A n00b polishing a turd
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3
Sister Sledge
PostPosted: 21:56 - 24 Jun 2019    Post subject: Reply with quote
It seems like part of a trap you've fallen for is in the aftermarket parts world.There's a heap of replacement shiny blingy nuts and bars and mirrors etc and the engine parts which claim to give power and all the stuff - those are just as good as a go faster stripe.
The racing CDI - have you opened it up to look inside? I expect it to look similar to one of those 'power savers' you plug into household sockets. Empty or with a capacitor inside.
I agree it can be fun messing on with stuff but you have to be wary of any ads claiming moar power for £2.
CCM 404 DS
Riejufixing
PostPosted: 22:13 - 24 Jun 2019    Post subject: Reply with quote
It's interesting. Apparently there are a few 'peds with the restricted-by-RPM systems, like the Kisbee mentioned. Boatiatione and things too. The "racing" ones may or may not be similar (I guess "not").
Easy-X
PostPosted: 22:26 - 24 Jun 2019    Post subject: Reply with quote
Originally the bike had no spark. At first I thought "no surprise, considering it also has no battery!" but obviously I know better now Smile
Anyhoo, the spark plug looked reasonable so that left the coil, the CDI or the stator. Coils and CDIs cost very little and are easy to fit. Stators not so much. I started with the easy stuff and it turned out to be the coil.
There were varying opinions on so called "racing" CDIs and went in not expecting much and that's what I got Very Happy
Easy-X
PostPosted: 22:28 - 24 Jun 2019    Post subject: Reply with quote
Oh, and in case I'm missing a trick, are there any cheaper ways to learn mechanical skills than junked and salvaged bikes?
Sister Sledge
PostPosted: 06:49 - 25 Jun 2019    Post subject: Reply with quote
Course there are.
Go into your kitchen and when it's not in use, get your washing machine and completely dismantle it - I'm talking every nut and bolt and if it's possible even the drum and remover the inner drum, bearings, seals etc etc.
The thinking is, washing machines contain more or less every component that a motorcycle has. The drum bearings and seals are similar to motorcycle wheel or primary drive units. There are pipes which replicate the various water cooling pipes on a bike. There are wires and what looks like a wiring harness too. Switches, small bulbs and so on.
Sure there's no fuel as such but remember too there are float sensors in washing machines that are a little like float valves on carbs.
Heck you could even repaint the washing machine and learn things there too!
I want a fiver for that tip.
CCM 404 DS
Easy-X
PostPosted: 09:56 - 25 Jun 2019    Post subject: Reply with quote
Umm... no!
I've errr.... already done that Wink And the tumble dryer and the dishwasher over the years.
Actually for the tumble dryer it was a good thing: some eejit overloaded the thing with wet towels the belt snapped, the drum got unbalanced and took out the rear bearing. Not knowing anything about tumble dryers I started at the front and worked my way back... doh!
Anyhoo, after struggling to get the belt on with screwdrivers and such I fashioned a tool out of some old steel pipe to slip over the end of the motor spindle and it was dead easy.
When the scandal over immolating white goods came up mine was one of the models affected. So I took it apart again and cleaned out all the fluff that was accumulating in dangerous spots - now knowing what everyone was banging on about.
Easy-X
PostPosted: 14:10 - 30 Jun 2019    Post subject: Reply with quote
This weekend's update. Took the stoopid pod filter off: keep things simple to start with Smile
Now have the new exhaust on but it's a bit too loud for my liking so I'm going to dick about with the baffle.
Going from an 84 jet to a 90 with the bore kit, new carb and exhaust but stock air filter seems to all work out quite nicely. Wasn't getting anywhere with it while the pod filter was on. From what I'm reading it'd probably need something like a 120 if you have really good air flow!!! Seems a bit unnecessary.
The stock air filter is ugly as shit so I might look to see what has similar air flow (or can have some restriction dialled into it.) Luckily £4 to £6 gets you an insanely large list of choices.
wr6133
PostPosted: 14:45 - 30 Jun 2019    Post subject: Reply with quote
When trying the pod filter are you only changing the main jet? You'll need to use a bigger idle jet and possibly play with the needle position as well or it will never idle or run right.
When I did one of these I ended up whacking a bigger carb on it but that was probably totally unnecessary and added faff because I didn't have a baseline to work from setting it up.
Easy-X
PostPosted: 17:54 - 30 Jun 2019    Post subject: Reply with quote
TBH what I'd like is stock(-ish) air flow but in a tidy package. A pod means you can chop the huge ugly stock airbox and the associated massive pipe that connects to the carb.
