Author |
chickenstrip |
chickenstrip Super Spammer
Posted: 11:36 - 29 Mar 2019 Post subject: |
Stinka wrote: | Next is to service the carbs as it’s rough as fuck low down
Complaints like this normally turn out to be EXUP problems, but you've serviced this, and presumably adjusted the cables as required too. You could also try resetting the TPS, a simple job which I can't remember off the top of my head, but info on it on the Fazer forum.
These bikes are always a little glitchy at low revs when standard. The Ivan's mod sorts this, either version.
Also, try a tankful of Shell V-Power. I've always found these bikes to run a little smoother on it, despite what others may say, although I'm not a stickler for using it all the time - just when a convenient opportunity arises.
But yes, perhaps it just needs a carb service/balance.
I really hate those standard silver rad and frame covers, so had this done on mine:
https://i.postimg.cc/vmWvhns5/DSCN0010.jpg
Carbon dip. It just looks plain black in most light. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
Back to top |
Stinka |
Stinka Two Stroke Sniffer
Posted: 13:13 - 29 Mar 2019 Post subject: |
Cheers mate, I’ll check all that thanks. And that looks beautiful |
Back to top |
chickenstrip |
Posted: 13:19 - 29 Mar 2019 Post subject: |
One other thing for folks who have just purchased one of these bikes. Underneath one of the fairing liner panels* (again, can't remember which side off the top of my head), there is a large electrical block connector, which sometimes gets dirty, and may eventually start to corrode inside, causing some problems. Worth cleaning this connector up once in a while, bit of contact cleaner should do it nicely, then some sort of suitable grease or treatment to keep it in good nick. Unlikely to be your rough-running problem though, Stinka.
Oh, and make sure you don't over-tension the drive chain when adjusting - common mistake with owners new to these! You should be able to push the bottom of the chain run up till it just touches the black plastic chain 'guide' on the s/arm when adjusted correctly.
*These panels crack easily if you are not careful tightening the screws when refitting. Try fitting some rubber washers underneath. The panels themselves are becoming as rare as rocking horse shit. I would suggest removing them before taking the bike to anyone else to work on - guess how I know this is a good idea? They can also cause all kinds of weird noises if the little damping pads around them are in poor condition. Best described as "someone swirling a bucket of nuts and bolts around" New or extra little foam pads solves it. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
Back to top |
MATTT |
MATTT Renault 5 Driver
Back to top |
Stinka |
Back to top |
chickenstrip |
Posted: 11:39 - 30 Mar 2019 Post subject: |
I have only had one brief ride on one of the very first FZ1s, unfaired, but my impression is it is focussed more towards the sportier side of things, or at least, has that feel in comparison. The gen 1 I think makes a better all-rounder, although the FZ1 is a perfectly good option for everyday use, from what I read.
The gen 1 has a very loyal following, and people return to them time and again. The FZ1 doesn't seem to have the same kind of pull. Perhaps it is too similar to many other bikes of its, and subsequent, generations? I wouldn't even say the gen 1 has more character - it does everything too well and reliably to be described in that way. It's just a better do-it-all bike, I think. A more complete package...or something ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
Back to top |
Stinka |
Back to top |
chickenstrip |
Posted: 14:10 - 30 Mar 2019 Post subject: |
Is it something to do with carburetted bikes having a more "connected" feel? Less sanitised?
I think the gen 1 will deserve classic status. It's like the last, and maybe the best, of a certain older breed. The FZ1 I'm not so sure about - might just get lost among all the other FI bikes of its generation. For someone who has never ridden anything other than modern FI/digitalised/rider aid bikes, they might not 'get' the gen 1? ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
Back to top |
MATTT |
Back to top |
Tdibs |
Tdibs Traffic Copper
Back to top |
69.9mph |
69.9mph Crazy Courier
Back to top |
Wyberton John |
Wyberton John Nova Slayer
Back to top |
chickenstrip |
Posted: 18:09 - 08 Apr 2019 Post subject: |
Wyberton John wrote: | chickenstrip wrote: | They can also cause all kinds of weird noises if the little damping pads around them are in poor condition. Best described as "someone swirling a bucket of nuts and bolts around" New or extra little foam pads solves it. |
Yes, 101%!!
Just got back from a quick 75 mile ride up the coast and yet again, this was blighting the enjoyment!
Been a right pain to my ears since I got the bike. Was just wondering if it was worth taping on some wadding, like someone at FOCU said they'd done. |
Thin draught excluder strikes me as a decent solution. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
Back to top |
Tdibs |
Posted: 18:15 - 23 May 2019 Post subject: |
Getting on alright with this one
https://puu.sh/Dwdsl.jpg
Ive moved up just outside the peak district now so had a few decent runs around it but want to stretch its legs some more. Gone for some Givi racks and going to be a topbox wanker at some point. Side racks for if I go somewhere away with the lady.
Im enjoying the bike a lot though. I removed all the front end to inspect it and investigate a massive ball of gaffa tape I could see under the infil.... Thankfully it was just bunching the connectors together and not a bodge. Tidied up some wiring, the end tabs on the fairing infils were broken and one of the mirrors is sized but just typical stuff.
Main problem I am having is a really bumping ride still, it feels like knocking through the bars when going at a steady speed at lower speed/rpm. Its no the fueling as I can hold in the clutch and I can still feel it. Jacked up the front end, bearings, head and wheel, both feel great. The back disc is warped though, asked for it checked when I got new tyres and there was some runout, but the mechanic said it was not terrible, not close to the limit at all. I can feel it pulsing through the pedal quite a bit though so going to put a new one on. I cant really think what else a bumpy/knocking feeling through the bars could be? Chain has no bad hardspots, suspension travel feels free and responsive. I can only think the disc is giving the bad ride.
Cant wait to get it over into europe by the end of the year ____________________ Previous : 09 Vanvan 125| 02' Sv650s || Current: 1999 Xj600n | 1992 DR650 RSE | 2005 Fazer 1000 |
Back to top |
Shaft |
Shaft World Chat Champion
Back to top |
Tdibs |
Posted: 23:11 - 10 Jun 2019 Post subject: |
Shaft wrote: | Tdibs wrote: | Getting on alright with this one
Main problem I am having is a really bumping ride still, it feels like knocking through the bars when going at a steady speed at lower speed/rpm. Jacked up the front end, bearings, head and wheel, both feel great. |
Fork bushes? |
Possibly?
I took it out armed with spanners, got the rear shock adjust pretty well now, it had no static sag set before and was pogoing me out the seat.
The front however, ive been through all the spectrum of settings, the problem is the first ~10% of fork travel. There is massive resistance to the first 10% of travel, once you overcome that, the fork works as it should. This is what is giving the awful bumpy ride as most small undulations in the road dont force the fork to travel more than the first 10%.
Im in two minds, to see where rebuilding it with new bushes and oil gets me, or send the forks out to K-tech ( few hundred quid) and getting springs and maybe a revalve done. ____________________ Previous : 09 Vanvan 125| 02' Sv650s || Current: 1999 Xj600n | 1992 DR650 RSE | 2005 Fazer 1000 |
Back to top |
Tdibs |
Back to top |
The last post was made 4 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
