Author |
Easy-X |
Easy-X Super Spammer
Back to top |
linuxyeti |
linuxyeti World Chat Champion
Posted: 11:55 - 24 Jun 2019 Post subject: |
Personally, I would imagine it would be cost prohibitive, and not likely to improve matters much, if at all. I've found to some degree treat efi bikes like carb'd bikes, and let them warm up first, leave it running whilst you get your jacket, helmet & gloves on, and that seems to solve most of the problems. Doesn't always work, even with my Triumph America, the engine would still randomly cut out slowing down from motorway speeds on slip roads, or going round roundabouts !! My Mash, would cut out, occasionally, until I started letting it warm up, after I started doing that, never had another cut out. On my little 125 (Mondial) the temp gauge on the dashboard flashes until it's deemed warm enough to ride..
The Superlight is fairly low powered, even by 125 standards, and I guess relatively heavy. Just picked one up for my daughter with 22Km's on the clock, as, that's the bike she wants to move up to when she's 17. Got it for a good price, and rode it home, quite a pleasant ride, but what is it with the indicator buttons !! ____________________ Beware what photos you upload, or link to on here, especially if you have family members on them |
Back to top |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 12:07 - 24 Jun 2019 Post subject: |
There's a simple adjustment that can be made to the EFI on my Enfield to the Throttle Position Sensor that causes slightly richer running - TPS resting voltage at idle should be 0.6v +/- 0.2v, so can be tweaked up to 0.8v to make it richer (WOT should be 5.0v).
https://www.youtube.com/watch?v=TiX8oFtYZls
Might be a completely different kettle of shite, but I'd be looking at seeing if there's an equivalent on your bike. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Back to top |
Easy-X |
Back to top |
Easy-X |
Back to top |
cb1rocket |
cb1rocket World Chat Champion
Back to top |
Easy-X |
Back to top |
linuxyeti |
Back to top |
MarJay |
MarJay But it's British!
Back to top |
Easy-X |
Back to top |
The Shaggy D.A. |
Back to top |
stevo as b4 |
Back to top |
Easy-X |
Posted: 20:38 - 24 Jun 2019 Post subject: |
Yeah but no but...
Indeed the voices in my head are yammering but personally I'm only interested in things that aren't a pointless waste of money and things that are interesting to do just for interest's sake.
Setting up a "home dyno" sounds like way too much effort obviously but it is annoying that it's only a sliver out of wack and yet there's nothing (practically) that can be done about it.
It also annoys me en principe that I have vehicle that in one aspect isn't mine as I'm subservient to a "closed shop" of ECU tuning. Wasteful and finicky as old carbs are at least they're yours to do with as you will...
I shouldn't be an idealist at my age ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
Easy-X |
Posted: 20:42 - 24 Jun 2019 Post subject: |
The Shaggy D.A. wrote: | The tweak is to rotate the body of the TPS to fool the EFI into thinking the butterfly is open wider than it is, so it adds more fuel. Could be a completely different setup on your bike, but worth experimenting with if (a) you have a similar arrangement and (b) you make a note of what it was when you started |
Yes, it is exactly the same. If I loosen off a bolt the throttle sensor can rotate a couple of degrees but this only changes the idle revs. It's the equivalent of twisting the throttle slightly, the dead spot will still be there Nice try though. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
Riejufixing |
Back to top |
Easy-X |
Posted: 22:18 - 24 Jun 2019 Post subject: |
As I understand it, the cat likes it hot (cue Ste gif!) but that comes at the expense of shortening the life of the rest of the engine
I would guess that "big name" manufacturers spend a bit more effort on their "emissions friendly" maps, VW even went just that little bit further for their customers
I don't suppose the Chinese spent quite as much time on the dyno with their copies creations. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
GettinBetter |
GettinBetter Crazy Courier
Back to top |
WD Forte |
WD Forte World Chat Champion
Back to top |
stevo as b4 |
Back to top |
Easy-X |
Back to top |
The last post was made 4 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
