Author |
777 |
777 Borekit Bruiser
Back to top |
Pete. |
Pete. Super Spammer
Posted: 17:08 - 13 Jun 2019 Post subject: |
Sounds like it's not charging and the extra load of revving the engine is pulling the battery voltage down. Un-plug the rectifier from the engine loom and check the AC output of the alternator with the engine at bout 5k rpm. Should be up around 50 or 60 volts AC at a guess. ____________________ a.k.a 'Geri'
132.9mph off and walked away. Gear is good, gear is good, gear is very very good |
Back to top |
777 |
777 Borekit Bruiser
Back to top |
Pete. |
Pete. Super Spammer
Posted: 17:46 - 13 Jun 2019 Post subject: |
Then check over the plug connections for the regulator rectifier and make sure none appear burnt or corroded. If they are ok check the DC output of the reg/rec at the plug. If there is none the reg/rec is dead, if you get a fair output from the reg/rec you probably have a fault on the neutral side.
I trust you have checked the battery connections are clean and tight? ____________________ a.k.a 'Geri'
Back to top |
777 |
777 Borekit Bruiser
Back to top |
777 |
777 Borekit Bruiser
Back to top |
Pete. |
Pete. Super Spammer
Posted: 17:57 - 13 Jun 2019 Post subject: |
Reg/rec is toast then. Easy fix, just swap it out. ____________________ a.k.a 'Geri'
Back to top |
777 |
777 Borekit Bruiser
Back to top |
777 |
777 Borekit Bruiser
Back to top |
777 |
777 Borekit Bruiser
Back to top |
Nobby the Bastard |
Back to top |
777 |
777 Borekit Bruiser
Back to top |
doggone |
doggone World Chat Champion
Back to top |
777 |
777 Borekit Bruiser
Back to top |
Pete. |
Pete. Super Spammer
Back to top |
777 |
777 Borekit Bruiser
Back to top |
777 |
777 Borekit Bruiser
Back to top |
777 |
777 Borekit Bruiser
Back to top |
The last post was made 4 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
