have not used one, and at the price they seem to command, I ain't a gonna. There are a lot of alternatives for something I would use so rarely. A cheap nut splitter is less than a tenner, for instance. If you've got gas it would most often do the trick. A cold chisel & a hammer to support the other side of what you're hitting would often do it.
Not to say it isn't a nice idea, though. I remember using induction heating to melt lead in a school physics experiment a while ago. I'm sure it'd work, but - see above.
Sister Sledge
PostPosted: 08:04 - 27 May 2019    Post subject: Reply with quote
They have one at the garage my son works out but it's rarely used. Often they just get the oxy acetylene out.
I suppose they will have uses where flames are less favoured.
CCM 404 DS
ADSrox0r
PostPosted: 08:46 - 27 May 2019    Post subject: Reply with quote
Kind of tool I'd love to have but cost vs usage puts it way out of even my 'fuck it I'll have one' range.
PostPosted: 09:56 - 27 May 2019    Post subject: Reply with quote
We had them supplied on our ships to heat up roller bearings rather than placing them on hot steam pipes which H&S got a strop over.
Wonderful wonderful things if you haven the use to justify the cost.
the ones we had were like this, SKF make. I dread to think what they cost to supply 50 ships.
https://simplybearings.co.uk/shop/images/assets/products/tih220m_bearing_heater.jpg
Triumph Trophy Launch Edition
PostPosted: 13:54 - 27 May 2019    Post subject: Re: Heat induction tool. Reply with quote
They are handy but will it even fit over your header nuts with the exhaust pipes so close by?
The Artist
PostPosted: 14:44 - 27 May 2019    Post subject: Reply with quote
You can make your own for not much £.
https://www.ebay.co.uk/itm/1000W-ZVS-Low-Voltage-Induction-Heating-Board-Module-Flyback-Driver-Heater-UK/183042731885?epid=27028403753&hash=item2a9e326f6d:g:DIMAAOSwubFacUMw
You can also get some copper and make the element into a suitable shape for access into tight spots.
nutty_nick
PostPosted: 08:34 - 22 Jun 2019    Post subject: Reply with quote
we have one of these at work, and I have to say it is an incredibly useful piece of tack to have, we do a lot of agricultural stuff and sometimes with lots of hydraulic oil/straw/dust sat in the crevices of machinery the last thing we need is flames, ours is a "power hand" not sure what the boss paid for it but it will cherry red an m10 nut in seconds, for removing paint off of the wheel threads on jcbs and stuff before cracking the wheel nuts off its unbeatable few seconds and then aquick scrub with a wire brush will see even the thickest paint gone.. ive even used the loop part (comes with preformed coils or a long loop) on some quite large stuff, ok it wont get it cherry but if its out of its range it simply doesnt do anything, it "senses" the amount of resistance and wont turn on, obviously they only work on Ferrous materials as they work on magnetic induction so no good on aluminium, they will however heat up a steel stud going throgh an aluminium housing (vw top link bolts etc) quite nicely without scorching everything to smithereens
ADSrox0r
PostPosted: 12:29 - 22 Jun 2019    Post subject: Reply with quote
Bugger all in the grand scheme of things to a multi billion dollar industry.
Grubscrew
PostPosted: 17:18 - 22 Jun 2019    Post subject: Reply with quote
I have total success with a plumbers gas torch, heats nuts up a goodun, and rock the nut back and forth and it works.
FJR1300/CBR1000F
misscrabstick
PostPosted: 21:14 - 22 Jun 2019    Post subject: Reply with quote
the one we have you don't have a loop of wire that goes round the nut/bolt, it has 2 heads that you can change, one heats from the end, the other from the side, you simply hold it against what needs heating, it is amazingly useful, things that usually would shear and cost much rectification time just come undone.
MCN
PostPosted: 04:01 - 23 Jun 2019    Post subject: Reply with quote
It's a thing that SHOULD be zero cost.
But operators have a love affair with avoidable downtime. Very Happy
The arseholes I work for are still determined to use a deep freeze to freeze fit bearings. It somehow works if the bearings are 3' diameter but for the most part it's a waste of time.
Hammering a bearing on/in is plain fcuking retarded stone age practice. If one understands any fing about bearings.
'Heat or Freeze and fit with ease'.
You can use that phrase I just made up if you want. Wink
The last post was made 6 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 78.85 Kb
