Author |
Kilshaw |
Kilshaw L Plate Warrior
Back to top |
Grubscrew |
Grubscrew Scooby Slapper
Posted: 20:26 - 22 Jun 2019 Post subject: |
I know that bolt/ nut if it’s the same....I had a ZZR1100 I worked on , had similar issue.
I did eventually get it out, but what had happened is the aluminium hole on the engine casing had corroded with the steel bolt. All this white stuff....oxidisation.
I managed to drill two small holes in the outer casting to the bolt edge, approximately 1/3 rd in from each end. Then I squirted wd40 in , whilst heating it. Let the wd penetrate it. Soak overnight regular squirts required. As it still was a bitch to get out, I ground the head or nut off, can’t remember which and used an SDS drill with an old masonry drill, using percussion and eventually it came out , as it shocked the bolt, knocking it back and forth and twisting.
I think from memory I left the nut on as it centralised the drill bit.
New bolt required was the only extra.
Good luck, as it was a real sod, ____________________ FJR1300/CBR1000F |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Sister Sledge |
Back to top |
Kilshaw |
Back to top |
ZRX61 |
ZRX61 Victor Meldrew
Back to top |
MarJay |
MarJay But it's British!
Back to top |
Kilshaw |
Back to top |
Islander |
Islander World Chat Champion
Back to top |
The last post was made 4 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