I'll shelve the airbox/pod experiments for now. I'm going to put a larger baffle in this:
https://i.imgur.com/Kf1g5L2.jpg?1
Ugly? Yes, but the stock one was disintegrating and this is as cheap as it gets Smile
I'll do a few commutes to work and see how I feel about variator weights and suchlike.
jayspeedy
PostPosted: 18:00 - 30 Jun 2019    Post subject: Reply with quote
Shocked it's...............big
2010 CBR600RR
Easy-X
PostPosted: 18:09 - 30 Jun 2019    Post subject: Reply with quote
That's what she said....
Actually, it looks big but is less than half the size and weight of the stock one...
https://webimg.secondhandapp.com/w-i-mgl/57fd1b0df0e229db1d857594
(random google search)
Sister Sledge
PostPosted: 07:42 - 01 Jul 2019    Post subject: Reply with quote
I'm confused.
The random search for a stock one shows a 2T exhaust surely? Quite different to a 4T exhaust.
CCM 404 DS
Easy-X
PostPosted: 16:12 - 01 Jul 2019    Post subject: Reply with quote
That's the exhaust that was on mine and as you can see from previous work on the bike it definitely has valves and a cam Smile
But you're right: it does have that expansion chamber thing going on. I suspect it is actually a 2 stroke one and they went "hey, sounds okay on the 4 stroke motor, job done!"
wr6133
PostPosted: 20:06 - 01 Jul 2019    Post subject: Reply with quote
It's probably a fake spanny chamber, technigas make one. I had one on the Vclic because it was the cheapest non rusty exhaust on eBay at the time.
Idle jet comment still stands based on the bore kit and the pipe.
Easy-X
PostPosted: 00:52 - 02 Jul 2019    Post subject: Reply with quote
Yes well it's been one of those "You know nothing, Jon Snow!" moments so I'm going to leave the stock air box on. Still, better to enter the "Hall of Stupid" with a discount ticket Rolling Eyes
The fake carbon fibre wrap sticker on the exhaust is truly awful, close up, but it does inspire me to buy a roll of "carbon fibre" tape to adorn the bike in hideous ways Twisted Evil
nutty_nick
PostPosted: 20:47 - 02 Jul 2019    Post subject: Reply with quote
i like this build, it has a lovely sense of "that'll do then"
keep it up Very Happy
Easy-X
PostPosted: 21:04 - 07 Jul 2019    Post subject: Reply with quote
Fixed up a few more things, rear indicator arm hanging off... JB Weld to the rescue!
https://i.imgur.com/KJzPoqf.jpg?1
I found the AC feed for the lights and swapped it for DC from the ignition. Swapped the wedge sidelight bulbs for LEDs but unfortunately the el-cheapo H4 LEDs (£4 per pair) I had were faulty Sad Lesson: never buy cheap shit from eBay if you need to rely on it Wink I'll see how it goes with the LED lighting, might go as far as replacing the gauge backlights too if the battery doesn't hold up in the evenings.
Finally I took a look at the cable and pipe routing around the engine and had a tidy up with the cable ties taking care to leave some slack there for suspension travel. As I'm going to stick with the stock airbox I also reattached the crank breather.
Still haven't got the replacement baffle yet so just for fun I started it up with no baffle... feck! it's loud Very Happy
Easy-X
PostPosted: 17:55 - 13 Jul 2019    Post subject: Reply with quote
Finished!!!
Here's what it sounds like with the new baffle:
https://youtu.be/IVX5sz9_Qio
It's loud but not "dial 101" loud Smile
And here it is in it's full errr.... "glory"
https://i.imgur.com/SdX0MAh.jpg?1
Not in the photos - final touches...
LED main bulbs and side lights
LED bulbs for gauges backlight
LED brake light
(Indicators have been left as filament bulbs as they're only on occasionally.)
I whizzed about on it yesterday to get the old oil circulating and changed it out today. Lots of crap and metal swarf trapped by the oil screen and oil plug magnet - as expected with a barrel change.
GPS checked the speed and definitely does >40mph with plenty left to go. I don't think the bigger piston and barrel did anything for the top speed but it certain has more low end torque, very nice! Pulling away is great, bit anaemic from 15 to 25 mph and then cruises nicely in the 30 to 40mph range. Ideal for little bit of light commuting; all in all, very happy with the way it's turned out Smile
Next stage should be variator weights and clutch springs but I need to make room for a bigger boys' bike when I pass my Mod 2 in a couple of weeks Very Happy
Easy-X
PostPosted: 13:05 - 15 Jul 2019    Post subject: Reply with quote
The journey is truly at an end: sold the scooter this afternoon. Seems someone appreciated the "look" I was going for Cool
The last post was made 7 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.08 - MySQL Queries: 16 - Page Size: 110.03 Kb
