Author |
Slimmy |
Slimmy L Plate Warrior
Posted: 12:43 - 24 Jun 2019 Post subject: Honda cd200 engine into cm125 |
Hi,
I have whacked a cd200 Benly engine into my cm125 to get a bit more power, however I have encountered a problem.
When the engine is started it ticks over ok but when Revved a bit it revs high on its own and sticks, revs come down but takes about 10 seconds, runs like a bag of shite.
What am I doing wrong?
The engine I’ve put in was 6v and my cm125 is 12v so I used the stator and all its 12v casing from the cm125 and added to the cd200, all fitted nicely but is this causing my issue, is that stator setup wrong some how for the cd200 engine?
I’ve cleaned carb, set up mixture screws, tried different float heights, my plugs are sooted up bad, not wet oily but fluffy carbon sooted up which wipes of easy, the cd200 engine has lowish miles and looks in good nick with good compression
If anyone can give me some advice I would be grateful ____________________ Slimmy |
Back to top |
A100man |
A100man World Chat Champion
Back to top |
Fizzer Thou |
Back to top |
Slimmy |
Back to top |
Slimmy |
Back to top |
Slimmy |
Back to top |
Robby |
Robby Dirty Old Man
Posted: 15:05 - 30 Jun 2019 Post subject: |
You're doing a top end rebuild, and cleaning up the valves and grinding them back in is part of the job.
Low compression could have something to do with the plugs sooting up, along with the other things that happen because the piston rings are worn.
Revs hanging is usually a sign of an air leak. Either inlet manifold poorly fitted or missing a gasket, or a cracked inlet, or you're really unlucky then it could be worn seals on the throttle butterfly spindle, so its sucking in air there.
The whole things need a proper going over. Piston rings wearing out is fairly rare, and suggests a lack of maintenance. Inspect the camshaft before you spend any money on it - or see if the one from your 125 engine is close enough to work. It is from the era when small Honda engines really needed frequent (~1000 mile) oil changes. If they didn't get that, they were liable to knacker the cam, the head, or both.
I almost forgot, standard answer - pass your test and get something decent. It would be embarrassing to get caught riding illegally by using a CD200 engine as a "performance upgrade". |
Back to top |
steve the grease |
Back to top |
Nobby the Bastard |
Back to top |
Teflon-Mike |
Posted: 21:14 - 30 Jun 2019 Post subject: |
why-do YOU WANT A cd200 MOTOR IN A cm125 frame to begin with?
If it's some bit of criminal mastermind to cheat Learner restrictions, look again; as stock and in good fettle, the 200 Benley barely makes the 15bhp permitted on an L-plate... it just has too many cc's. CM is also hardly a 'sports-bike', and with soggy twin-shock suspenmsoin and semi cruiserified geometry, hardly has the ingredients to make much of any extra oomph its given.... And wot you got be dodod anyway....
Before doing much more I would want to be pretty clear what I was tryingf to achieve...
See:- HOW2: Top End Rebuild Honda CB125 (Benley Motor)
Whether top ending the CM125 or CD200 lump, you are looking at the thick end of £200 in parts. Doing the 200 rather than the 125 gains you little, and probaby makes life harder to choose bits. Barel kits for the 125's are pretty commonmon the bay from china, 200's less so, and the 53mm bore barels have thicker liners and larger liner rebates in the crank cases, so using cheaper/more common 125 barel kit wou;d noy be a straight swap, and ISTRT that the gudgeon pin diameters differ also.
Hence probably as much work and money and less risk/hasel to recondition the CM engine.... and probably as much useful performance to be found.
If doing doe cheaps, then it aint really.... be better of cashing in the CM and sticking recon costs towards, well for cheaps or performance, a full licence, if you dont have one; plenty of sub £500 big bikes on the market and most of them, apart from a CD200 tend to have a lot more oomph for it! Can be cheaper to insure too.....
Else-wise, sorry to dis youyr pride and joy, but the CM125 is only as powerful as a CG125 poush-rod single, and no more economical.... smoother perhaps, more stylish... debate ably.... but the bottom line is that it offers bludger-all over any other 125 Learner bike.... so if dead, why try revive it, let alone mod it too?
Nut the answer is,motor need rebuild....See:- HOW2: Top End Rebuild Honda CB125 (Benley Motor) ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Back to top |
Slimmy |
Back to top |
Easy-X |
Easy-X Super Spammer
Back to top |
Teflon-Mike |
Posted: 01:49 - 01 Jul 2019 Post subject: |
I have briefly had a CD200 lump in a 125 S-D. It was absolutely no faster; the extra ponies just aren't enough to make that much odds; might have been stretched a bit muggering with sprokets, but CD200 has 4-speed gearbox, and rides on the low down stimp. It is actually quite nice, but I wouldn't chuck reconditioning money at a CD200 lump, to make a CM less valuable, less insurable, and not a lot better OTR.
Of the big bore Benly's, the CB-Two-Fifty lump would likely be gavourite for a straight swap... reletively cheap in the breaklers, and in good fettle, 19hp, five cog-box and a straight swap... that would be the cheaps way about with plusses for cheaps using take oot motor that does actually have a little exta oomph..... but still money I would query spending at all.
If you want a bigger bike, then there is little to stop you have one, apart from lience, and its likely easier, cheaper, safer, and as much charecter, or more than the CM125... go look at the small adds.... see whats on offer; pay heed to the Chinky made AJS raptor too, a cm/rebel clone they chucked the 233 lump into and even offered as a dealer conversion......
Otherwise, plenty of126-400 cruiserettes out there, none very sought after or expensive, all you need is a licence..... no spanners requied;' likely less to sinsure bludger all more to tax, just as ecconomical and nice to look at and ride.... L-plate restrictions are utterly self imposed... id upi dont want to suffer the4m, all you need so is take the tests, and they is hardly brain surgery..... and if you an taxkle the daily commute on L's no reason you cant do it once for man with clipboard, for less than price of repeat CBT...... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Back to top |
The last post was made 4 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
