Author |
8nisd10a |
8nisd10a L Plate Warrior
Back to top |
jaffa90 |
jaffa90 World Chat Champion
Back to top |
8nisd10a |
Back to top |
jaffa90 |
Back to top |
BusterGonads |
BusterGonads Trackday Trickster
Back to top |
8nisd10a |
Back to top |
8nisd10a |
Back to top |
Robby |
Robby Dirty Old Man
Posted: 21:26 - 15 Jul 2019 Post subject: |
Well it sounds like this was your first rebuild, and you don't know what you're doing, so it could be lots of things.
Its running, but not making power. You didn't mention what the compression was after the piston replacement, or if you honed or replaced the barrel.
So, things I would be suspicious of:
1. Air leaks, inlet side.
2. Head gasket not sealing - gasket surface wasn't clean enough, head not torqued down, re-used gasket, knackered mating surface.
3. Head damage - bent valve, bent/broken valve guide, valve seat problem.
4. Fuelling - carb filthy, full of water, generally blocked.
That's without thinking about the bottom end. You didn't mention what you did to stop the knock, like getting a recon crank. |
Back to top |
8nisd10a |
Back to top |
Nobby the Bastard |
Back to top |
8nisd10a |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
The last post was made 4 years, 282 days ago. Instead of replying here, would creating a new thread be more useful? |
