Danonymoose Derestricted Danger
Posted: 17:34 - 06 Aug 2019 Post subject: |
Robby wrote: | The reason you're getting lots of tricky questions is because its an RS125. People cock around with them, so there could be a bigger underlying problem.
If the bike is in otherwise good and standard-ish condition, then the only change required should be setting up the fuelling to match the new pipe. A bigger carb is not necessary to make it run right, but may (or may not) be required to get maximum power.
What is necessary is getting the carb set up to match the pipe. Sometimes the pipe comes with recommended carb settings, sometimes you can find it in forums. Either way, if you've gone up from 120 to 145 on the main jet, you should raise the needle height at least one position as well. The needle is really controlling the fuelling between one quarter and three quarters throttle opening.
Of course, it's an RS125, so someone could have messed with it. Common things include messing with the oil pump, disconnecting the autolube entirely and running pre-mix, and poorly done top end rebuilds.
So you want to do a compression check (on wide open throttle), and really make sure that the oiling is working properly. If it is blocked off, disconnected, or has air in the lines, problem.
Finally, if the trouble started just after filling up with petrol, that's a sign that it was running on pre-mix before and you've just trashed your engine. |
The autolube system is working fine. I was considering going pre-mix when I bought the bike, but after reading online about people not generally having issues with the autolube system, and seeing that is was working on my bike, I decided to leave it as is. A compression check shows 120PSI on wide open throttle, and that's been checked with 2 compression testers, so it should be reasonably accurate. |
P. Red Rocket
